The main thermistor TH1 has poor contact or open circuit.The thermal switch TP1 has an open circuit.The fixing heater has an open circuit.The SSR is faulty or the DC controller PCB.After the main power switch is turned ON the temperature detected by the main thermistor does not reach 70 C.The error must be reset in service mode :COPIER - FUNCTION - CLEAR - ERR.
We have the Oce im2330 for our small business. It was working fine until a couple weeks ago when I...
(More)
We have the Oce im2330 for our small business. It was working fine until a couple weeks ago when I powered it on and it went from warming up to call for service error code F103. I would like to try to fix this but need some instruction. I think I have determined it is a hard drive problem. This was the explanation provided for the same problem on a Toshiba 282 (which appears to be the same copier branded differently). Where is the hard drive? What type of hard drive should is required for replacement? Once I have physically replaced it; Now what? Help!
I have a Lanier MS 105 voice recorder that needs to be repaired. Can you repair older products such...
(More)
I have a Lanier MS 105 voice recorder that needs to be repaired. Can you repair older products such as this one?
computer reports print job is going to imagerunner but pringint has stopped. There is paper but...
(More)
computer reports print job is going to imagerunner but pringint has stopped. There is paper but screen report receiving data a nd processing, nothing coming out?
