Question about Whirlpool GEW9250 Electric Dryer
Condenser Washer Dryer
I have an LG washer dryer. The washer works fine, but the dryer does not work at all. A few months ago we had a leaking stop tap in the cupboard under the sink, and an emergency plumber came out an tightened it. Since then the appliance has not worked. Could the lack of enough water pressure be the problem?   We live in a victorian house and every pipe and tap in the place is old and tired. Any ideas? Thanks
  • 833 Answers
Sam...washers run on 110 volts..dryers on 220...two circuit breakers connected together. Flip them off and then on. It may be the problem. Water pressure has no effect on the dryer...Essentially, this is two appliances in one cabinet.
Posted on Dec 18, 2007
Condenser dryer
on the bottom right on the back is the water pump
it needs cleaning or replacing
not lifting the water to the water draw
Dec 12, 2013 | Creda IWD12 Front Load Washer / Dryer
Splendide 2000S Washer/dryer won't wash/dry. Noise then stops, then dial clicks around endlessly.
sounds very much like the bearing has seized on the drum.
can you turn it by hand?
I'm betting it's either stuck or REALLY stiff
Apr 16, 2017 | Splendide 2000S Front Load Washer / Dryer
I have a washer/dryer machine. It is about 4 years old. About a month or two ago when I switched it on it would light up, but not all around the dial. And then some cycles would not start. Then all cyles...
Possible failure of the program controller unit in your washer. Try to clean the contacts, make sure all the wiring's are tight , clean and reset all the contact pins and leads.
If the fault has reduced repeat the work or else the price of a new controller unit must be checked out before you decide to replace.
Jan 20, 2011 | LG WM3431 Front Load Washer / Dryer
My dryer quit working this morning. The light and beep go off but the drum dies nothing.
I have the Frigidaire Affinity Washer and Dryer. A few weeks ago my Washer door switch went out I changes that with no problem. Now the Dryer has just stop quit working. Here are the symptoms on the ; 1>it's plug up and the power is fine 2> there is no errors on the panel 3> control operate fine. 4> close the door, set the controls, press start, No spinning. 5> when you press start you hear a buzzing sound for about 5 seconds, then nothing... Is it over for the dryer I bought 3 years with out extended warranty, or is the a simple fix? Thanks, Rob...
Sep 07, 2010 | Frigidaire Affinity AEQ6000WH Dryer
For the past few years the small fuse in the washing machine blew about once a year. A few months ago it seemed to blow every week. Then it was fine again. Now I replace the fuse and as soon as I turn on...
One says the lid switchs are not working in tandem with each other. Another says the circuit board is bad. I say it is because it is a Maytag and built with an obsolete ethical plan for generating profit.
Dec 29, 2009 | Maytag LSE7806A Top Load Stacked...
Washer stopped working with clothes and water in it
If you try to wash too many items with the water level set to low it is hard on the drive sysem and will kick out the motor.
When the motor resets it should work again but its very bad for the motor so II would try not to do it again.
Good Luck
Jun 04, 2009 | Frigidaire FEX831CS Top Load Stacked...
i used to do warranty work for LG needless to say, after finding out customers were waiting up to 2 1/2 months just to get parts i stopped doing any work for them. if it were me, i would take both the washer and dryer back and buy a bosch instead. much more reliable and there customer service is great
Nov 28, 2007 | Dryers
E10 error code
I had this problem, the washer/dryer stopped working while in the drying cycle and displayed e10 message. It was caused by a faulty three-way inlet valve. The solenoid controlling flow to dryer condenser proved to be open circuit. Pulled washer out from under counter top, unplugged, removed top cover, tested solenoid circuits with ohm meter and found one solenoid was faulty. The filter going into the unit was clear. Replaced whole three way component with one ordered on Internet and all now works fine. Noticed that during drying cycle, water to condenser is constantly being switched on and off, explaining why the green condenser solenoid is the one that wears out first.
Mar 03, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Whirlpool GEW9250 Electric Dryer Logo
78 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
