Question about Acer X191WSD Monitor
ACER X191 Monitor - Speaker input?
ACER X191 Monitor
I just bought speakers but cannot find the input. How am I missing it?
Thanks,
Leah
    Problem Solver:
  • 20 Answers
Go monitor back side and Saw of spk input point .input point name is line in .then insert the jack and connect ur pc lin out put point for Sound
Posted on Dec 29, 2007
Just bought a Harbinger HX121M 2" Monitor, from Musicians Friend it did not come with a booklet on how to wire into my sound system it has two 1/4" jacks and a strange round plug about the size...
If you don't know how to connect this... well we don't either because you did not tell us what your sound system is. The larger plug is what is known as a "Speakon" connector and is a fairly reliable speaker connection that is used now. For your use you will PROBABLY use either of the 1/4 inch jacks with a cable from the amp that will drive the monitor(s). If you have multiple monitors you will daisy chain them using the 1/4 inch jacks and SPEAKER rated cables creating a string of speakers with input going into one and an output from the same one to the next speaker and so on...USUALLY you will be limited to two speakers per amp output...
Aug 15, 2011 | Harbinger HX121M 12" Stage Monitor
I have no audio out. Buy my S243HLBMII monitor have a speaker and an audio input. audio input is only enable while I connect the lcd with vga cable. I want to disable the audio in and want to make it audio...
Hi lucasthehack,
I would like to help regarding your concern about the Audio issue you are experiencing with your LCD monitor using HDMI.
Since you are using HDMI you really do not need to look for an audio out to get sounds out of your LCD monitor.
- On your screen you will see a speaker Icon wherethe time is, right click on the speaker Icon then select Playback Devices.
- In the Playback Device Window you will see HDMI on the top of the list right click on it and click set as default, this will give you aduio out from the HDMI connection.
Restart you system with the HDMI conencted to the LCD monitor this should make the changes we made work using HDMI video and audio on your LCD monitor.
Thank you for choosing Fixya,
avf110686
Dec 21, 2010 | Acer S243HLbmii Widescreen LCD Monitor 24...
Bought a powered monitor as it said to do in the owner's manual, even though I thought it was weird as you usually use a passive monitor with a power amp. Purchased Kustom 10" powered monitor, hooked...
You haven't mentioned what model and manufacturer the mixer is. I will have to guess and say that the monitor out on the board isn't providing signal to the powered monitor or the monitor out on your board is powered and is now damaged by plugging a powered monitor into it. Carefully reread your manual and determine if the monitor out on your mixer is powered or line level. Reread also and make sure that the signal you are monitoring is assigned to monitor out, levelled correctly etc. If you find that the monitor out is passive (line level) try hooking it up to an external power amp and speaker. A guitar amp will do for testing purposes. Start with a low input volume on the amp. Also make sure that if it is passive to use a shielded cable from monitor out to input. If your board has powered monitor outs you can use a speaker cable from monitor out to speaker input (non powered monitor speaker).
Dec 10, 2010 | Kustom Profile 2 PA Speaker / Mixer Stand
Speaker in the Monitor?
It looks like there are no speakers according to:
http://support.acer.com/acerpanam/monitor/0000/Acer/X193/X193sp2.shtml
You should be able to use any external speakers to your system. The question is looks and power. You will likely have to buy speakers that have power in order to get enough volume.
Most speakers that come with monitors are of very, very low quality. You now have the option of buying good speakers (if you want to pay for them). If you are in a hurry you can likely pick up cheap speakers at the drugstore or Walmart. Another option is headphones.
Good luck finding the right sound.
May 24, 2010 | Acer X193W LCD Monitor
Monitor Speakers are working however I can not adjust the volume to a level I can hear (I am not deaf) I have gone to the control panel and increase the settings there but still unable to hear ir clearly....
The speakers for the monitor are low rated in terms of required power input. You can open the speaker box and disconnect one from the two wires connecting the speaker and leaving the other one still connected direct to speaker.
provide a resistor from a range of 25000 to 30000kilo ohms and connect the chosen resistor between the wire which was cut on the speaker. this way you will provide what we call attenuation on the path. please check and try this method. thanks for asking fixya.
thanks.
Jan 06, 2010 | ViewSonic VA1930WM LCD Monitor
I just bought an acer x213h monitor,has no speakers which i was aware of.But i did not know there was no audio input for this monitor.Is there a way to fix this problem
Monitors that do not have built-in speakers will not have an audio input.
Just purchase a set of external powered speakers and connect it to the audio output on the computer and place a speaker of each side of the monitor.
Oct 22, 2009 | Acer Computers & Internet
Hook up monitor speakers to PC?
how i hook up my JBL SPEAKER TO MY COMPAQ COMPUTER LOST MY DIAGRAM TO THE COMPUTER FORGOT HOW TO HOOK THE WIRE TO MY COMPUTER
Mar 18, 2009 | Compaq fs740 17" CRT Monitor
Sound
If your monitor have inbuilt speaker, then you need not to plug it, because the monitor cable will work for that. I have ViewSonic 19" with inbuilt speaker and its working without any extra cable or connection.
Thanks
Iqbal
Mar 23, 2008 | Acer AL1916W 19" LCD Monitor
No Sound on Envision H22W Monitor
The Envision H22W has speaker grilles, but does not include speakers. Note there is no input connector for audio.
The Envision G22LWK does have built in speakers. I think they just used the same mount/frame for both models, but only the G model actually includes the speakers.
Note that the web specs and the manual for the H22W says nothing about speakers.
No doubt this is why the H22W costs appreciably less than the G model.
Dec 09, 2007 | Computers & Internet
User manual
Try the following link (it will take a while to load)! http://csd.acer.com.tw/acer/URMUL1.NSF/1af87a750eeeb70f0825628f006e0bfc/86c01365b6b82317482572330038e26e/$FILE/X191%20user_enu.pdf
Jul 25, 2007 | Acer X191WSD Monitor
Acer X191WSD Monitor Logo
141 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
