Question about HP Photosmart C6180 All-In-One InkJet Printer
Printing envelopes When I try to print 6" x 9" envelopes from Print shop deluxe, a message appears saying it's the wrong type of paper.
I have the same problem I am running vista on a 64 bit computer.
Tried everything
tom
Posted on Jan 05, 2008
    Sergeant:
  • 239 Answers
You may have to go into the printer properties and change the size in the paper size drop down list, Your printer thinks that you are trying to print the envelopes on standard size sheet of paper, if you change that to the 6x9 in the printer properties it should work for you now, If it don't just write back here and we will try something else. Happy Holidays
Posted on Dec 15, 2007
Print Shop 23.1 printing problem
Does that happen only with Print Shop, or any way you try to print, please?
Are you really a message with the exact wording (to) keep printing or what?
Are you really seeing a message with the exact wording (to) turn off envelope printing size of printer and use reg. paper size or what?
Nov 29, 2017 | Computers & Internet
Printing envelopes
HI,
Try this one.Make sure the HP paper size setting needs to be "plain paper," not "automatic.
Aug 17, 2008 | HP Photosmart 3210 All-In-One InkJet...
Hp j6480 printer wont print keeps sending a paper mismatch message
Paper mismatch errors occur because the product scans the width of the envelope before printing. If the paper size setting in the printer driver does not match the paper actually loaded in the product, the product reports a 'Paper Mismatch' error. The message saves paper and ink by preventing print jobs from accidentally printing on the wrong paper. For example, the print job might be for a 101.6 x 152.4 mm (4 x 6 inch) photo, but there is letter-size paper loaded in the product. The error message displays to make sure that ink is not wasted on the wrong paper type. try this out , disable the automatic paper type sensor.
  1. Open the Print dialog box.
    1. In Word 2003, click File , and then click Print
    2. In Word 2007, click the Office button (c01850900.gif ), and then click Print .
  2. Make sure that your product is in the Name drop-down list box, and then clickProperties .
  3. Click the Features or Paper/Quality tab.
  4. In the Paper type drop-down list, click Plain paper .
  5. Click OK to close the Properties dialog box.
  6. Click OK again to print the current print job.
Feb 24, 2011 | Digital Products Hewlett Packard OfficeJet...
Need help printing customized size envelopes
you need to set the preferences in the 'Page Setup" to print envelopes
try this
good luck
Apr 29, 2010 | HP Photosmart C4180 All-In-One InkJet...
Trouble printing envelopes on kodak esp3 printer
Have you tried this procedure?
Loading Envelopes
You can load plain envelopes into the paper tray of your Kodak ESP 3 All-in-One printer.
Important Do not use envelopes with cutouts or cellophane windows.
1 Remove any other paper from the paper tray.
2 Insert one or more envelopes into the right side of the paper tray with the print side down and
the envelope flaps on the right, pointing left.
3 Squeeze the paper-width guide and move it to its right-most position up against the envelopes.
4 Leave the paper tray open while the envelopes are loaded.
If you have and it's not printing correctly, there is probably a problem with the document you're trying to print.
Jan 16, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printing envelopes
did you put these envelopes right way (portrait/landscape) also you have to change in printer menu paper source paper type from plain paper to envelope.
Mar 24, 2008 | Konica Minolta magicolor 5430 DL Laser...
PIXMA 830 Smudges when printing envelopes
On my MP780, be careful to select the appropriate paper type; I was getting black smudges on the left side of my envelopes until I explicitly set that my paper type was "envelope" from "plain paper".
Another idea is to adjust the "ink drying wait time" to a higher level.
Dec 09, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Printer Error When Printing Envelopes
I had the same problem with my 7260 and I finally changed the paper type from automatic to plain paper. Go to either Properties or Preferences in your printer set up window. Somehow this turns off some sort of sensor. It might work for you, too. To the person who is using the Hallmark program, that is where I first encountered the problem, I then tried to print an envelope from Word and the same error message came up. I found this solution online from someone using a three in one printer/fax/copier so I tried it and it worked for me, too! I hope this helps......
Nov 04, 2007 | HP Photosmart 8250 InkJet Printer
Hp psc 2410 photosmart
marglet, Turn-off and unplug the printer for a couple of minutes...there may be improper setting stuck in the printer memory. then plug it in and try to print the envelopes..if that doesn't work...Make sure there aren't any custom print settings causing this. Lastly...Try updating the drivers. Download the latest drivers from the site. http://www.shopping.hp.com/webapp/shopping/search/search_request.do?pageName=HP+printers_land Good Luck, Tim
Feb 03, 2007 | HP PSC 2410 All-In-One InkJet Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
253 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
