4GB SDHC not compatible with hp iPAQ
Hi there....I just bought two 4GB SDHC memory cards for my hp iPAQ and they do not recognise it.  I would have thought that they would work.  Should they?
  • 362 Answers
Not neccessarily each one is designed to read certain amount of memory and if it wont read it it wont work. you have to check the specs on yor equiptment before you go purchase.
Posted on Dec 12, 2007
I bought a 4gb memory (Sony) card. I t shows unsupported when turned on , is it compatable?
The M415 works with SD cards. Your 4GB card is actually an SDHC card and won't work with the camera. You need to use SD cards, 2GB and smaller.
Aug 25, 2011 | HP Photosmart M415 Digital Camera
I have a 4GB SD memory card that I am trying to use. It says the memory card is empty or incorrect file format. I have only 4 jpegs that I compressed thinking this was the problem. How do I get it to...
The problem is that your NuVue 560 Digital Photo Player is only compatible with SD cards, not SDHC cards. You bought a larger card for your older Digital Photo Player, not noticing that it was SDHC (or not knowing that it mattered). The new card doesn't work, not because it or the Digital Photo Player is broken, but because it's not compatible.
Cards up to 2Gb are generally SD.
Cards of 4Gb are generally SDHC.
Cards over 8Gb have to be SDHC.
(There are exceptions. Sometimes, manufacturers make 4Gb SDHC cards but some have errors; they disable half of the chip and sell it as 2Gb, but it's still SDHC. 4Gb cards are almost always SDHC because they're cheaper, but 4Gb SD cards do exist. They are so rare that I've even seen a guru on this site claim they don't. I did own one once, but it was very expensive and turned out to be so unreliable that I had to return it. I don't recommend looking for one, because of the problems.)
Your solution is to go find a 2Gb card, and be extra sure that it doesn't say "SDHC" on it. Ask around your friends: someone who has a camera that can use SDHC cards might have an older 2Gb card that they'd be willing to swap ;-)
Mar 21, 2011 | Digital Spectrum NuVue 560 56Inch Digital...
I haw a ipaq but my newsdhc 4gb do not want to install.
This HP Ipaq runs on Windows 5.0 , which is an old platform. For 4GB SDHC to work u will require an advanced handset. Even if it accepts it will freeze or the screen will stop working. Finally u cant install 4GB SDHC on ur HP IPaq :(
Mar 14, 2011 | HP iPAQ HX2100 Pocket PC
SanDisk 2GB microSD Memory Card not working can recover data from most flash memory devices including memory cards and usb flash drives for just £39 - give them a try it worked for me!
Dec 18, 2010 | SanDisk 2GB microSD Memory Card
Your memory card reader lacks SDHC compatibility. You must either update your pc card reader to one which is compliant with SDHC or use a cheap external card reader to do the job.
SD and SDHC cards look the same and fit the same slots, but they have significant technical differences which older readers cannot handle.
Jul 22, 2010 | SanDisk 4GB microSDHC Memory Card
My Powershot 450sd camera is not reading 4GB SDHC
SDHC memory cards are relatively new, and are sadly compatible with only the newest model cameras. For your model camera, recommend a maximum 2GB standard SD card. Fortunately, these days a 2GB card is very inexpensive.
Dec 29, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
Just bought 4GB SD card that hx4700 does not recognise - help pse
Your slot in the iPAQ is a SD slot, not a SDHC slot - therefore it will not read the card. Your PC card is probably a dual reader. The SD cards look the same but are different. Have a read of this...
Dec 10, 2008 | HP iPAQ HX4700 Pocket PC
Sd Card reader not recognising SDHC cards
When You Insert your SD card into the internal card reader, then the SD card is not recognised by the system and the SD card drive doesn't show there. The problem can be because of driver issue, system issue and device issue.
To fix the problem you need to go at device manager if there is a yelllow sign in SD card controller, the problem is most probably caused by a driver issue. Then you need to update the driver. You can also download the driver for your card reader.
Also, check if your SD Card is broken. You can also check it into different devices port.
If it is detected then you can backup of your data.
If the problem not resolved by any means and you require you SD Card data then I will suggest you read -
Mar 03, 2017 | Computers & Internet
What's max mem size for ipaq 1950
Mem cards are added as storage cards and do not add up to your iPaq RAM.
You can use mem cards to add up space to install applications. (ie. it is something similar to installing a new Harddrive on your PC). However the physical RAM of your iPaq cannot be extended.
PocketPC programs have small RAM requirements so your PDA's built-in RAM will suffice.
As far as the maximum card size if I understood your question right, if your iPaq comes with Windows Mobile v5 or earlier, it supports SD cards up to 2GB and perhaps some non SDHC standard SD cards up to 4GB. If you can upgrade to WM6, then WM6 supports SDHC cards, so you can install >4GB cards.
Hope this helps.
Feb 16, 2008 | HP iPAQ rx1950 Pocket PC
Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
I recently bought a DMC-TZ3 and have been researching memory cards. Several sites sell cards with the camera and list the card type. I would suggest buying one of these cards. Any cards larger than 2gb must be SDHC type SD cards. There appear to different types of SDHC cards, 1.0, 1.1 and 2.0. Check out for a description. 2.0 cards are not compatable for devices developed prior to 2.0 so that may be the reason for the camera problem. So far I haven't seen anything that states what type SDHC card the camera requires. I found a computer memory site that that sells memory that they say will work. There may be others.
Dec 13, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
Computers & Internet Logo
424 people viewed this question
David Payne
David Payne
