Maytag EPIC MFW9700S Front Load Washer Logo
Anonymous Posted on Sep 17, 2009
Divide 56Kg in the ratio of 4:3
Divide 56Kg of potatoes in the ratio of 4:3
Anonymous
Level 2:
  • Expert 291 Answers
  • Posted on Sep 17, 2009
Anonymous
Expert
Level 2:
Answers
291
Questions
0
Helped
108998
Points
800
You just need to divide the 56 by 7 in order to get the right base, then multiply that result by 4 and then 3 in order to get the answers. So...
56/7 is 8. 8*4 is 32, and 8*3 is 24.
32Kg and 24Kg
You can do this with algebra as well, equation is 4x + 3x = 56.
Testimonial: "Thank you"
What is the petrol to 2 stroke oil ratio for the 61
really? grade school math.
Divide 1 by the total number of parts (water + solution). For example, if your mixratio is 8:1 or 8 parts water to 1 part solution, there are (8 + 1) or 9 parts. The mixing percentage is 11.1% (1 divided by 9). If your mix ratio is 4:1 or 4 parts water to 1 part solution, there are (4 + 1) or 5 parts.
Sep 07, 2017 • Garden
2answers
Diff ratio. On a 1994 toyota 4 runner v6 petrol ??
4x4, 4 cyl, 4.10 ratio, ABS 4x4, 4 cyl, 4.10 ratio, w/o ABS
4x4, 4 cyl, 4.56 ratio, ABS 4x4, 4 cyl, 4.56 ratio, w/o ABS
4x2 (3.90 ratio), 2 wheel ABS 4x2 (3.90 ratio),
4 wheel ABS 4x4, 6 cyl, 2 wheel ABS, 4.30 ratio
4x4, 6 cyl, 2 wheel ABS, 4.56 ratio 4x4, 6 cyl, 2 wheel ABS, 4.88 ratio 4x4,
6 cyl, 4 wheel ABS, 4.30 ratio 4x4, 6 cyl, 4 wheel ABS, 4.56 ratio
4x4, 6 cyl, 4 wheel ABS, 4.88 ratio there are a few options. you will need to figure it out or look at the code panel in the truck. if you want to figure it out. you will need to remove the cover from that axle and count the two ring gears and then divide the numbers to get the gear ratio. for example if one is 40 and the other was 11. would be 3.72. so here is the trick to counting the gears. they are covered in oil so have a pan ready when you pull the cover. and use a marker or crayon and mark a tooth on the gear ring. then count the gears and you will know where to stop when you get back to your mark. the little gear will be harder since its in the back. you might have to turn the wheels and you will need it in neutral and jack the rear end up. as always use jack stands to prevent damage to you or the truck..
Please explain how you do ratios
A ratio can be simplified by dividing both sides of the ratio by the Highest Common Factor (HCF). The highest common factor is the largest number that goes into both numbers of your ratio. In example 1 you are asked to simplify the ratio 6:8. Here the HCF is 2 so divide both sides of the ratio by 2 to give 3:4.
https://www.youtube.com/watch?v=cbjQWf411O8
How do you figure out the gear ratio on a 1972 chevy blazer. the crown gear has 41 teeth
if the ring has 41 and the pinion has 10 divide 41 into 10 = 4.10 so take and divide the higher tooth count and divide by lower tooth count another Example 44 Into 12 = 3.41 Ratio good luck
3helpful
DB to Power ratio using antilog
The conversion formula is
# dB =10*log(Pout/Pin) for say an amplifier.
For your case
Pout/Pin= 10^4 then #dB =10*log(10^4)=10*4=40 dB
Let us take a less obscure exemple
# dB= 57.39, what is the power ratio?
10*log(Pout/Pin)= 57.39
log(Pout/Pin)=57.39/10=5.739
Pout/Pin=Ratio =10^(5.739)= 548276.9649, not a number you would hear or see quoted, but a correct value.
To calculate the power ratio
  1. Convert the decibels in Bels (divide by 10)
  2. While the number just calculated is still in Answer memory (ANS), press [SHIFT] [LOG] to access the the 10^x function
  3. Press [SHIFT][(-)] to enter (ANS)
  4. Close the parenthesis [)]
  5. Press [ENTER]
Here is the screen capture for the calculation one way and back.
How to calculate ratio number
Ratios are usually written as xx/1 such as 8 to 1 or 4 to 1 so that one is the base number. If you have 8 black sheep out of 64 then it's ration is 64/8 but you want to reduce the 8 to 1 so divide 8 by 8=1. now you have to do the same thing to the the other side of the equation so you have to divide 64 by 8 = 8 or to simplify this divide the first number by the last = the radio. Thus 64/8 = 8/1 on a more difficult scale let's do 6888/123 is 6888 divided by 123 or 56 to 1
How to nfind a gear ratio ?
Count the number of teeth on each gear and divide. Example: If gear (a) has 60 teeth and gear (b) has 20 teeth, then the gear ratio is 3:1. Hope this helps.
Jul 21, 2009 • Boating
Gear Ratio
there should be a tag on one of the rearend cover bolts indicating the ratio.if not remove cover count all the teeth on the ring gear and pinion,divide the ring gear # by the # of pinion teeth and that will be your ratio.
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
