Seagate FreeAgent  Go 250 GB USB 2.0 Hard Drive
Problem for Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive
320GB seagate freeagent, cant open some of the files.
By itzabhijith on Sep 17, 2009
I bought 320GB seagate free agent go 3 months back.
I stored some data in the disk. From a week back I m not able to access some of the folders. Today I was not able to open another one. I was able to open these folders some time back. Some times I cannot write data into Hard disk. I get a warning saying the disk in "read only". But some other times I can copy data.. What is the solution??
I have already formatted the disk once.
Data format is FAT32.
Best Solution
posted on Sep 17, 2009
Very Helpful)
bob_computer
Rank: Guru  Computer Accessories  Expert
Rating: 87%, 1250 votes
If you have the ability and space then recover any files that you can
use the RUN option from the start menu
now type in "cmd" then ENTER
Now in the black box that appears type "chkdsk x: /f /r" and press ENTER
The "x" is the drive letter of the drive you wish to check
It may take some time but this will try fix any errors it comes acrosss and you may have to re-start to complete the task.
Now remove any more files that you can.
Use the RUN command again but this time type "compmgmt.msc"
Select Disk management
Make sure you freeagent is listed here.
Right click and select "Format"
Select NTFS as the file system
Do not tic any other boxes
Click OK
When it is done you can move the files back to this drive.
It is quite possible you hit the limits of the FAT32 file system which would have caused the types of error you saw.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Sep 18, 2009
Not Rated)
sandip426
Rank: Wiz  Computer Accessories  Expert
Rating: 92%, 12 votes
Harddisk could have been damaged. Have it replaced if you still have warranty on it. Otherwise try to run good harddisk repair tool like Norton Disk Doctor. Boot the computer from CD run Harddisk diagnostic program and see whether it pass the test. The diagnostics program are usually available from the website of the manufacturers. Another way the problem could be solved by running the scandisk to check physical damage of the harddisk. From windows you can do the same thing using the Error checking from the harddisk drive's property's options in my computer window.
Was this helpful?
Yes
No
Popular Solutions for Seagate FreeAgent Go 250 GB
Questions and Unsolved Problems for Seagate FreeAgent Go 250 GB
Do you recommend Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive?
Answer
Answer
Why do I get all these files in my Recycle bin every time I boot up with the FreeAgent External... (More)
Answer
my freeagent go no longer backs up. it just tells me the backup failed and when i view the back up... (More)
Answer
Not recognizing anything that I try to back up...like pictures, music...anything
Answer
Seagate Freeagent 250Gb go mac does not work on my Xp pro operating system but works fine in Vista.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Hard Drives Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
