Question about Philips PSS110/17 MP3 Player
Phillips pss110/05 worked fine, decided to change music stored on it.connected it to my computer then had to stop so disconnected properly. now it says on the screen upgrading firmware... now it won't do anything not even reset
  • Anonymous Dec 08, 2008
    Hey, my PSS-110 is a little funky. It seemed perfectly normal. I plugged it in, it showed the name 'PSS-110' in my windows media player as soon as i plugged it in. But then, after i put songs on the sync list, and clicked to start sync it went through regularly, taking time to sync evrything. Then it finished, and said i could disconnect it. It always goes perfectly normal. Plus, when i plug it into the computer and access its' files from there, the songs are there. But when I check the device, it only has the songs that came with it, even though the computer shows the files that i uploaded onto it, as part of it. I didn't use the cd i don't believe. But now that I went to go do it i remembered i had it in a big CD case that was stolen from me. Could i get the CD online, or some help please?
Give me the link to get the cd for th mp3 player
Posted on Feb 20, 2008
Oh God I had the same problem - pointless trying to work out what the cause is, easier just to re-install all the software, connect the device and restore it using device manager. Still couldnt get it to work but having read jpwadd's note about selecting pss110 instead of flash from the settings box was the key - thanks! interesting really as I never had to do this before - the computer I used when I first bought this used win2000 and I think the musicmatch portable device defaulted to pss110 whereas newer operating systems show the flash - cant think of any other explanation. once selected I dragged and dropped tracks from the playlist instead of using the 'send to' command. works fine now after hours of frustration!
Posted on Jan 09, 2008
Hello, i found the original cd that came with the mp3 player, uninstalled musicmatch and pss device manager, disconnected from the internet and reinstalled everything on the disc. i then reformatted the device and had to go into settings on the portable device option in musicmatch and selected pss 110 rather than flash. the device works now although i had to select the 'add' from portable device rather than sending to it from musicmatch jukebox.
hopen it works for you. you may have to keep selecting the pss option as it seemed to re-set itself as a flash device a few times. john
Posted on Jan 05, 2008
  • Gordon Nov 21, 2011
    Worked a treat, tho I must have had older software as the firmware required upgrading so I could select the PSS110. Thanks Gordon
How do i upload songs
How to Upload Songs to an iPod: (You can also find the instructions here.)
1)Download the latest version of iTunes. It is free and you can obtain it from the Apple website. It could have come with your iPod on an installation CD. Makes sure your computer meets the requirements. You can find older versions on the web, but they have limitations.
2)Scan your computer for songs to add to the library.
3)Connect your iPod to your computer with the USB cable that came with your iPod. The iPod screen should say "Do not disconnect".
4)Open iTunes. Your iPod should appear under Devices in the bar to the left.
5)Follow the instructions for naming your iPod and changing the initial settings if the iPod has not been plugged into a computer before.
6)Buy music from the iTunes music store or import songs off a CD using iTunes.
7)Decide whether you want to sync your iPod with your iTunes library or manually put songs on your iPod.
(Syncing your iPod will automatically add all of the songs in your library to your iPod. It will also delete any songs from your iPod that are not in your library. Click on your iPod icon and select Sync in the lower right corner.)
8)If you do not want all the songs in your library on your iPod, make a playlist of all the songs you do want, or decide which playlists you want to include on your iPod.
9)Click on your iPod icon.
10)On the top bar, click on the button which says "Music".
11)Make sure the box that says "Sync Music" is checked, then check the box for whether you want your iPod to sync with the entire library or selected playlists. If you click selected playlists, select the playlists you want in the playlists category. For newer iPods you can check which artists are included on your iPod to automatically import all the songs from each selected artist onto your iPod.
12)Properly disconnect your iPod using the eject button (see Warnings).
13)Listen to your new songs!
TIPS:
Set up the iPod on the computer you plan to use it on. An iPod set up with a Macintosh will need to have all the songs deleted in order to use it on a Windows operating system. This only needs to be done once if you switch computers, but just to make less hassle, try to use the iPod on only one computer.
WARNINGS:
Make sure you disconnect the iPod properly to avoid problems or loss of files on your iPod. Click the eject button next to the iPod icon in iTunes, or in the lower, right-hand corner. If you quit iTunes, drag the iPod icon on your desktop to the trash to eject (Mac). Right click on the iPod icon on your desktop on a Windows PC.
Things You'll Need:
- USB connector cable
- iTunes
- iPod
- Computer
- Music files or CD's
Hope this information helps!
Apr 06, 2011 | Apple iPod MA446LL/A MP3 Player
Tv worked fine then i connected my computer to it still worked fine ,, when i disconnected my pc my tv stopped working when i change channels all i c is different colors and no sound
Try reinserting the interconnect cable into the TV several times. Sometimes these interconnect cables have built in switches to indicate that a cable is plugged in. The contacts stick and prevent the video from passing thru. Reinserting the interconnect cable can restore proper operation of the TV video. Hope this helps.
Jan 13, 2010 | Sylvania LC195SLX LCD TV
My phillips GoGear SA6185/02 just freezes when i plug usb in
disconnect it. Turn it off. Then while holding the menu button plus it back in. This will make the screen go white about the splash screens. Your computer will see the hard drive and the device will not sync. Remove all the media and the data files. Plug back in and I was good to go.
Jun 24, 2009 | Philips GoGear SA6185/37 Digital Media...
Iriver Clix 2 8GB connecting to PC problem
Usually it have to, but if is not use iriver plus software !! or see if u have drivers properly installed.
Apr 28, 2009 | iRiver Clix Digital Media Player
Gogear mp3
Run the Update tab in the Philips Device Manager - make sure you are connected to the internet before performing the Update.
-Tha Mp3 Doctor
Dec 28, 2008 | Philips GOGEAR SA6045 MP3 Player
Kinda frozen just weird
I got the same problem with my old sansa. All i did is return the product with the facture to the store and they gave me a new one.
Apr 26, 2008 | SanDisk Sansa e260 MP3 Player
My iPod stopped playing through speakers- but only at work...
Esmurfette
First things First!
1) check on other speakers to see if your iPod work fine
2) check connector for loosing electric connectivity.
3) check with your headphones to see if your iPod play music well.
4) Check, power on the computer spk. you got. or the input that is working right.
Good Luck
Jan 29, 2008 | Apple Logitech Inc MM50 Portable Speakers...
Computer doesn't recognize unit when connected
I am guessing there is a problem with the driver for the audio player. I have a Coby Audio Player MP-C827, and one day my brother decided to just remove it from the computer without correctly stopping it. Ever since, whenever I plug in it into my PC, it just does not open...nothing happens. And I don't have the cd to re-install the driver files. With respect to all of the above, a driver file which is needed by the mp3 is either damaged or corrupt. Contact me at ramone.williams89@gmail.com
Dec 29, 2007 | Coby MPC-848 MP3 Player
Philips PSS110/17 MP3 Player Logo
656 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
