Question about Hotpoint HSS25GFP Side by Side Refrigerator
Icemaker The icemaker in my Hotpoint HSS25GFP Side by Side started slowly leaking water so I shut off the water source to it. I opened the line again to try to locate the exact source and water was pouring out of the iceholder. Any ideas of where to start troubleshooting? thanks!
  • 447 Answers
Yeah sounds like the inlet valve needs replacement.
Posted on Dec 13, 2007
Water dispenser is not shutting off
There are several valves and solenoids involved.
To stop the water, pull the fridge away from the wall and shut off the water source.
then you can troubleshoot the problem or have it looked at.
Sep 28, 2010 | Hotpoint HSS25GFP Side by Side...
Icemaker leaking water and frezzing ice into one large block
take the freezer panel off. unclog the hole where the water collects. its clogged
Feb 13, 2010 | Hotpoint HSS25GFP Side by Side...
I have a Hotpoint Refrigerator Model HSS25GFPH and the water dispenser won't work. The icemaker is still working. I have changed the filter and still no water. Any suggestions? Ben Kirkpatrick,...
My daughter's Hotpoint has the same problem (not sure of the exact model). Discovered that the water line inside the freezer door is freezing up. However, I don't know why and the dealer says they have no clue either. This may be your problem.
Jan 04, 2010 | Hotpoint HSS25GFP Side by Side...
I changed the water filter, but still have no water. I have ice.
water for the foutain is not the same water as for icemaker / you have a dual water valve . which is either bad on one side of the water line is frozen. frozen is most common . adjust tempt of fresh food. if you are freezing veg / then your freezing the water .. mm
Dec 19, 2009 | Hotpoint HSS25GFP Side by Side...
Ice maker does not work on my Hotpoint sise by side. the water dispenser works, i've replaced the filter, the green light is on, but nothing happens with the icemaker, no running water sound, no ice
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Jul 01, 2009 | Hotpoint HSS25GFP Side by Side...
Icemaker on Hotpoint Model HSS25GFPAWW Refrigerator not working
try turning the temperature for the freezer down a little bit. it has to at least be around 17 degrees before the older ice makers start to work.
Jan 20, 2009 | Hotpoint HSS25GFP Side by Side...
Water in the door does not work
I had the same problem. I found the answer on this forum.
The water line could be frozen in the door. Need to 'thaw' your door.
Copy paste link.
Dec 09, 2008 | Hotpoint HSS25GFP Side by Side...
Ice maker supply system leaking at back of freezer wall.
replace water valve and remove ice from tube leading to icemaker.
Jan 14, 2008 | Hotpoint HSS25GFP Side by Side...
Hotpoint HSS25GFP icemaker stopped working
are u sure that model # Is right.. DOnt come up in any of my model data bases Seems like u might of got a bad icemaker.. if the water is coming into the icemaker from the water valve.. icemaker has to have power, to do that... all funtions after that would be controled by the iceaker .. The only other thing i can think of is your refrigerator has to be a certain temp to activate icemaker somewhere around 0 give or take some to be safe
Aug 21, 2007 | Hotpoint HSS25GFP Side by Side...
Water leaking inside freezer ice maker
sounds like the line was frozen but the water fill indicator is faulty.
Jun 05, 2007 | Hotpoint HSS25GFP Side by Side...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
165 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
