Question about ASUS M2N32-SLI Deluxe/Wireless Edition ATX Motherboard (1254095)
Asus m2n32 deluxe sli motherboard lock up
Hi, I have a newer system that I build early this fall. It is freezing up and then when it reboots it gives me one long beep and two short. I call Asus and they said to check the ram in the b1 slot. Well I have crucial memory and it is 800. I tested the one stick in the different slots and it would not post just the long and two short beeps so i put the other stick in and it works. I`m getting ready to send it back for another but It just started doing it with the other stick. Could this be a videocard isssue instead? Is there a way to run a test to see if it is ram or something else. I`m still new to this stuff and need some help. i have a ati x850xt viedocard.
  • poppinfresh Dec 13, 2007
    Just to clear up the memory type it is crucial ballistix 1 gig sticks and i have a pair for a total of 2 gigs. they are ddr2 800 series. the voltage for them from the factory is 2.2 volts which is where they are set at. also my board is the 590 sli m2n32 deluxe. Thanks for the help and let me know if you have any other suggestions. It is greatly apperciated. Is there a mem test i can do to see if I have aproblem?
  • wizrb Jan 03, 2008
    Wow, I have the same exact problem. m2n32 sli deluxe and 2 1gb modules of Crucial Ballistix. I was running the system beautifully for 3 weeks then one morning I powered on and 2 quick beeps followed by a steady stream of regular beeps. I'm guessing it's the memory since I hear that this beep code is a memory problem. Crucial says these sticks work with this mb, but I'm at a loss.
    Problem Solver:
  • 17 Answers
Since you have a M2N board i think the issue is with the memory. I recall seeing loads of forums where people have issues with this board due t the fact that its unable to give sufficient power for DDR 800 memory to run fine specially if the machine is overclocked. I think a lot of people had success running DDR2 800 memory which worked on 1.8V but not any that needed any high voltages such as 2.0 or 2.1+.
Since you dont mention the memory type its hard to give a solid answer, but the solutions for this has been to flash your board with the latest bios, and also increase the voltage for the RAM to say 2.0V (Be warned this could damage your RAM unit, so try it at your own risk)
Posted on Dec 13, 2007
PC Freezes During Boot and at the BIOS Screen, EVGA P55 Classified 200
Beep Code Descriptions
1 short beep Normal POST - system is ok
2 short beeps POST Error - error code shown on screen
No beep Power supply or system board problem
Continuous beep Power supply, system board, or keyboard problem
Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Enhanced Graphics Adapter (EGA)
3 long beeps 3270 keyboard card
Aug 30, 2012 | Evga P55 Classified 200 (160LFE659KR)...
My hp-compaq dx2300 microtower restarts automatically when working. It is installed on win xp sp3. Please let anyone help if solution is known.
Hi names Rui, i question for you does your PC give a beeping sound when you turn it on? if does can you tell me how many beeps it gives?
if it give a designated number of beeps this might be the problem i will give you a chart so you can differentiate the warning beeps you hear.
warning beeps:
1 Short Beep DRAM refresh failure
2 Short Beep Parity circuit failure
3 Short Beep Base 64k RAM failure
4 Short Beep System time failure
5 Short Beep Process failure
6 Short Beep keyboard control gate A20 failure
7 Short Beep Virtual mode exeption failure
8 Short Beep Display memory read/write test failure
9 Short Beep ROM BIOS checksum failure
10 Short Beep CMOS shutdown read/write error
11 Short Beep Cache memory error
1 long, 3 short Beep Conventional/Extended memory failure
1 long, 8 short beep Display/Retrace test failed
hope this will determine the problem if none of this warning beep is heard try reseting the power botton in you PC cause sometimes the power botton will loosen cause of continuous use of the botton.
hope this will help you.
Jul 20, 2011 | HP Compaq dx2300 Microtower - RT950UTABA...
Hp pavilion 2000 not displaying anything but err one long beep and two short beeps
Hi taiwojoke,
Usually this would be because of the issue with the Memory (RAM) on the computer. I would sincerely suggest you to reseat the memory cards on your computer once. If you are aware of doing it then give it a try., otherwise its advisable to take it to a computer doctor :) (technician). Hope to see your issue resolved as early as possible.
Cheers!!!
Sep 14, 2010 | Computers & Internet
Winwos doesn load freezes
how many beeps... what kind of pc? below is the standard beeps codes with the the issue.
Standard Original IBM POST Error Codes 1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Jun 18, 2010 | Western Digital My Book Home Edition 500...
It does not start, gives one long beep (about 2-3 seconds) silence and beep again
Switching DDR cards solved the problem. I was getting long beeps every 2 seconds. No short beeps. Just one long beep every 2 seconds. Thanks Josh Whitehead.
Apr 23, 2009 | Computers & Internet
Hi i have a asus P4s533-mx and with a 3GHZ processor and with a geforce6600 (agp) and the games tend to freeze and i have to reboot my system?. any help please
It is the video card. Newer games are so graphic intensive that they freeze up the system if there is not enough video memory. You could try upgrading RAM but I had a problem running newer games until I installed a graphic card that had at least 512 mb video ram onboard. Hope this helps.
Jan 10, 2009 | ASUS P4S533-MX MB, DDR+SDR/ VGA/ Audio/...
Black screen with error codes
I think the msg you are seeing is just the default monitor message when there is no video to display. Here is a list of common beep codes: Are you getting the one long beep at each restart?
Beep Code: Description of Problem: No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
Dec 16, 2008 | Computers & Internet
Dell dimension E310 crash
  • Bad video card - 1 long and 2 short beeps
  • Bad power supply - 1) continuous beeps, 2) non-stop short beeps
  • Bad memory - 3 short beeps
  • Bad Motherboard - 1 long and 1 short beep
  • Disk drive related problem / Video card problem - 1 short beep then nothing happens
May 02, 2008 | Computers & Internet
ASUS A8S-X beeps sometimes on startup!
Hi 1 Long, then 3 Short Beeps: Video error The BIOS is unable to access the video system in order to write any error messages to the screen. Diagnosis: This is usually caused by a problem with the video card, or the memory on the video card. Remove your video card inspect it for damage and then re insert it. Try rebooting and see if the error remains. If so replace the battery on the mother board and try a different video card. If you have a video card built in then remove 1 srick of the RAM and re boot. Do the same with the other stick. If the error still remains then there is a fault in the Mother Board I hope this helps!
May 11, 2007 | ASUS A8S-X Motherboard
ASUS M2N32-SLI Deluxe/Wireless Edition ATX Motherboard (1254095) Logo
94 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
