Question about Hisense LCD1504 15 in. Television
ITE Power Supply
Black power supply box.I need to know where to get one at.
  • 259 Answers
First you need to know the Voltage of your monitor. Most likely 12V Then the Amps of your monitor. 2A, 3A, 4A, ECT...
This is the output voltage and ampage. This is important so the power supply can provide ample current for The cheapest place to find the is on Ebay!!!!
Check it out:
http://search.ebay.com/search/search.dll?sofocus=bs&sbrftog=1&catref=C12&from=R10&_trksid=m37&satitle=lcd+monitor+power&sacat=58058%26catref%3DC6&sargn=-1%26saslc%3D2&sadis=200&fpos=12601&sabfmts=1&ftrt=1&ftrv=1&saprclo=&saprchi=&fsop=1%26fsoo%3D1&coaction=compare&copagenum=1&coentrypage=search&fgtp=
Posted on Dec 13, 2007
  • Rafael Ortiz
    Rafael Ortiz Dec 13, 2007
    Correction:
    This is the output voltage and ampage. This is important so the power supply can provide ample current for the monitor.
    Check it out:
Where can you buy a model: u120320AB4 ITE power supply cord?
where can i found a ike power supply model mu122120100a1
Jan 04, 2012 | Kitchen Appliances - Others
I have a Westinghouse monitor Model # LCM-19v SL the monitor keep turning off. Unplugging then replugging gets it working then it shorts out again. Can I replace the power Supply cord - Potrans ITE Power...
i also have a 19" westinghouse monitor the screen on mine goes black i just turn the monitor of then back on the problem is it's overheating and from what i understand it's caused by faulty or worn capacitors the ones that are bad are vented on top so it's easy to tell the bad ones. you can see what they look like on line!
Nov 18, 2010 | Westinghouse LCM-19v1 Monitor
Cat chewed phone power supply for GE cordless phone. Its in two pieces and also gnawed in many other areas of the line. Looking for a power supply replacement Thomson Inc 5-2812 IW506 Input: 120v 60Hz 0.2A...
Get you some electrical tape and cut cord where it's chew off and splice wire ( match white and black wire with the same and ......match black and black ok,,,after that tightly wrap only matched pair one at a time ok
Dec 03, 2009 | Uniden Cordless Phone
E-machine will not power up even after replacing the power supply
If power does not come to hard disk, cd/dvd etc. then replace the mother board. And if you can put on the cpu and there is no display, then replace the RAM module.
Dec 17, 2008 | E-Machines eMachines Desktop PC
Same problem as bloodthinners post on Apr 20,2008
Yes the power supply akai supplied with the tv is kind of weak so it usualy gets warm because it has trouble keeping up with the energy demand which sometimes leads to tv failure because the tv keeps trying to draw more power and the power supply cant keep up so the tv may eventually quit worse case senario because it is trying so hard to draw more power which causes it to fry the tvs circut board out mine does the same thing it is normal. i just went and bought a aftermarket bigger power supply and the tv works better and the black box stays cooler all you need to do is bring you power supply to radio shack and they will see what you need. Hope this helps
Jun 04, 2008 | Akai LCT2070 20 in. EDTV-Ready LCD...
No power
Hate to say it. But down at my shop, we have repaired a good 200+ eMachines in the last two years... all with the same ailments.
Usually what we find, is a bad power supply. That's only the first part.... in most cases the mainboard is damaged as well and needs to be replaced.
If you look at your power supply, it is probably a Bestec brand. While you have the cover off, look over the mainboard with a flashlight. You may find a blown ITE chip, or even some hot spots or small burn spots on the southbridge chip. Which is located usually towards the bottom right side of the board if your point of view is with the computer sitting upright. It will be about one inch square in size.
If you have a space power supply, or know someone with one, you can try that. We've not had much luck replacing just the power supply. In a few rare cases it solved the problem. But in most, a motherboard replacement was in order as well.
Best we can figure, the power supply fails and takes the mainboard with it. The only commonality among each one, was the Bestec power supply. Since some of these were Intel based and some were AMD based.
Oct 30, 2007 | E-Machines -T1840-CELERON-1.8GHz,40GB...
Hisense LCD1504 15 in. Television Logo
120 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
