Question about Canon PIXMA MP780 All-In-One InkJet Printer
Print quality and color
For some reason the print quality in black is sketchy (sort of fuzzy a little) and the colors don't print correctly ie: brown comes out green etc.
  • fairfight Dec 13, 2007
    I am on a mac, so I tried aligning the print cartridge, cleaning it with all those functions and still it looks like the "magenta" isn't printing.
  • 106 Answers
Go into your canon control panel and hit align ink
that should solve your problem
Posted on Dec 13, 2007
Black printing is fuzzy; other colors not printing
First thing you want to do is print the print quality test pages. Using the up and down keys and the enter key, you want to go through menus as follows: Troubleshooting>PQ test. This prints unique single color pages for each cartridge. If you a small amount of each color it is possible that you may have defective cartridges. As well, one bad cartridge can cause all the colors to not print. Yellow cartridges are bad for causing this. Have you recently changed cartridges in the printer? You may have gotten a bad one, it happens, especially if you are using refilled or 3rd party cartridges.
Jul 28, 2014 | HP LaserJet 3600dn Printer
HP 722C has quit printing black in color draft
WORKAROUND: Select EconoFast or Draft as the print quality setting in the printer properties. This will prevent the color cartridge from being used. - Or - Try another color cartridge. The color cartridge is used to print grayscale images in Normal or Best print modes, so if one color has run out, the printout will have the wrong tint. With a full color cartridge, the colors can be properly combined to create a composite black. CAUSE: When printing with Normal or Best as the print quality setting, the HP Deskjet 710C or 720C or 722C series printer will use the color ink to improve print quality output, even when printing a grayscale image.
Sep 07, 2007 | HP DeskJet 722c InkJet Printer
Copier stopped printing in color, at which time I installed a new color cartridge in an attempt to correct the problem. It continues to only prints in black and white.
Hi
Please go to printing preferences and uncheck the print quality greyscale quality. Then try to print again.
If not working, please let me know to help you more.Regards
Mar 03, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Mfc 5860 red printing green - already checked print levels. all are fine.
1. Confirm that the colors are incorrect by printing a Print Quality Check Sheet
a. Press INK.
b. Press the UP OR DOWN ARROW key to select Test Print.
c. Press OK.
d. Use the UP OR DOWN ARROW key to select Print Quality.
e. Press OK.
f. Press COLOR START
The machine will generate the Print Quality Check Sheet.
2. The LCD will ask "IS QUALITY OK? 1. YES 2. NO"
a. Press STOP/EXIT to return to the "Date and Time" display.
3. Evaluate the Print Quality Check Sheet.
On the Print Quality Check Sheet each of the four colors is represented by a slanted square pattern made up of 96 individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
NOTE: Cyan is the light blue color and magenta is the pinkish color.
a. If the colors on the Print Quality Check Sheet do not match the sequence listed above then the ink cartridges are most likely installed in the wrong order. Continue to STEP 4 to resolve this.
4. Open the Ink Refill cover.
5. Open the cartridge covers of the colors that do not appear in the correct order.
6. Remove the cartridges and reinstall them in the correct slots. On Brother Genuine Cartridges the color of the label will match the color of the cartridge cover.
7. Run a "Setup Purge". A Setup Purge is necessary to replace the ink in the ink supply tubes with the correct color. One or more of the ink cartridges may run empty during this process. If they do, replace the empty cartridge with a Brother Genuine Ink Cartridge before continuing the process.
a. Press MENU - BLACK START - MENU. The LCD will display Maintenance.
b. Press 7-6, The LCD will display CLEANING ALL
c. Press 6, the LCD will display eINIT__P ALL
d. Press the RIGHT ARROW key until one of the colors that was installed incorrectly is displayed. i.e. eINIT__P CYAN.
e. Press the BLACK START Key.
  • After the machine completes the Setup Purge it will return to the Standby Display.
8. Print another Print Quality Check Sheet
a. Press INK.
c. Press OK.
e. Press OK.
9. The machine will generate another Print Quality Check Sheet.
a. If all four colors printed correctly the issue is resolved.
b. If one or more of the colors are still not printing in the correct order repeat STEPS 4 - 8.
Feb 17, 2011 | Brother MFC-5860CN InkJet Printer
The printer suddenly started printing fuzzy text. I think it is out of alignment but when I try to print the alignment page, it comes out fuzzy too. Is there another way to align the printer and take care...
There are several reasons why the HP All-in-One may fail to align the cartridges. The most common reason is an ink cartridge that has one of the following problems:
  • One of the ink cartridges is low or out of ink. Black and all three colors must be available.
  • The paper has already been printed on or is colored paper.
  • Protective tape on a new ink cartridge has not been removed.
  • Contacts on the ink cartridge are not meeting the contacts in the carriage correctly.
  • Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
  • The ink cartridge is defective
raaj_k001@rediffmail.com
Jan 13, 2011 | HP PSC 1410 All-In-One InkJet Printer
I just installed a Canon mx300 on my Mac (runs 10.4.x) and all seemed to go well. I can print but the black letters don't print black (actually, the same happens if I have colored text mixed in). It's...
If the colors in your document don’t look right, you can change whether colors are managed by ColorSync or your printer.
To change color management options for printing:
Open the document you want to print.
Choose File > Print.
If the Print dialog contains only two pop-up menus and some buttons across the bottom, click the disclosure triangle beside the Printer pop-up menu.
Choose Color Matching from the print options pop-up menu.
Select one of the following options:
Select ColorSync if you want the application you’re using to control the color management of the printed output.
Select “In printer” if you want the printer you’re using to control the color management of the printed output.
If you select ColorSync and don’t believe the correct profile is selected for your printer, you may be able to change it. If you see a Profile pop-up menu, choose Other Profiles from the pop-up menu, and select a new one.
I hope this info will help to sort out your problem..Regards
Jan 08, 2010 | Canon MX300 Office All-In-One Printer
Colour printing lovely - black awful
call 1.800.421.6699 and select option 01 for prints missing black or color ink and tell them you need a new printhead
Jan 27, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Want to print with black ink cartridge only
It is a little known fact that ink cartridges do have an expiry date, and it is sometimes possible that even if a printer reads full, that it has dried out and will not print. When you recieve a warning that your ink is too low you will simply be unable to print black ink after a certain point. Generaly if you want to print in only black you will have to do that when you print a document. For instance in IE when you go to file and then print you can select prefrences and select print in greyscale or black. hope this helps!
Jan 24, 2009 | Dell 922 All-In-One InkJet Printer
Blurred and fuzzy print quality
i think you use a compatible ink... use genuine ink for epson ok...
Jan 04, 2008 | Epson Stylus Color 740 InkJet Printer
Printing in black "fuzzy"
have you replaced the ink art with a new one?
if you have time to replace the print head.
Dec 13, 2007 | Canon i860 InkJet Photo Printer
Canon PIXMA MP780 All-In-One InkJet Printer Logo
85 people viewed this question
old marine
old marine
