4110 HP All-in-one Printer Problem
Basically, one day, all of a sudden, for no apparent reason, my printer started rejected my black ink cartridge, claiming it was the wrong kind. Of course, this is absurd, as it was just using the same cartridge successfully for several printouts... and all the numbers check.
Is there anything I can do, or will replacing the cartridge with (another) new one fix the error message?
I've tried everything as far as rebooting, re-installing, etc... but the problem persists.
Thanks for any info,
Replacing the cartridge should fix your problem.
Posted on Jan 15, 2008
After 7 yrs, suddenly the ********* cartridge is not recognized, no red light, why?
HP Officejet Pro 8500 will not recognize changed ink cartrid ... > Printers, Copiers, Scanners and Fax > Inkjet
Laptops & Tablets Laptops & Tablets .... HP Officejet Pro 8500 will not recognizechanged ink cartridge ..... I have a hard time believing that something that worked just fine until it ran out of ink, suddenly has a broken sensor. It's barely 2 yrs old. ... show any ink, replaced them all and after 5 minutes of 'thinking', worked.
Epson cannot recognise a cartridge:16 ways to solve the ...? 6:33 4, 2013 - Uploaded by viandant5The red ink light remains on after replacing an ink cartridge. - The printer is not recognising one or more ink cartridges. ... Via Beverara 224/7 ... Printer cartridges not detected - How to fix - Duration: 2:41. by Thriftyink 102,951 ...Epson inkjet printer rejecting printer cartridges
Dec 21, 2015 | Office Equipment & Supplies
HP 8600 New Setup ink cartridges not recognised
Hi Alan,
Is this brand new printer ? Check the Warranty on it, Ideally warranty starts from day 1 you purchase the printer.
If it is asking you to use Setup cartridges, you should try contacting HP Support.
Feb 14, 2013 | HP OfficeJet Pro K8600 Printer
The ink is dried up from not using machine, Will my hp4110 all in one print, if i leave in the old color cartridge , and just replace the black ink?
If both of both of the cartridge has dried up, I suggest you replace them both to prevent further problems to your printer. If you are planning to print just black from your printer, It is still advisable to use a working color cartridge as a clogged one can cause cartridge detection problems which may result to further printing issues.
Click here to view an article on how to clear a clogged cartridge.
Sep 04, 2011 | HP Officejet 4110 All-In-One InkJet...
Hello! hp 4110 "check black cartridge"
usually this means you need to change the black cartridge out for a new one as you are low on ink
Jun 15, 2011 | HP Officejet 4110 All-In-One InkJet...
The printer suddenly started printing fuzzy text. I think it is out of alignment but when I try to print the alignment page, it comes out fuzzy too. Is there another way to align the printer and take care...
There are several reasons why the HP All-in-One may fail to align the cartridges. The most common reason is an ink cartridge that has one of the following problems:
  • One of the ink cartridges is low or out of ink. Black and all three colors must be available.
  • The paper has already been printed on or is colored paper.
  • Protective tape on a new ink cartridge has not been removed.
  • Contacts on the ink cartridge are not meeting the contacts in the carriage correctly.
  • Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
  • The ink cartridge is defective
Jan 13, 2011 | HP PSC 1410 All-In-One InkJet Printer
Printer only won't print in black
My printer did that a few months ago. I tried everything to get it printing black but in the end I had to take the ink cartridge back and return a new one. Some ink cartridges dry out when they are being shipped if not stored in proper conditions.
Mar 14, 2010 | HP Officejet 6500 Wireless All-in-One...
I refill my own cartridges. Printer says "Black Ink Low". I tried the "tape over the contacts" trick but it didn't work. How do I clear this error without having to cycle 2 other cartridges through it?
Use the fairy new cartridges offered by HP.
I realize they cost more but if there is a problem there is a warranty available from HP on their product.
The first thing refilled cartridges do for you is to cause any remaining warranty on the printer to be canceled.
Another benefit of refilled cartridges is most often poor print quality. Then of course, you can get stuck in the "Check ink level" or "Incorrect ink cartridge"
Refilled cartridges are not worth the time and effort you put into them, but hey that's just my humble opinion. I have seen firsthand what the damages can be with junk ink.
Feb 14, 2010 | HP Officejet 4110 All-In-One InkJet...
Hp photosmart d7200 erro Oxc18a0001
Filling your cartridge with non-HP ink won't cause an error. There are basically two reasons for ink system failure, The cartridge is no good or the ink system has failed. Some of these machines can be reset. But, try replacing cartridge first.
Jul 16, 2009 | HP Photosmart D7460 Printer
HP Officejet 4110 doesn't print
You very well could have messed up a sensor in the printer.
These days, printers are considered "throw-away" and normally there are not any parts available to repair them.
You won't find a manual. Even printer repair shops cannot get parts.
But before you consider all lost, you could try to get a new cartridge. Otherwise, get a new printer.
Apr 20, 2009 | HP Officejet 4110 All-In-One InkJet...
Black Ink Cartridge error
clean the head With alcohol ,dry put it back
the head is jam !
Mar 10, 2008 | HP Officejet 4110 All-In-One InkJet...
320 people viewed this question
