Question about LaCie Electron 22" CRT Monitor
Monitor into TV
Hi, Can you help? I have a redundant |Goodmans GV400 LCD monitor I thought I'd try turning into a Tv for my daughter. Bought a TV box, TV sound plays through the monitor but the message Sync over range comes up instead of picture, and I don't know how to reset refresh. monitor is on OxO, 75 Hz s
  • dunkz2006 Mar 09, 2009
    did you manage to sort this i want to try and use a freeview box in my goodmans gv400 too thanks
  • 33 Answers
The monitor may not be compatible with your TV box. Basically if the monitor can't handle the refresh rate or resolution a blank screen like this will result. There should be a way to change the refresh rate or a standard refresh rate listed in the manual. What brand/,model of tv box is it?
Posted on Dec 13, 2007
  • 348 Answers
TV box may faulty replace it compaint it to vender
Posted on Nov 28, 2008
Panasonic viera 50px80u tv will turn on but no picture. HELP?!?!
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
Hi Josh,
Your TV is 7 years old, so it is not worth spending a lot of money fixing. You could take it to a shop for an estimate.
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 04, 2015 | Panasonic Viera TH-50PX80U Plasma TV
Does anyone know if I can use a Goodmans TFT LCD TV, Model: GTVL19W19HD as a computer monitor? It has a VGA socket on the back, but when I connected a computer It wouldn't show.
Yes,
You will need to select the VGA or PC input on the TV and then boot the PC up with the monitor attached so the video card will see it correctly.
Nov 07, 2012 | Goodmans GTVL19W17HDF 19 in. LCD TV
How to connect television cable and samsung sync 2233
Samsung SyncMaster 2233BW does not support TV / Cable input (RF Connector).
If you wish to connect Cable to the LCD, you have to buy a TV Box and connect Cable with your LCD through TV Box. (Cable TV to TV BOX and from TV BOX to LCD)
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 09, 2011 | Samsung SyncMaster 2233BW 22" LCD Monitor
I GOT THIS MONITOR/TV FROM DAUGHTER, I DON'T HAVE MANUAL. HOW DO I HOOK IT TO MY COMPUTER TO USE AS MONITOR. WHAT CABLES AND WHAT PORTS? THANK YOU
Tries Element website itself if ur LCD tv model still in the market u can download manual for free not look for their phone number like 1-800..call them pay them a fee they'll send out a copy of the manual to u.U have a LCD monitor now hook up to ur computer right now to used as a monitor now wright?Yes.Take that VGA cable out from ur computer and ur old LCD monitor VGA cable out of the VGA ports just take ur hand and unscrew the VGA cable.Used ur old LCD monitor VGA cable and hook up to the LCD tv VGA port and to ur computer VGA computer graphic card port or computer monitor port hook up the other end.Turn on ur Computer and tv on used the sides button of the tv find one that said INPUT push it a few times should find ur tv mode 1,2.3 ur computer is on as a monitor.
Aug 19, 2011 | Element Electronics FLX3210 32 in. LCD TV
Hi there, i was just wondering that, my hdmi monitor which is goodmans GTVL19W17HD monitor and it has a HDMI slot, but my graphics card doesnt, instead my graphics card has a vga and dvi slot, and if i...
Hi hassy786,
Regarding your question if you will use a converter from VGA to HDMI will it provid High Defenition video?
I believe that it will provdie video converting the signal from VGA to an HDMI connection but I do not think that the video will be High Definition since the VGA is just being converted to HDMI signal and not an actual HDMI but just a converted signal, and it is possible that it may not work properly or the LCD TV may have difficulties recognizing the signal from VGA converted to HDMI.
Thanks for chosing Fixya,
avf110686
Mar 27, 2011 | Goodmans GTVL19W17HDF 19 in. LCD TV
Says no tv input
make sure your antenna is effective or you can use dvd or video to test it.you can use your system to test it as a monitor.if all this fail to work, change your analog to digital conversion board
Aug 23, 2008 | Goodmans W280NS Television
No RGA input detected
through the Remote .. press menu .. and make sure that the VGA output is one that the Monitor can handle (if LCD 1280x1024) ... lower the refrech rate or definition until the monitor 'sinc's
Sep 26, 2007 | V-Stream Xpert 1280x1024 LCD TV Box...
Use my lcd monitor as TV
I would suggest getting a pc tv tuner card. http://www.newegg.com/Product/Product.aspx?Item=N82E16814122221 Then you connect your cable wire from the cable box into the pc and watch it that way.
Aug 01, 2007 | ViewSonic VX922 19" Monitor Flat Panel
Open Questions:
LaCie Electron 22" CRT Monitor Logo
181 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Marvin
Marvin
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
