VGA PC CAMERA
When installing via the cd, it installs up to 80% then says 'error 20' and will not install..
  • 18 more comments
  • ZERT Dec 12, 2007
    VGA PC CAMERA
    Chicony DC-5132; HP: EW193AA#XXX
    OR
    Chicony DC-5130; HP: EW192AA#XXX
  • ZERT Dec 13, 2007
    what do you mean by operating system? I have windows xp if that helps ..
  • ZERT Dec 13, 2007
    I also use firefox though I have the option of windows explorer; also I didn't get any link in your last reply.
  • ZERT Dec 13, 2007
    I have tried on both firefox and windows explorer and it won't download..
  • ZERT Dec 13, 2007
    no, by somebody who works for HP.
    so you say i should clean out temp files.. how do I do that?
  • ZERT Dec 13, 2007
    ok, I worked out how to do the first way :-))
    and I'll try the second one .. and let you know if it makes a difference..
  • ZERT Dec 13, 2007
    hmm.. after all that .. it's still coming up with error 20
  • ZERT Dec 13, 2007
    this might help..
    it says the process cannot access the file because it is being used by another process; how do I find out what? where?
  • ZERT Dec 13, 2007
    temp files should have been cleared by the clean-up process ... correct me if I'm wrong ..
    you want to know all the processes listed? There are about 40 listed under processes!
    the applications are firefox and skype [under applications]..
  • ZERT Dec 13, 2007
    ok, I will do this; there were some temp files that could only be wiped out if the comp was restarted; I must admit, I skipped this stage.
    There was originally other cam software installed but it was one of the first things I completely deleted when these problems started.
  • ZERT Dec 13, 2007
    so I should rerun Ccleaner?
  • ZERT Dec 13, 2007
    do you mean the part labeled 'registry'? I run it through and it says its fine - no issues were found.
  • ZERT Dec 13, 2007
    I don't know who you are but you've sure got loads of patience and you're being a great help!
    I have done i think what you have told me and, lo and behold, it loads fully :-)) .. no 20% error .. BUT it is not appearing in the scanners and cameras in control panel..
  • ZERT Dec 13, 2007
    also, just btw, after doing everything, restarting etc, firefox has started with an xtra toolbar from yahoo;as far as i know i didnt invite them! How do i get rid of it and any idea why it appeared? [you dont have to answer this if you feel this is another query but it has appeared after all the above :)]
  • ZERT Dec 13, 2007
    btw, it does say [near the clock] a new hardware has been installed and ready for use..
  • ZERT Dec 13, 2007
    I cant try the cam if its not installed on the scanners and cameras section; I have no link to start it with; when it originally loaded or installed, it registered there and that was how i accessed it..
  • ZERT Dec 13, 2007
    wooopee, it's on! now I have to test it :-))
  • ZERT Dec 13, 2007
    hehe, yu're a wizard..
    it's up and running..
    thank you very much ..
    btw, the yahoo hasn't uninstalled even though i did restart etc and its now not on the add or remove programs any more .. ??!
  • ZERT Dec 13, 2007
    where can I rate you?
    was there anything else you were going to say?
  • ZERT Dec 13, 2007
  • 328 Answers
If you tell me the brand and model of your webcam, I can find a driver on-line for you. Also tell me for what operating system you have.
Posted on Dec 12, 2007
  • 12 more comments
  • Lyle Siemens
    Lyle Siemens Dec 13, 2007
    I do believe that this link for drivers should work fine. Scroll down to the DC-5110 series and download the driver. I tried the link myself and could not get it to work on my computer but it may be my Firefox settings. I have scoured the web and could not find a better place to get this driver. Good Luck
  • Lyle Siemens
    Sorry about that, here it is
    http://www.chicony.com.tw/download/kb/to...
  • Lyle Siemens
    The site may be under repair right now. I found other sites with a driver but are in Russian or Japanese so I could not make out what to press to download. You can try clearing out all temp files on your system. Sometimes this clears the old info which may have been corrupted. Ccleaner is a free software utility that cleans out any file or files you want and also fixes the registry, may be something to try too if you want to retry the CD again. The driver download site may be up and running properly soon too I hope. Sorry for the problems you are having here. 9/10 this is a easy fix but this time, it has me stumped. Did you by chance get this cam from Ebay?
