Computers & Internet Logo
Posted on Sep 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Monitor looks as if there is no CPU
I am using LG 700E CRT monitor. Green light is blinking as an indication of power supply before I switch my CPU. But after CPU is switched on, it is still blinking (as if CPU is shutted down). I can see that my mouse and keyboard are getting power supply. What can I do? Any help is accepted
Thanks in advance...
--Raja
Ian White
Level 2:
  • Expert 147 Answers
  • Posted on Sep 17, 2009
Ian White
Expert
Level 2:
Answers
147
Questions
Helped
29586
Points
397
If the light is blinking then the monitor is getting power. Make sure the vga plug on the monitor is securely connected to the PC. If you have more than one vga connection i.e. one on-board and another card, try moving the plug to the other vga connection. Ian.
Anonymous
Level 2:
Scholar:
  • Expert 112 Answers
Anonymous
Expert
Level 2:
Scholar:
Answers
112
Questions
0
Helped
37836
Points
343
As long as you suspect the computer is booting properly, I suggest you borrow a monitor from a friend to confirm your monitor is not working properly.
Please post back if you would like further assistance.
Anonymous
Level 3:
  • Master 375 Answers
Anonymous
Master
Level 3:
Answers
375
Questions
0
Helped
203338
Points
1545
If the power supply is coming to CPU before activation of CPU then it must be receiving current from UPS. Don't try unplugging, You may get shock. Thank you, Sir.
Ray Smith
Level 2:
  • Expert 124 Answers
Ray Smith
Expert
Level 2:
Answers
124
Questions
0
Helped
38832
Points
383
Try reseating your memory modules
1helpful
Preset mode in lg crt monitor
if you do repairs then disassemle the monitor.where the power cord is thats the power supply resolder the main components in the power supply. cause some of the them are not making good contact on the circuit due to the age of the monitor and constant heat over the years.
4helpful
2answers
LG 700E CRT 17" monitor,
problem with the monitor Display cable. it is damaged.
Normally monitor will receive 3 colors red, green, Blue signals from CPU. If one cable i.e Red wire connection is missing in display cable which is connected to monitor, Red color image on monitor wil be replaced with other fade color.
So, need the replace the display cable or display connector!
9helpful
3answers
700e Lg crt monitor problam power on eht on but not display
The normal crt monitor have a demo display when you unplug the vga cable to PC like this image below.. fd6b6b9.jpg
Note:
If the crt monitor green LED light steady and heater beam have light, the horinzontal and High Voltage supplied to tube is completely good. If you encountered this problem just focus on video section of crt monitor. But before you start... find the flyback transformer behind this they have two controls screen & focus. After you found it plugin the monitor use plastic precision or small screw philip driver for safety to high voltage at horizontal area choose screen control rotate it to clockwise direction follow this....
5b5166c.jpg If the display responses or from dim to lighter 100% you have a problem to ABL find this at the bottom of horinzontal section near at flyback transformer pins trace the line of ABL for dried solder, open resistor if nothing happen find the Video IC at chroma section and replace it. follow this...
3c6e89c.jpg For LG & Redfox you found LM1269NA Visit this site for seaching semiconductor matches www.alldatasheet.com Good luck.
Check this site for searching semiconductor
4helpful
Blinking of moniter 700e lg
I think that two capacitors in the powers supply circuitry(incise the monitor) has gone bad. Just open and you'll see them.
This should solve your problem.Best of Luck.Please rank me appropriately. If you want any clarification, Please get back to me
My LG 700E monitors indicator light is blinking for long
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. When the capacitors blow out they also damage the driver MOSFETs. If you aregood at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictures and your monitor should work fine. The capacitors do need to beinstalled with the correct + and - connections, note the stripe on theold one and insert the new one the same way. If you don't want to trythe repair yourself we offer a repair servicefor $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
5helpful
3answers
THE POWER LED (GREEN) IS BLINKING CONTINUOUSLY
LG 700E monitor's power LED blinking continueously and there is no display solutin ........
43helpful
6answers
LG 700E monitor's power LED blinking continueously, no display
LG 700E monitor's power LED blinking continueously, no displaySolution.............
1helpful
Lg 700e monitor
check dry points in power supply & Horizontal, video section(CRT Neck board)
check output voltages from SMPS
check 5V from SMPS to MICOM IC
Grand Canyon Tech
Grand Canyon Tech
