Question about BenQ PB6200 Multimedia Projector
Vertical white lines and color is way off on BenQ PB6200
Whenever I turn on the projector, a series of Vertical White lines cover the screen. Also the color is way off on the actual video as well.
Whats could be the problem and how much will it cost to fix?
SOURCE: BENQ PROJECTOR
Mine needed a "fan module" replaced. The part number is 60.J8613.011.
Cost was $60, plus $100 for labour.
Posted on Apr 10, 2009
projdoc
  • 2237 Answers
SOURCE: Flickering dots on Benq PB6200 projector.
it's not the lamp. if you've replaced the cords and still have the problem, reset the settings to factory default to make sure the resolution matches. if still not ok, there may be an issue with the main board.
Posted on Nov 12, 2009
  • 75 Answers
SOURCE: My pb6200 benq projector's colour is wrong.
Your correct about missing your primary color. this could be either your cable or the connection at the projector could have a bent pin on the port. not sure what your trying to display computer?
Posted on Jun 05, 2010
  • 81 Answers
SOURCE: my benQ bp2 120 micro seris projector keeps turning off
One of two issues. One, the unit keep overheating. Common even with my projector. These things should be serviced and cleaned as dust clogs intakes, fans and exhaust ports. Proper venting is essential. If you have the ability, take the unit apart and use compressed air to blow off all circuits, vents and generally all around. Do NOT use high pressure...just the blow off cans will work fine. Second, the lamp could be on it's way out. Check the hours on the lamp counter. Generally, a lamp life that states it is good for 2,000 hours will last about 1,500 as turning the unit on an off eats lamp life.
Posted on Jun 30, 2010
sodeep
  • 3267 Answers
SOURCE: Greetings! My Benq PB6200 was working fine until I
if there are no leds lit, replace the power supply. if there are, and the fans are on but no light, it's the colorwheel.
Posted on Dec 20, 2010
Turn on benq pb6200 with new bulb all I get is humming and no led
same problem here. checked fuse, mainboard seems ok. nothing looked blown.
Jul 15, 2010 | BenQ PB6200 Multimedia Projector
My pb6200 benq projector's colour is wrong. Missing green. Has a lot of blue & red. How do I fix this please? Have since replaced the lamp - does the same with both old & new lamp. Also has a...
Jun 01, 2010 | BenQ PB6200 Multimedia Projector
Oct 04, 2009 | BenQ PB6200 Multimedia Projector
Hi. I have a problem with a white line on the screen
Hi
This will probably be a vertical white line you are seeing ?
Common BenQ Mainboard problem that can unfortunately only be solved by replacing it.
Nov 26, 2008 | BenQ (200NSH-LAMP) Projector Lamp for...
Thin vertical line appears on projector
I have found that vertical lines that suddenly appear from projectors are due to poorly connected cables. Sut off your projector and wait for the fan to go off. Then unplug the connectors from the computer to the projector and secure them again, making sure to go all the way. Hope this helps.
Nov 25, 2008 | Office Equipment & Supplies
Color problem
Check the cables connected to the back of the projector. reinsert the cables a few times to get a good contact. Jiggle the connection at the projector to see if there is a bad connection, do this while viewing the image on the screen. If everything is good and no response to the connections, It might be the main/input board is bad and will need replacement.
Aug 16, 2008 | BenQ PB6100 Multimedia Projector
White vertical line on left side of screen
Hi there
This problem can only be fixed properly by replacing the Mainboard.
Jan 01, 2008 | BenQ PB6100 Multimedia Projector
A vertical white line on the projected screen
i'm having the same problem some one sugested changing the input tryed s-video and nothing i've taken mine apart and cleaned the color wheel thinking something was bloking light or the image the only thing i havent messed with is the lens area but i'm going to try it i'll let you know if it worked hopefuly someone can help us bcause now i'm stuck with a $300 bulb i hope i dont have to buy another 1
May 07, 2007 | BenQ MP610 Multimedia Projector
BenQ PB6200 Multimedia Projector Logo
182 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
