Question about MSI 865GVM3-V Motherboard
No power when i power it on no thing happen except that cpu fan tries to move then stop and the power supply stop too thank u for reading my proplem afud@yahoo.com
  • afud Dec 14, 2007
    it worked from two days.it sensed when i removd the ram stick once then it never repeat it till now
  • 36 Answers
If you have no short causing this you probably have a fried motherboard. When was the last time it was working?
Posted on Dec 12, 2007
Plug power cord in to computer, power supply starts up system fan and cpu fan starts and runs no other indication that the computer is booting up. this happens with all cobles diconnected, even the frount...
Try swapping out the RAM first since it's easier then changing out the CPU. If that doesn't work, then the probably most likely lies with the CPU.
Regards,
Matt
Mar 30, 2011 | HP Computers & Internet
My gateway computer do not turn on.the fan try to start and stop.what should be happenning?
I think that the CPU fan isn't working as it should and the CPU is overheating quickly. If the CPU is heating too fast, the mainboard is automaticly shutting down the all PC to prevent damage. Your thermal paste might be gone. Isn't the computer giving any sounds or LED flashes ?
Nov 02, 2010 | Gateway 830GM power supply **FREE **...
I have HP 305W. When turns on the power, it stops within 5 scnds
sounds like your motherboard lost a control chip. that makes the power supply cycle off, when m/b doesn't send correct signals to continue boot.
Nov 27, 2009 | HP Computers & Internet
The small fan does not want to run, it runs for a few seconds and stops, my computer keeps rebooting
when the fan stops 2 things are happening 1 the bios sences no rpm speed from the fan or the processor heats up to quickly and the safety in the bios will shut it down. try moving the fan connector to the case fan connector then go into the bios and change the fan settings. this is only a temp fix the fan stopping tells me that the onboard cpu fan regulator is going out and this is a precurser to more problems to the board going out. also just to be certin check the power supply 4 years ago i came across this in a gateway it was weird.
Jun 29, 2009 | Iwill KK400 Motherboard
Computer does not turn on
Check the switch of the power supply at the back (black button) First
If the power supply fan doesn't work or cpu fan doesn't work
Replace the power supply.
Thank you for using FIXYA
Please don't forget to rate my help
Have a great day!
Pablo :-)
Oct 16, 2008 | Computers & Internet
Singlle long beep on booting up my Biostar M7NCDPro motherboard with nothing on screen
If you get one continuous beep (Long and Non-Stop)
This could happen if:
1. The Power supply is damaged or bad.
2. The BIOS is corrupted. Try resetting the CMOS using JCMOS1 jumper on the motherboard or remove the battery from the motherboard for 20 minutes. At this point the first thing to try is a different Power Supply to see if the result is better. If the same problem happens with the new power supply, you may need to send the BIOS Chip to local dealer for reprogramming.
If you get one long High Pitched tone that does not stop until you disconnect the power supply:
1. Check if the CPU fan is connected to the JCFAN1 connector.
2. The CPU might be overheated. Change the CPU FAN or check if the CPU fan has proper contact with the CPU. Refer to your manual for CPU installation.
3. Clear CMOS battery (JCMOS1), be sure to set JCMOS1 back to 1-2 position. (See Quick start guide/ user manual for more info on how to clear the CMOS)
4. Make sure the power supply you have on your system supports the M/B specification. Example. If you have a P4 M/B, you need to use an ATX v2.03 specification power supply. (power supply that has an extra 4-pin square connector)
Sep 15, 2008 | Computers & Internet
Power not on
  • First if you have move the computer recently, check that nothing has moved inside box and unplug cards if any including memery and replace again.
  • Check switch if working, does it turn on if you hold button? If so New switch required.
  • Most common problem: Power supply might be blown, see if the fan is running in the back of box when you start-up. Otherwise you will need to check a few things before you replace with new one. Check that the CPU fan inside box is running. Check that there isn't dust build up on fan stopping from running. Might need replacing. Try also taking out battery and starting up computer. If all else fails you will need to replace power supply with a 500watt or more power supply. If you have another computer on hand, you could try the power supply from that system as look as it has same connectors and try and run with that. If works then you know what to do. If nothing, the motherboard might be gone, or cpu even. Try also taking memory out and replacing. see if runs.
  • Before you give up, unplug all cables to hard drive, cd roms and DVD-rom and try to turn on
Aug 03, 2008 | Acer Veriton 7600GT PC Desktop
Emachine T2742 - Will not power on
Check the ram and make sure is securly in it's place.. Unplug everything else from the mobo except power and fan/cpu and power button..
Do the fans come on?
Mar 26, 2008 | E-Machines eMachines Desktop PC
No respons at all !
I think your power supply cables is not able to start your B-board if your power supply is working properly then check mother board jack where you insert your power supply plug in M-board. Then you have to change or repair that jack where you insert power supply wire in M-board. With best regards M. Khalid Shaikh from Pakistan Mobile: +92-332-2631983
Sep 19, 2006 | Intel Desktop Board D845BGSE Motherboard
MSI 865GVM3-V Motherboard Logo
114 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
