Overiding Empty Cartridge error for Dell A10 962
Ink cartridges were already replaced.... Red flashing light still blinking indicating low levels. Error on screen still shows low levels error. how do I overide.
Machine is printing perfectly
  • Anonymous Mar 27, 2008
    Having the same problem.
Red flashing light on '8BK' small black cartridge on left hand side.
If this indicates 'low ink' then it is not alerting me on the monitor. I think this is something different because my printing has been interrupted. Aileen
Posted on Apr 29, 2008
Ink light is on. which cartridge needs to be replaced
The printer's indicator lights tell you when to obtain a replacement ink cartridge by flashing when ink is low, and when to replace an empty ink cartridge by remaining on when ink is depleted. The LCD panel also displays INK LOW or INK OUT.
Even if only one ink cartridge is empty, the printer cannot continue to print.
Nov 24, 2014 | HP DeskJet 960c InkJet Printer
Empty cartridge light keeps flashing
These cartridges don't have anything internally to check for new ink. They simply work on a basis of counting pages and page coverage to estimate ink levels. As such it is perfectly normal for your printer to warn of low ink once the cartridge has been refilled.
A low ink warning in itself should not stop your printer from printing though. If it does it is likely that the light is actually indicating a problem recognising the cartridge after refilling. I would recommend cleaning the copper contacts on the front of the cartridge and checking for any messages on the connected PC or laptop for more information.
Oct 16, 2012 | HP DeskJet F380 All-In-One Printer
I have an hp deskjet 940c. I don't know if this is the same model as deskjet inkjet. Anyway what light is on or off on the front when a new ink cartridge(s) is needed?
For the HP 940c, there is only one light to indicate a possible low ink cartridge. The LED above the cartridge symbol (the only one without a button) will flash. (Note: this LED is the second from the left.) When you see the error code, open the printer's top cover. If the error is a low ink issue, the LED will stop blinking.
With the cover open, the cartridge carrier will move until the yellow arrow lines up with an icon on the printer itself. These five icons are in order from left to right (as you look at the cartridges) : tri-color ink cartridge problem, black ink cartridge problem, tri-color ink low, black ink low and cartridges OK. If both cartridges are low, replace the one indicated by the arrow. Then the cartridge carrier will move to indicate the other cartridge is low. (If only one has a problem, after you replace it, the carrier will move to the cartridge OK symbol.)
If HP offers the full-feature software for your OS, then install the software. Use the HP Deskjet Toolbox to get exactly which cartridge needs to be replaced without needing to be ready to replace both (or to monitor your ink level (approximate ink level)).
The manual for the Deskjet 940c is available as a PDF from HP: http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=125&prodTypeId=18972&prodSeriesId=35985 .
I hope this helps.
Apr 11, 2011 | HP DeskJet 940c InkJet Printer
Colour ink cartridge empty but the on off light and red ink light flashes alternately and the carriage will not move to allow access to remove the empty cartridge.
hello, are you sure its not the error light that is blinking alternately with the power light, or is ink light indicator blinking , and just the power light blinking. i would first problably pull the power cord. then plug back in, and try again. the alternating error light and power light would be inkjet service, maint or waste pads are full, as far as the other error, i looked it up, and that error not coming up, unless there is something else going on. maybe cover for ink cartridge is caught, and not allowing printer to cycle.
Oct 05, 2010 | Epson Stylus Photo 1290 InkJet Printer
Reset the ink memory level after replacing cartridge
Have you tried to unplug your printer and plug it back in?
May 31, 2009 | Dell 962 Photo All-In-One InkJet Printer
maybe it have the ink level chip which can be resetted by removing the cartridge and oning and offing the printer for 5 times within 10 minutes coz it saves data of a cartridge upto 5 use before only.. and 6th time insert it.
Nov 15, 2008 | Dell 962 Photo All-In-One InkJet Printer
I would take out both cartridges and put them in again. Realign the printer and the error codes should remove themselves. Try turning the printer off and on before puting the cartridges in again. That may make a difference. You can let your computer know not to tell you when the ink is low too. Let me know how this work for you.
Cynthia Charczenko
Dec 26, 2007 | Dell A940 All-In-One InkJet Printer
It will not print.
Hi Greenhorn, Your info is slightly conflicting - I think. As I remember the C60 has just 2 LED's: 1 - Green for Power 2 - Red for Error The third button - Cartridge exchange - has no LED Now it is a while since I looked at a C60 and my brain leaks like a sieve, but that's the way I remember it and feel free to correct me if I'm wrong. The error codes I remember are: Printer status - Indicators - Priority Power - Error Power ON condition On - Ink sequence Blink - Ink Cartridge change mode Blink - Data processing Blink - Paper Out *1 - On Paper jam condition *1 - On Ink end (Black) *1 - On -> Blink Ink level low (Black) - Blink-> Blink Ink end (Color) *1 - On -> Blink2 Ink level low (Color) - Blink-> Blink2 Ink end (Black and Color) - On -> On No Ink Cartridge (Black or Color) *1 - On Maintenance request (Ink Overflow Countererror) *1 Alt Blink Alt Blink Fatal error *1 Off On Special setting Blink2 Blink2
Mar 27, 2007 | Epson Stylus C60 InkJet Printer
Refilled black ink before it ran out-now can use at all
After hours of reading about this I finally found the solution. This will NOT reset your levels but you will be able to print without being told you have empty levels.
Start, Control Panel, then Printers and Faxes.
On the next screen, Right click on your printer then on Printing Preferences. Now select the Advanced tab.
Near the bottom left, you will see more options. Click that and then Appearance. Check NEVER display printing status and make sure under Complete-A-Print, all is unchecked. Click OK at the bottom.
You can print without the stupid messages coming up. Dells printer ink cartridges have a computer chip in them and the refurbished ink does not which causes these error messages telling you your ink cartridges are empty.
Jan 14, 2007 | Dell 924 All-in-One InkJet Printer
497 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
