Home | Air Conditioners | Intertherm fur...
Air Conditioners
Problem for Air Conditioners
Generic problem for all Air Conditioners
Intertherm furnace..not working right
By mcrowder on Dec 12, 2007
not sure what is wrong with my furnace....but when it is on but not running...it emets (sp?) heat and smells of burnt dust. Has been working properly until yesterday (12-11-07). Can someone please tell me what might be wrong with it....
Same Problem
Jan 21, 2008
-   When the thermostat is turned to "HEAT" the compressor kicks on and a slight burning smell emits from the air return but the blower never turns on. When the thermostat is turned to "OFF" for several minutes following and then back to "HEAT" the blower occasionally turns on for a couple minutes before again shutting off leaving the compressor running and releasing the burnt dust smell.-   Guest
Best Solution
posted on Dec 13, 2007
Very Helpful)
peyton32034
Rank: Guru
Rating: 92%, 359 votes
if i understand your problem description correctly when power is on but the furnace is not running you can smell burning dust and feel heat? first thing i can think of is possible a heater relay has gone bad keeping the heater on all the time but no fan...
Was this helpful?
Yes
No
Popular Solutions for Air Conditioners
Questions and Unsolved Problems for Air Conditioners
Answer
Our Quality: We believe that our customers should receive the highest quality Hp dv1000 battery at... (More)
Answer
we were going to purchase 2 fujitsu split systems, but have just had a offer of buying LG instead .... (More)
Answer
can't get my dometic a/c or the furnace to work fuses are good how do you trouble shoot a remote .... (More)
Answer
can not see screen, and do not know how to change battery
Answer
Model Number LBUK3660BL Ceiling Duct AC keeps tripping the switchboard. The switch is not RCD... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Air Conditioners:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
