JVC AV-65WP74 Rear Projection Television
Problem for JVC AV-65WP74 Rear Projection Television
THE RED ON MAGIC FOCUS AND MANUAL CONVERGENCE WILL
By bmcnease on Sep 17, 2009
THE RED ON MAGIC FOCUS AND MANUAL CONVERGENCE WILL NOT ADJUST
Best Solution
posted on Sep 17, 2009
Very Helpful)
asnowman
Rank: Guru  Televisions & Videos  Expert
Rating: 96%, 593 votes
Your symptoms sounds like a damaged convergence IC.
There are two and large IC’s that control the convergence in a big screen set. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110, and they are located on the signal board (on the left as you look into the back of the set).
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
There are also two resistors on the front of the board located in the middle that are fusible link resistors, these should be checked for opens and replaced if they are found so.
I would suggest that you contact a service center in your area for a complete diagnosis and repair, as this type of repair can get a little tricky. But if you want to repair the set yourself, just remember to be careful. The capacitors and CRT’s can hold a charge and may shock you.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Not Rated)
dadsboy70
Rank: Guru
Rating: 93%, 40 votes
you need new convergence chips, they are stk392-110, there are 2 of them on the front convergence board, also check and replace and burned up resistors next to the chips, common problem, but you will need disassembly and soldering skills at least to fix.
Was this helpful?
Yes
No
Popular Solutions for JVC AV-65WP74 Rear Projection
Questions and Unsolved Problems for JVC AV-65WP74 Rear Projection
Do you recommend JVC AV-65WP74 Rear Projection Television?
Answer
Answer
My tv has a a yellow shadow with a little blue. would like to know if it can be fixed without... (More)
Answer
I have a pink line running across the screen about 4 inches down from the top of the tv
Answer
rainbow like spots on my jvc 52 rear projection how do i fix ,they were there before so i cahnged... (More)
Answer
The picture no longer comes in. The objects are fragmented
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
in , OH
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