  • Lyle Siemens
    click on the Start button and choose Programs
    (All Programs in Windows XP). Then choose Accessories, System Tools, and Disk Cleanup. (A shortcut is
    to click on Start, choose Run, and type in cleanmgr.)
    The other way is with Ccleaner because it digs a little deeper and has no spyware or adware and its free.
  • Lyle Siemens
    Too bad. Does the driver CD support XP? This is an unusual error for XP. At this point I would wait until later on and only hope that the Chicony site will correct itself. This seems to be a very hard to find driver unlike most others. One last thing to try with the CD is: Right click on the CD in My Computer and select Compatibility and choose Windows 98 as a last ditch effort. I will continue my search for this driver for you in the mean time. I would also welcome any other expert's advice at this point.
  • Lyle Siemens
    Well in that case, try restarting the comp, clear temp files and try again. If that does not work, you have to check all running processes by Ctrl+Alt+Delete. Post them, one of them is interferring. Get back to me, I think I know what it is.
  • Lyle Siemens
    After restarting, the process running to prevent the install should have stopped. The clearing of all temp files also makes sure that there is no interference with the new installation. Do you have any other cam software installed on your system? If so, it must be uninstalled first.
  • Lyle Siemens
    Also in case Ccleaner would help with clearing the bad registry files left behind from the last driver. I understand that you may have un installed the last software but some registry items often stay behind and should be cleaned too.
  • Lyle Siemens
    Ccleaner has a registry repair option if you look. This is important to clear up any old files. Hope this works for you.
  • Lyle Siemens
    Under Start---->Run, type in "msconfig" Once it pops up, check under Startup. Make sure the name or extension of your old cam is not on this list. You can also uncheck any other startup items that are not needed for Windows startup. Do a restart. I really hope that this helps you for your sake, I know you must be frustrated by now.
  • Lyle Siemens
    Well the cam might be installed now but looks like the driver came with a Yahoo toolbar too. Go to Start---->Control Panel----->Add Remove Programs and look for Yahoo and click it and uninstall it. If you just want to hide it, right click on the Yahoo toolbar and you should see an option to remove it. Have you tried the cam yet?
  • Lyle Siemens
    I think Firefox may have tried to interfere with installation so that the toolbar doesnt change Firefox settings, hence an error. Too bad the cam has a hard to find driver on the net. You should try it with MSN too be sure if it works.
  • Lyle Siemens
    You may have to run Ccleaner's registry cleaner in safe mode. Restart and tap F8 and run the cleaner
  • Lyle Siemens
    Glad it worked for you. by providing such good info as you did helped solve the problem. Excellent communication.
What happens when I get Error code 20 on a canon rebel eos rebel t3i 600d?
From the Canon owner's manual:
"Error codes 10, 20, 30, 40, 50, 60, 70 and 80: Shooting is not possible due to an error. Turn the camera off and on again or re-install the battery. Operate the power switch, remove and install the battery pack again, or use a Canon lens (p.32, 28)."
Jun 17, 2014 | Canon EOS 30D Digital Camera with 18-55mm...
Lost Cd my mini digital camera
i have the driver, email me @
tech @ lawckedgaming.com
i will send it to your email
Jun 30, 2009 | Dual Electronics Mini Dual Mode USB VGA...
I HAVE a KTO international web camera but i lost the installation cd. How could I install my camera without a cd
you cannot start the camera without installation cd. for downloading the driver, go to download.com and in the search tab just enter the model no. there you will get your software also with free of cost........... enjoy :-)
Jun 28, 2009 | Radio Shack VGA PC Camera Webcam
IBM VGA camera XVP610 - driver installed, cam still not working
Hi Sir, I have an IBM Promax XVP610 web cam. I lost the installation CD that comes with it. Need...
May 26, 2008 | IBM Promax 33L4892 Webcam
Hp Webcam with Integrated Camera (Product number PG088AA) compatible with vista?
perdi el cd de intalacion y necesito el driver de hp vga webcam por fa me ayudan??
Jan 21, 2008 | HP VGA Webcam
Usb pc camera problem
Install your Usb pc camera under "administrator" user account means that all privileges should be i you so that you can install any driver and software to your pc. may this helpful to you.
In installing disconnect the pc cam to the computer and install the driver. after installing the correct driver connect back the pc camera. the computer will install it for you.
Dec 17, 2007 | Radio Shack VGA PC Camera Webcam
Computers & Internet Logo
473 people viewed this question
Alun Cox
David Payne
David Payne
