Williams wall furnace, top vent.
The pilot turns on and works fine but when the heater reaches the desired room temperature and the unit turns off, so does the pilot light.
  • 1 more comment
  • Anonymous Dec 14, 2007
    the pilot wont stay on
  • Anonymous Dec 15, 2007
    I relit the pilot it worked for alittle bit,but went out.Then I changed the thermo-coupling relit the pilot worked for alittle bit and went out.I noticed the flame was flikering at this point.What can I do to fix my wall unit?
  • Anonymous Mar 19, 2014
    my heater will turn on fine, then it will cut off before the desired temperature is reached and code 88 will show on the display.
I've replaced a Williams wall gas heater non-electric. The thermostat is connected right and mounted on the wall. But, there's a thick black copper wire on the side of the furnace tagged thermostat. I don't know what to do with it? Where do you connect this wire? When it touches the top screw of the three screws running vertically(where the other wires are connected). The burner lights up and stays on, even if you play with the wall thermostat. Touching the other two screws doesn't do anything. Now, the manual talks about connecting it to the venting wires? Extra wires coming from the top or maybe somewhere else in the wall? I've left it connected to the first screw, ran the heater. But, it never turns off? Any suggestions? Thanks
Posted on Feb 23, 2008
    Sergeant:
  • 288 Answers
Is this an old heater? If so the burner may be in bad shape so when the thing turns off it is blowing out the pilot flame. You happen to notice a whooshing sound when the thing goes off?
Posted on Dec 18, 2007
If the flame is flickering then the pilot is clogged, it probably needs to be cleaned in order to get a proper flame to the thermocouple. The flame should be constant and blue not yellow at all.
Posted on Jan 03, 2008
  • tigermark76
    tigermark76 Jul 23, 2013
    When its operating it works perfectly its only when it reaches temp and tries to restart that it needs to be reset
If your old furnace is faulty replace the unit for safety and efficiency. it will pay for itself in energy.
Posted on Dec 20, 2007
Thermostats aren't very expensive. You can get universal ones at home improvement stores.
Dec 06, 2016 | Williams Heating & Cooling
Williams wall heater 2509622. How do I keep the pilot on? It tends to turn off after it reaches the desired temperature.
WILLIAMS 2509622 OWNER'S MANUAL Pdf Download.
www.manualslib.com > Brands > Williams Manuals > Furnace > 2509622
2509622; 2539622; 2559622; 3509622; 3539622; 3559622; ... WHAT TO DO IF YOU SMELL GAS: ... Williams furnace co. direct-vent wall furnace owner's manual (24 pages) ... Caring for Your Furnace ............24-25 Locating Wall Furnace and Thermostat ........6-7 Learn how to keep your new Williams Furnace operating.
How to light Heater or Furnace Pilot Light Gas Pilot of ...
? 5:01
https://www.youtube.com/watch?v=FZVQmKTYTTg
Oct 25, 2013 - Uploaded by 3p0cHx
How to light a gas pilot for a heater or furnace of the Williamstype. This is a general guide and is not ...
[PDF]Monterey Installation Instruction Manual - Home Depot
Dec 08, 2015 | Williams Heating & Cooling
The pilot goes out when the heater cycles
The thermocouple is not working correctly. sometimes you can clean the soot build up from it and it will work again. sometimes they just need replacing. the thermocouple is what the pilot light flame heats up when you turn on the heater. when the thermocouple gets hot it sends a 20 to 60 millivolt signal to the gas valve to activate the gas flow to the main burner.
Feb 18, 2015 | Williams Wall Heaters: 50,000 BTU/Hr...
Chimney type wall furnace. The furnace won't start However after switch was off for a couple hours and turn on the switch it started. What is a possible problem?
The problem sounds like the thermocouple is not working correctly. After being off for a couple hours allowed it to cool down and reset. Sometimes you can clean the soot build up from it and it will work again. Sometimes they just need replacing. the thermocouple is what the pilot light flame heats up when you turn on the heater. when the thermocouple gets hot it sends a 20 to 60 millivolt signal to the gas valve to activate the gas flow to the main burner.
Feb 16, 2015 | Williams Wall Heaters: 50,000 BTU/Hr...
I have a Williams direct vent wall furnace(LP) and something is wrong with the pilot. It wants to blow out when the furnace runs just a few minutes and appears the flame of the pilot is shooting out both...
You will need to remove the burner and then you can gain access to the pilot assembly, it sounds like the pilot is rusted and falling apart, it is recommended to replace the pilot assembly. These direct wall units need maintenance before the call season and after for them to work efficiently
Mar 01, 2018 | Williams 6508732 Gas Heater
William forshaire 435 runs well for awhile until
Try cleaning your thermocouple,and resetting it where was, which is located at the pilot flame. this should solve your problem.
Feb 23, 2010 | Heating & Cooling
I have model#2509622 Williams wall heater. I just installed it and the pilot lights fine. There is a copper ground wire, but the only way the furnace will fire up is when the ground wire is in contact with...
can you manually fire the unit w/o the thermostat by shorting 2 of the 3 wires, there may be more wires than that, but you should be able to fire it on 2 to 3 wires alone let me know it sounds like something is floating voltage wise on the unit
Oct 09, 2009 | Williams 1403622 Gas Compact Heater
Williams gravity vented wall furnance - where is the pilot?
Its in the bottom of the heater behind the vent cover . I don't know where you are but your local gas utility will come out and lite this for free.
Dec 10, 2007 | Williams 2509612 Ceramic Mid-Size Heater
Unable To Keep Pilot Light Lit!
I have a Williams top vent gravity wall furnace (model 5009622) and I had the same problem. I had to take the cover off the furnace -- screw on top and two at the bottom (open the access door and there is one screw on each side) to get to the reset button for the vent safety shutoff system. On my furnace it's on the left side toward the top of the unit. I pressed the little red reset button and it's been working ever since. If your furnace is properly installed and doesn't have bird's nest in the chimney, it should work fine. Good luck!
Mar 04, 2007 | Williams 2509612 Ceramic Mid-Size Heater
Heating & Cooling Logo
1,749 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
