Question about Refrigerators
Icemaker How do I adjust the size of the ice cubes.
  • 1 more comment
  • Joyce600 Dec 13, 2007
    It must be on with glue. I am afraid to force it. the model is GE side by side, circa year 2000.
  • Joyce600 Dec 18, 2007
    I wish someone would tell me how to get the cover off the icemaker (GE side by side).
  • Anonymous Dec 19, 2008
    don't see an adjustment screw on an older ge side by side
  • 126 Answers
Need to know what icemaker try popping front cover off. there should be an adjusting screw there
Posted on Dec 13, 2007
My PT Model IM-600 US ice maker makes cubes but continues to freeze on the ouside of the cube tray blo th cubes from falling into the bucketwhat is wrong.
cubes set too large
Adjusting the Ice Cube Size: 1. Press and hold the "Adjust" button for approximately 3 seconds until the Green Indicator starts blinking, release the button. The unit is now in Ice Adjustment mode. 2a. Press the "CLEAN" button to decrease ice cube size. The Red Indicator will flash as you lower in size and will blink when you have reached the smallest possible setting. 2b. Press the "MODE" button to increase ice cube size. The Yellow Indicator will flash as you increase the size and will blink when you reached the largest possible setting. After 10 seconds without any operation, the unit will return to the previous mode. NOTE: • During the ice adjustment mode, if the "ICE FULL", "ICE MAKING" and "ICE HARVEST" LED's all blink simultaneously, this means setting is at the regular (middle) size. • When the machine is in the cleaning stage or ice full stage, the ice size cannot be adjusted.
Dec 04, 2017 | Refrigerators
Is there a water flow adjustment?
Yes. On most refrigerator ice makers by the front panel on the right hand side there is a small screw adjuster that controls the amount of time that the water solenoid closes to admit water in. Adjusting it changes the size of the ice cubes from small to large or vice versa.
Aug 29, 2015 | General Electric Icemaker Ice Maker...
Our ice machine does not make full ice cubes. they are small and not complete, they are full of holes.
The icemaker requires a water pressure of 1.5 - 8.5kgf/cm2. It is acceptable if the water supply fills a cup of 180cc with water in 3 seconds. The icemaker produces small cubes if the water fed into it is not enough and lumped together if too much water is supplied. In order to obtain the desired size of ice cubes, the amount of water supplied to the ice maker needs to be adjusted. Adjust the valve supplying water to the icemaker or the unit in general in such a way that right amount of water fills the ice tray.
Nov 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
How do you change the ice cube size on this model? I cannot locate the ice cube size button anywhere!?
Hello there
Normally
You can't change the shape. or the size of the ice that is produced s It's determined by the manufacturer of the ice maker. but if you have the adjustment feature on your icemaker than pull the front cover off of the icemaker ande their will be a round adjustment wheel with different letters along the side these represent the different sizes of the ice that can be produced
their should also be a diagram on the inside ov the cover that you just took off that will help explain the different settings ok
I hope that this is very helpfull for you.
Best regards Michael
Nov 05, 2009 | LG Refrigerators
How do you change the ice cube setting on the 25cf LG French Door bottom freezer? I cannot see anywere in the manual where it indicates where you change this setting?!
Nov 05, 2009 | LG LFX25960 Bottom Freezer French Door...
My ice maker is letting too much water go into the ice tray so it freezes in a solid piece. Cubes do fall down but there is so much water it freezes into a solid block
Oct 30, 2009 | Sub-Zero Bottom Freezer Refrigerator
Cube size adjustment location on lg refrigerator
Oct 29, 2009 | ASUS Eee PC 900 Notebook
My GE Profile refrig ice maker makes hollow ice cubes. Why would this happen?
Not enough water is being pumped into the icemaker. The water pressure in the water line coming into the refrigerator may be too low, perhaps due to a blockage somewhere.
Move the refrigerator enough to get behind it. Turn off the water at the small valve which connects the water line from the house plumbing to the tube going into the refrigerator. Get a bucket. Remove the refrigerator water line from the on-off valve (there should be a compresson nut holding it on). Point the incoming water line into the bucket and open the valve. Do you have a good flow of water? If so, either there is a blockage in the tubing within the refrigerator or the water valve at the bottom of the back of the refrigerator is malfunctioning.
Oct 12, 2009 | KitchenAid Superba Architect KSCS25INSS...
U-line water level too full
If you have a icemaker then remove the cover. You will see a screw with a spring around it. Turn that clockwise like your tightening it this will reduce the size of the cube. Also make sure it is leveled. And make sure no corrosion is around the gears on that same plate. This could make the motor run slower and more water comes into it.
Jun 27, 2009 | U-Line Icemaker
Ice Maker problem
remove the cover on the frount of the icemaker and on the right side of the module there is a little and i mean little white adjusting screw, turn it clockwise 1/2 half of a turn clockwise and this is what adjusts the fill time of the ice maker, you may need to adjest back and forth to get the desired size of cubes but do not go more that one complet turn of the screw to get the size
if you can not get it by doing this then the frount module will ned to be replaced
Apr 19, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Refrigerators Logo
177 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
