How do I make my Luminox titanium watch band smaller. Thank you.
2 Other Users Have The Same Problem
Comment by gagecreed, posted on Jan 20, 2008
I also have a Luminox titanium band that I need to resize. My concern is that there appears to be a flat head groove on one end of the pin (the same side that the 'arrows' are pointing to. I read somewhere earlier that if this seems to be the case, the pin should be unscrewed (and whether it's screwed in or not, the pin should always exit the band on the side that the arrows are pointing to...?).
I happen to have a set of tiny precision screwdrivers, but even the smallest one in the set seems to be just a little too wide to actually penetrate the shaft and reach the screw. I can file the ends down a little to fix that problem, but I'd like to know for sure if the pin is actually screwed in before I attempt to do that.
Any thoughts?
Comment by stan462, posted on Dec 15, 2007
How to adjust the links on the watch..Need to take out 2 links.
Thanks,
Stan
Rating: 0%, 0 votes
Was this solution helpful? Show your Appreciation by rating it:
Rating: 0%, 0 votes
Post a New problem for Navy Seal Luminox Watch with
Email this problem
Can you Help with these Watches problems?
Need more links
Rotating unidirectional bezel...
LUMINOX DEAD IN THE WATER!!!
