Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
Default Password I have not been able to set up a password protected network because I do not know what the factory default password is. Who should I call to get that password?
  • Anonymous Dec 18, 2007
    wireless g router not password protected...set up and working fine but no security
  • Conrad2269 Apr 15, 2009
    how do i get to where i can change the password, so i can hook up my 3g iphone to my wirelessness
  • 20 Answers
The default password for your westell 327 is username: admin and password: password, the admin admin combination is what usually isp providers such as verizon tells you to put in after configuring it for the first time. 192.168.1.1 is the url add for you to be able to access your westell 327. after accessing your modem you can find the WEP key below the modem, after enabling the security of your network the WEP kep is your default security password
Posted on Dec 20, 2008
Default facotry password access on Westell W327 is:
Username - admin
Password - admin
Posted on Dec 31, 2007
  • 38 Answers
Go to the manufacturers web site and look it up by model there. or google model and manufacturer.
Posted on Dec 14, 2007
Hi. what is default password Ip Camera model vivotek ip7730 ?
By default, the Network Camera is not password-protected.
Hardware Reset
The reset button is used to reset the system or restore the factory default settings
Sometimes resetting the system can return the camera to normal operation If the system problems remain
after reset, restore the factory settings and install again
Reset
: Press and release the reset button with a paper clip or thin object
Wait for the Network Camera to reboot
Restore
: Press on the reset button continuously for over 5 seconds
Feb 15, 2015 | Computers & Internet
Default password j4868a
The switch ships from the factory with no default username and password. If someone set it and you do not know it then you'll have to reset the switch to it's factory default configuration. There is a reset switch on the back of the unit and when pressed/held in a certain sequence the switch will reset. You'll need to look up the proper procedure in the user's guide of the switch.
Mar 07, 2014 | HP ProCurve 2124 (J4868A#ABA) 24x10/100...
Need to hard reset westell 7500 modem to factory defaults..cust chngd admin password and can't remember what they chngd it to and i need to get into modem
  • Note: Resetting your router to the factory defaults not only changes your router user name and password to the factory default values, but it also deletes all your home network settings. This includes the SSID and network encryption key. After you reset your router to the factory defaults, your home network won't be accessible until you reconfigure your router and all your network devices to use the same SSID and encryption key.
To reset your VersaLink 7500 gateway to the factory settings:
  1. Hold the reset button on the back panel of the VersaLink 7500 gateway for 30 seconds.
    • All your settings will be lost including network encryption information and any SSID information you have entered.
    • The gateway user name and password will revert to the default of Admin as the user name and Password as the password.
  2. Your VersaLink 7500 gateway is now using the default settings for the network configuration. This includes the default SSID and network encryption key. You must re-configure your VersaLink gateway to match your previous settings that were assigned to all other devices on your wireless network. Otherwise, no other network devices will be recognized.
Nov 05, 2011 | Westell Wirespeed VersaLink...
How can I recover my password, I have forgotten it?
Generally you cannot.
You should try using the default password for your router if you have not changed it. If it doesn't work, you can reset the router by pushing in the button on the back of the router and holding it for 10 seconds. Usually, it is protected by the case so you cant accidentally press it, use toothpick or a needle or some such. By doing that you are resetting it to the factory settings which means password will be reset to the factory default too.
However, you will also reset user info such as your Internet username and password and things like your wireless network set-up (including its password), port forwards and so forth. Make sure you know how to re-enter that information so you can re-establish the connection to Internet or any wireless devices.
Jun 20, 2011 | Computers & Internet
Change my router password
Click around once you're in the settings. There should be a setup tab with the password change somewhere.
Mar 12, 2011 | Linksys WRT160N Wireless Router
My grandpa set up our wireless network a few years ago, but bless his heart, he passed away just this year and we forgot our WEP key and we need to reset it or just get ahold of it so the family can access...
Sorry for your loss.
  • Note: Resetting your router to the factory defaults not only changes your gateway user name and password to the factory default values, but it also deletes all your home network settings. This includes the SSID and network encryption key. After you reset your gateway to the factory defaults, your home network won't be accessible until you reconfigure your router and all your network devices to use the same SSID and network encryption key.
To reset your VersaLink 327W gateway to the factory settings:
Hold the reset button on the back panel of the VersaLink gateway for 30 seconds.
  • All your settings will be lost including network encryption information, MAC Address filtering information, and any SSID information you have entered.
  • You will need your user name or password to reconfigure the unit..
Your VersaLink 327W gateway is now using the default settings for the network configuration. This includes the default SSID and network encryption key. You must re-configure your VersaLink gateway to match your previous settings that were assigned to all other devices on your wireless network. Otherwise, no other network devices will be recognized.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 18, 2011 | Westell Wirespeed VersaLink...
Need to find out password or how to reset a new password
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
or
if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
dont forget to vote hope this helps
Feb 05, 2011 | NetGear WGR614 Wireless Router
How do you reset a password?
Easy, reset the router itself, should have a tiny pin hole in the back that has a button that you must compress, just google reseting your model.
If you have any problems let me know.
Apr 03, 2010 | NetGear DG834G Router
Don't know my network name or password to hook up wireless printer
You only choice may be to factory default your linksys.....once you factory default the node, you should be able to login with the default username nad password
Oct 28, 2009 | Linksys Wireless-G WUSB54G 802.11g/b
Password protect the router
You can reset the router password but it will go to the factory default setting. Are you sure you know how to configure it back then do one thing take a ballpen and press the reset hole switch for 30 seconds or untill all the lights or single power light blinks now most of the roter factory default username and password is Admin try it first then do resetting
Jul 04, 2008 | Belkin Computers & Internet
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
762 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Carlos Soto
Carlos Soto
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
