Question about Konica Minolta magicolor 2300DL Laser Printer
Konica Minolta 2530DL
I am experiencing the Fatal Error Code 17H on my printer.
I have taken out each of the colour cartridges and replaced them in the order invited by the printer. ie after replacing each cartridge the machine is closed alllowing the cartridge carrier to cycle to the correct plositon, then it invites the insertion of the next specified colour.
Interestingly after doing this I was asked by the printer to print a page. This printed page (black only) showed toner useage etc., but printed effortlessly, then the printer returned to the Fatal Error code, when I tried to print a colour copy.
From other advice received, but without suyccess, I have released the cartirdges mechanism and gently eased around the colour cartridges head, in an effort to re-align the colour head.
Whenever the error occurs, the paper onto which the print is to be made travels through the paper path to a position where the leading edge of the paper stops against a small plastic trigger (which could be a counter or some other similar device) seems to stop the paper. This small "trigger".is situated on the rear section of the paper pth about 50% of the way up the interior of the machine-paper pathway.
Lastly and following this paper path comment, I m wondering whether the problem relates to paper path rather than Colour Cartiridge?
Any suggestions to rectify my problem?
  • 3 Answers
I had the exact problem with the paper stopping at the same point in the printer. The fault was not the paper feed but the fact that the drum stopped at this point due to a loose toner cartridge. I rotated the cartridge using the menu for relpacing it and removed the cartridge and then re-fitted making sure it was fully seated in the printer. It now works fine. I would check each of the toners again.
Posted on Dec 27, 2007
I have a Fatal Error Code: 17H Can you help? It is a Magicolor 2530 DL color printer.
Check your toner cartridges, one of them is seized up. Remove all cartridges and turn the gear on the right side backwards ( counterclockwise) about 10 times and see if it turns smoothly. I don't know why but 90% of the time its the cyan that gets stuck.
Jun 11, 2010 | Konica Minolta Magicolor 2530 DL Laser...
your printer is laser printer change toner cartridge right,
you may try
1) Open the front door and remove the toner cartridge.
2) you will see a small round hole near the colour toner cartridge
3) hold a screwdriver in that hole and the carousel will rotate freely. 4) Move the carousel round and remove each one of three cartridges at a time.
set back all cartridge close door.
Jan 29, 2009 | Konica Minolta magicolor 2300DL Laser...
Where are the toner cartridges in magicolor 2300 dl
rack rotation
open door, remove waste toner box then you have to find a small switch in left side and push it wit screwdriver or something, then you can rotate the toner rack manually. then install the waste toner box again and power up printer.
Sep 01, 2008 | Konica Minolta magicolor 2300DL Laser...
Minolta 2300 dl laser printer fatal error 17H
had printer for approximately 2 years. Used daily in office setting. today the printer tried to print, then just stopped and it said fatal error 17H in the window. We cleared paper jam and rebooted, gives the same error message. Anything we can do?
Apr 14, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Minolta Magicolor Fatal Error
Remove each of your cartridges one at a time and see if you can spin the toner rollers by pushing on the little white plastic gears with your finger. They will be tight but you should be able to spin the roller by moving the little gears around.
My printer started giving the Fatal Error Code 17H and I did all the removal of the four color cartridges and re-seating each of them to no avail. After removing each cartridge and checking to see if I could rotate the toner roller I found that the yellow cartridge was extremely tight. I took the cartridge outside and used a can of compressed air to blow all the toner off the roller and tapped the cartridge on all corners and shook it back and forth several time. Finally I was able to get the toner roller so that it would rotate when pushing the little white gears like the other three cartridges.
After replacing the cartridge in the printer it worked with no more error codes. Hopefully this will fix the problem until I can order a new yellow cartridge.
Jan 07, 2008 | Konica Minolta magicolor 2300DL Laser...
Fatal error 17H
Try going through each toner cartridge again. The error is linked to incorrect rotation usually caused by badly seated toner cartridges.
Dec 06, 2007 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta Magicolor 2300 DL - Fatal Error Code 0EH ????
I had the same problem one time, they told me to pull out all of the toner cartriges, power off, power on, power off, replace all cartridges and the problem went away.
Who knows why. If this doesn't work....
Call Konica Minolta tech support.
They were pretty helpful to me.
Nov 28, 2007 | Minolta magicolor 2300W Laser Printer
Rack rotation failure, I'm not 100% that this is that error, but does the rack, where the toner are move ? if not, move it with manually a little bit then restart printer.
Nov 14, 2007 | Konica Minolta magicolor 2430 DL Laser...
Fatal Error 17H - toner cartridges will not advance
Open the front door and remove the toner bottle.
Look near the colour toner carts and you will see a small round hole. Jam a screwdriver in that hole and the carousel will rotate freely. Move the carousel round and remove each toner one at a time.
Oct 10, 2007 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta magicolor 2300DL Laser Printer Logo
519 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
