Question about Gateway Profile 4 Notebook
Gateway profile 4
Will not detect the dvd rom drive
  • 833 Answers
You probably don't have the software installed. Go to the dvd mfgr's website and download the driver. Often, windows will not install the correct one. Does the unit have power?...does it light up when you boot? If not, the problem is not the driver.
Posted on Jan 07, 2008
Gateway dx4200 09 dvd drive will not eject?
Unable To Eject DVD From DVD-ROM Drive With The Eject
The DVD-ROM drive will not open to release the DVD when the button is pushed on the drive. RESOLUTION:
  1. Shut down the program that you are installing or running that uses the DVD-ROM drive.
  2. Wait 10 to 15 seconds, and then open the DVD-ROM drive by pushing the eject button on the DVD-ROM drive.
  3. If the DVD-ROM drive door still does not open, do the following:
    • Insert a paper clip or small pointed object into the small hole near the button on the DVD-ROM door.
      Gently push in the paper clip until the DVD-ROM door opens.
    • Remove the CD from the drive.
To prevent the DVD-ROM drive from exhibiting this behavior again, follow these steps:
  1. From the Start menu, point to Settings, and then click Control Panel.
  2. In Control Panel, double-click the System icon.
  3. In the System Properties dialog box, click the Device Manager tab.
  4. On the Device Manager tab, double-click the CD-ROM category.
  5. Double-click Toshiba DVD-ROM.
  6. In the Toshiba DVD-ROM Properties dialog box, click the Settings tab.
  7. On the Settings tab, clear the Auto insertion notification check box, and then click OK.
  8. Click Close.
Dec 03, 2013 | Gateway DX4200-09 PC Desktop
CD Rom not detected
CD Rom not detected? As in the Disk or your CD Rom Drive? If it is the disk you should make sure that your drive is compatible to read it. There are different kinds of DVD's out there.
If your Drive isn't recognized this will take a little bit of troubleshooting to determine the issue. First, you should make sure it hasnt become disconnected. Does it open and close? If you go into device manager, is it listed under CD/DVD Drives? Try running a windows update to see if it has drivers for it. You can try to reboot your PC. It is also possible that the drive is actually failing and needs to be replaced.
Feb 20, 2013 | Gateway Computers & Internet
Cannot Detect CD/DVD Drive and USB Drives
mark_holzem
If the drives are not being detected this is a sign that you need to have the drive letters mapped. The links below will help you do this.
How to change your drive letter in Windows Vista and Windows 7
How to change your drive letter in Windows XP
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Sep 06, 2011 | Gateway (5500381) CD-ROM Drive
Asus e818a3t is recognized as a DVD-ROM only. I can no longer write CDs after my Windows 7 Pro 64-bit install. Windows says the driver is installed and everything is working properly. Obviously not!
Hello there,
Try this trick,
1. Go to Hardware Profile and Remove your Asus ROM profile.
2. Shutdown your Machine -
3. Remove the Asus ROM from your Sata Connector.
4. Turn your Computer ON without that ROM
5. Shutdown it again, and Reconnect your ROM to those Sata connectors
6. Comment back here if still not working. :)
Cheers!
Aug 20, 2010 | ASUS DVD E818A3T - Disk drive - DVD-ROM -...
Missing drivers for Gateway desktop DVD drive. manufacturer's website useless.
I recognize that you've previously visited Gateway's support site, but I recommend trying again at the follow page. You can choose your exact desktop from this list:
http://support.gateway.com/support/drivers/ddaStep.asp?platform=10021&st=browse
You should be able to find the driver for your DVD drive there.
If not, you can open the computer case, find out what the manufacturer of the DVD-ROM is and go to their site to find the necessary driver.
Also, have you tried using the "Update Driver" utility in Windows? You can manage drivers from within the Computer Management console of Windows.
1. Right-click on My Computer and select Manage.
2. Then select Device Manager.
3. Expand CD/DVD-ROM drives.
4. Right-click the drive and select "Update Driver"
--Good luck!
Aug 01, 2009 | Computers & Internet
-DVD Drive won't read or burn blank -DVD media
Just replace the drive, that unit is old and it has a bad reputation.
Mar 03, 2017 | Computers & Internet
I have a gateway Dvd rom and my drive is missing
Windows XP provides drivers for optical drives (DVD-ROM)
If you can set me what drives you have on your system, I can help you to set them up
May 01, 2009 | Gateway (5500652) (  5500652)...
My emachines dvd rom is not detecting a dvd in the drive
Dissamble the dvd rom from pc. Open it and clean the laser with a soft cloth or try a dvd lens cleaner disk. You can buy it from any hardware shop. Connect the cables correctly. Start with a fresh dvd disk. If your pc still can't detect dvd disc, replace dvd rom with a new one.
Feb 23, 2009 | eMachines T5274 Desktop PC
Gateway gt5464
Alright i would say it has something to do with your memory if you don't know what that is it's RAM= RANDOM ACCESS MEMORY check in your BIOS to see if your RAM is in and also check your boot order to see if its correct like your HARD DRIVE first then CD-ROM.
Dec 14, 2008 | Gateway GT5220 PC Desktop
CD Burner not detected.
Check your different jumper settings in the drive; Is your CD RW drive set in the proper setup as a slave or master drive; or as a single drive.Check in your bios, in the disk management section if your CD RW is detected.
Apr 22, 2008 | Gateway (5502134) CD-RW/DVD-ROM (Combo)...
Gateway Profile 4 Notebook Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
