Canon 4200F I am trying to print directly from the scanner to my home network printer. Is there anyway to change the default printer to my home printer and change it from Quick books PDF. I change it and apply the change yet everytime I go to print is is back to quickbooks. Running windows pro XP. The settings button is useless just lets me move the buttons on the front to do what I want but they won't do what I want. Needless to say printing directly from the scanner to the printer is NOT the quick task I have needed it to be!
Are you using CS toolbox?
I f so go into the preferences and choose it to print for copy.
Make sure your network printer is set to the default.
Find toolbox here after choosing your OS
reloaded drivers from canon website (windows 7 64 o/s) but message "there is no application...
(More)
reloaded drivers from canon website (windows 7 64 o/s) but message "there is no application registered for this event " shows when trying to use the scanner (canon flat 4200f)
why does my canoscan toolbox show no twain connection after being idle for a period of time? I need...
(More)
why does my canoscan toolbox show no twain connection after being idle for a period of time? I need to reboot my PC to get a connection established.
When scanning in colour on Canoscan 4200F, documents come out dark and white background on original...
(More)
When scanning in colour on Canoscan 4200F, documents come out dark and white background on original comes out grey. What can be done to correct this? Scanning in black & white works fine.
Scanner 'Canoscan 4200F' will not run. Appears to be a problem with the drive mechanism. Sounds like...
(More)
Scanner 'Canoscan 4200F' will not run. Appears to be a problem with the drive mechanism. Sounds like cog wheel not engaging properly ? It has not had a lot of use, maybe two or three dozen times.
I am scanning coloured drawings (grandson) and the white paper background turns blue when scanning....
(More)
I am scanning coloured drawings (grandson) and the white paper background turns blue when scanning. SHows white on "preview" then changes ( still in preview) to blue tone when time to "scan". I tried "photocolour" and "magazine", settings; both turn the background bluish.
