Question about Sony KDS-R50XBR1 50" HDTV
TV will not power on 4 red blinks
We have had several problems with our KDS-R50XRV1 and I am looking for some new advice. We purchased the TV in Dec of '05 and did not have any problems until last month. The TV would turn on for a brief second and then turn off then the light would go to red and blink 4 times. We read all of the posts on the optical block and so we called and had it replaced. At the same time we also purchased a new bulb but found that the yellow problem went away and the TV powered on fine so we did not change the bulb.
The next day it had the same 4 red blinking lights. We read some other posts about the fans. We took the back cover off and used canned air and cleaned out the fans. Again the TV worked for a day or two and then back to the red lights (4).
We have since made sure that it was connected directly to the wall outlet and also changed the bulb that we purchased when we had the optical block replaced. It will turn on some times and then others it will turn on for a second then off with the 4 red blinks. Once it gets in this state we have to either unplug it for a while or remove the lamp and put it back in.
I am getting so frustrated. I cannot believe that a TV that was so expensive is such a hunk of junk. Any other ideas?
  • WillHolder Mar 16, 2008
    I have a Sony Grand Wega Model KDS-R50XBR1, purchased in Dec 2005. I've also had the optical block replaced and a lamp. My tv started doing the same thing. I took the back cover off and cleaned everything up manually spinned the fans. Turned the tv on and it worked fine for "45 minutes" now its back to the 4 flashing red lights. I believe the tv is overheating? I noticed there is more than one fan also? Does anyone have any advice for this problem?????
  • 23 Answers
Disregard "Guests" comments, he had a light blinking 3 times, which is a lamp/lamp door issue...
Chances are the large fan on the rear needs to be replaced.
Posted on Oct 01, 2008
  • FIXRUPPR Oct 01, 2008
    This is a fan issue, most likely the large fan in the rear, lower left (from the back)...
    Here's the fix, I promise, it's EASY........
    Ok, I think I have the answer for the BIG FAN failure. I recently did a
    similar fix on the spindle of an xbox 360 and it is identical. Ok, this
    is an EXTREMELY EASY FIX...
    Open the back of the tv, locate the large fan (on the lower left on the back of the set.) unscrew the screen and remove the fan.
    Once the fan is removed, you will see the side with the model number and the other side is totally open.
    On the open side, pull...
    The fan will come off, into your hand, it is only held by magnets...
    You will notice a spindle on the fan and the other side has the magnets
    and the hole where the spindle came from (this is the fan motor).
    Clean both the spindle and the hole (motor) with a q-tip. The hole is
    smaller than the q-tip, but do the best you can to remove the old
    lubricant.
    Get a bit of WD40 and lubricate the spindle and spray a touch in the hole.
    Put them together, reconnect your fan, test it on startup and thank me...lol...
    HOPE THIS HELPS!!!! IT WORKS, TRUST ME...
I have the same problem with this tv. the only solution was pounding repeatedly to the right of the power button. There is a sensor underneath this spot and it is indicating that this panel is open. After 2 years of radomly having this problem, I opened up the panel and rigged the button, and I have not had the problem since
Posted on Mar 20, 2008
I found the following suggestion on avsforum.com and it worked perfectly (going through the lamp door).
Nate
Quote: Originally Posted by Civicsixxx After some digging around I found that four blinks means there's a problem with a fan. I took the back cover off, used a screw driver to manually spin the fan near the lamp a few revolutions, plugged it back in and it powered right up! I guess it was just stuck or something. I'm a longtime lurker not much of a poster, but this happened to me to yesterday. I used civicsixxx's advice and this works. However you don't have to take anything apart. All I did was take out the lamp then put your hand in carefully to the right and you'l feel the fan just give it a spin and plug back in the light and the TV your good to go. Hope this helps.
Posted on Jan 03, 2008
Sony KDS-R50XBR1 /(2005) Red stand-by light blinks 4 times.Tried new bulb (Philips) 1 week ago ,same problem as before .Whole new light engine replaced two yrs ago by sony.What happens is it will turn off...
The error code of 4 blinks indicate a fan problem.the fan is slowing or internitantly stoping. the fan is stallling. or the fans not getting power. Always rember anything that moves will eventally stop. this fan is on all the time. also there more than one fan. Listen closely to hear the fan. The fan is not difficult or exspensive repair.
Mar 04, 2011 | Sony KDS-R50XBR1 50" HDTV
New lamp is placed in tv, but tv won't come on. Light in front of power button is blinking green, then blinks red. Not sure what the problem is
One question, why you decided to replace lamp in tv? Did tv showed red lamp light blinking?
Suggestion, make sure lamp cover has been placed back in its position after lamp replacement, lamp cover is first thing that you removed from tv cabinet to take out lamp.
Oct 05, 2010 | Sony XL-5100 Projector Lamp for Grand WEGA...
Sony SXRD KDS-50A2000 Will not power on. Green
I have the same problem with my unit. I've been removing the bulb and just replace it back and unit will work again. I probably need to vacuum or check the fan out too.
Mar 09, 2010 | Sony KDS-50A2000 50" HDTV
Power light flashed red 4 times then repeats no pic,new bulb/fan!
Check the fan that cools the bulb. It is directly behing the bulb. It should turn on when the power comes on. It apparently has a safety to protect your tv(and home). mine is in the process of going out. looking for online solutions as we speak.
Jul 19, 2009 | Sony KDS-R50XBR1 50" HDTV
Red Light Blinks 4 straight imes
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. The 4 red blinks is similar to an error code. It represents what's wrong with the TV to a service tech who knows how to repair it. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need a power supply module. If the problem is one of the video circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Jun 18, 2009 | Sony KDS-R50XBR1 50" HDTV
After a power failure I have 4 red blinks and tv
The fan has stopped most likey a problem with the AGU board
Jun 17, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Kds-50a2020 sony tv will not turn on
You may have luck in reading the blink code to find your problem at this link.
http://www.agoraquest.com/viewtopic.php?forum=70&topic=31721
Mike
Mar 22, 2009 | Sony KDS-50A2020 Television
KDS-R50XBR1 5 red blinks
If you are positive that the fan is still running and that it isn't an over heating issue, I would venture to say you need a new dlp lamp. Your model uses a Sony XL 5100 dlp lamp. You can grab one over at DLPLamps.com.
Feb 15, 2009 | Sony KDS-R50XBR1 50" HDTV
My tv sony kds-50a2000 dont tur ON
I have a Sony KDS-50A2000 50 in. HDTV Television. I just replace the lamp because I got the message that appeared on the TV. Lamp needs to be repaced. I replace with a Sony lamp and now TV cut off after 2 to 3 hours off watching the TV. Any Idea what is going on with this TV
Jan 02, 2009 | Sony KDS-50A2000 50" HDTV
KDS-R60XBR1 60" SXRD HDTV
I had the same problem if it is blinking 4 times like I think it is... it is a problem with one of the fans (there are 4) in your TV.. It is a simple fix... try using an air canister to clean them. It will require some disassembly though.
Sep 12, 2007 | Sony KDS-R60XBR1 60" Projection HDTV
Sony KDS-R50XBR1 50" HDTV Logo
197 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
