Question about Conair GS5 Iron
How do i put water into my upright conair steamer
I'm
  • 2 more comments
  • PinkyJanet Dec 18, 2007
    How do I refill my Con Air Compact Fabric Steamer Model GS4?
    Please advise
    Janet.Mandarino@dkib.com
  • deahart Jan 22, 2008
    can't put water in mine either
  • Anonymous Sep 28, 2008
    i can't get the thing open. i can't believe it is so difficult. i feel like i'm trying to open the hatch on the tv show lost.
  • GARealtor Jan 23, 2009
    CANNOT get that darn hose off in order to refill.
Conair steamer green light comes on but low water beeps. water full.
How To Use The Conair® Deluxe Fabric Steamer
www.conair.com/how-to-use-the-conair-reg-deluxe-f...
Conair CorporationThe Conair® Deluxe Fabric Steamer (model # GS11DR) conveniently rolls to any spot in your ... This unit comes with a rotating hanger. ... The switch will light to indicate when power is on. ... Note: If the low water indicator lamp becomes illuminated but the water tank is not empty, follow the instructions for decalcification.
[PDF]Instruction Booklet - ExtremeSteam® Upright ... - Conair
www.conair.com/.../gs95_13pa140688_ib_final.pdf
Conair CorporationMar 1, 2013 - ... water only. 8. Plug the steamer unit into a standard 120V AC power outlet. 9. ... Push button on T-nozzle - light will go on and steam will start.
Customer Reviews: Conair Extreme Steam Fabric Steamer ...
Aug 16, 2013 | Irons
Conair GS33 fabric steamer spews too much water..can't be normal, eh?
Are you setting the body of the steamer on a table? If part of the hose sits lower than the steamer body steam will condense in the hose and collect in the low spot. Steam pressure will push the water out through the nozzle. If your steamer starts to sputter lift the hose so that it is completely above the level of the water reservoir and let the water drain down. Its a good idea to keep the steamer body on the floor so the hose can never get lower than it.
Feb 03, 2010 | Conair Irons
CGS11DR CONAIR GARMENT STEAMER
Have you checked the float?
Sometimes that gets stuck, or collects mineral and stays in the last position.
Matt
Sep 14, 2009 | Conair Compact Garment Steamer Iron
How do you fill the water tank on the steamer conair model GS15RN?
FOR HOUSEHOLD USE ONLY
FILLING INSTRUCTIONS
1. Place the unit on a stable surface.
2. While holding the water tank with one
hand, move the release lever toward the
power cord.
3. With the reservoir released, pull up on
the reservoir to remove it from the body of
the unit.
4. Turn the reservoir over, revealing the rubber
inlet cover.
5. Open the inlet cover and fill the tank
with everyday tap water (filtered water may
reduce hard water problems).
6. Close the inlet cover and return the
reservoir to its place, making sure that the
reservoir is secure.
Hope this helps! Hal
Jun 04, 2009 | Conair Compact Garment Steamer Iron
Conair steamer leaks water and wets my clothes.
When I use mine I hang the hand held part from my closet door, while I am waiting for it to heat up. When the hose gets too much condensation, from the steam, it leaks out... This will also happen if you try to use in the motion of an iron. The hand held part needs to be at a vertical position at all time to prevent leaking.
Jan 24, 2009 | Conair Compact Garment Steamer Iron
I have lost my operating instructions, I have a Conair G3 compact garment steamer and want to use it, how do I start. Thank you for your help.
Check out a video manual on Conair Fabric Steamer
at http://www.handbooklive.com/
Click on Appliances category. The video instructions are for GS4 model but it must be similar.
Hope that helps
Sep 03, 2008 | Conair Compact Garment Steamer Iron
Conair steamer
Fill it with boiling hot mixture of half water half vinegar. Let it sit two hours. Rinse and repeat as necessary. Hope this helps you out.
George
Jul 03, 2008 | Conair Compact Garment Steamer Iron
Conair GS4 Steamer
faa3e02.jpgthis is from conair instructions included with steamer, finally found it, hope it helps some!
Oct 28, 2007 | Conair Gs4 Iron
Conair GS5 Iron Logo
822 people viewed this question
Top Conair Irons Experts
Glenn Smart
Glenn Smart
bigdaddyd2
ray gallant
Are you a Conair Iron Expert? Answer questions, earn points and help others
