Question about Coleman 805D712T
Coleman a/c I have a coleman a/c unit for a camper. The problem is i can get a swith for it. The switch has 4 positions and a off position. Fan on high and low only and it also controls the a/c on max or normal. The wire that come off the switch is 1 black, 1 red, 1 blue, and 2 orange. I know one of the orange wires come off the thermistat. What kind of switch or switchs will i need to make the a/c work and also just the fan to work. I need to know what wires need to be hooked up to what. Thanks for your help Jason.
  • 24 Answers
Black= power wire - red= power wire+ blue= a/c control orange#1= thermo orange#2= common
Posted on Dec 13, 2007
One day my RV Coleman ac just quit running on low cool but every other setting works fine. Any ideas?
Is your Air Conditioner run with a wall mounted thermostat or the ceiling pack controls? If it is the ceiling pack controls, then your selector switch has gone bad and needs to be replaced. This is located in the ceiling pack itself and is relatively easy to do. You can easily test it with an Ohmmeter, going through these steps:
To check the selector switch, remove wires from the terminals
and rotate the switch to the proper position and read
continuity as follows:
Terminals Switch Position
L-1-3 Lo Heat
L-1 Lo Fan
L-2 Hi Fan
L-1-4 Lo Cool
L-2-4 Hi Cool
* If you do not wish to remove the wires from each terminal,
disconnect the 9 pin plug from the a/c unit.
Hope this helps,
Jun 27, 2009 | Coleman Mach 15 Air Conditioner
Unit not cooling on medium or high fan
pls if you change the fan speed from low to meduim or to high on cool position and the compressor stop non these two psitions means the selector swith must be changed.
Apr 28, 2009 | Whirlpool ACQ108XL Air Conditioner
Re: wiring the FV-08VKS1
The black and white in the fan box are the main power and neutral for normal (low speed) of the fan. The two reds are the signal wires. It is basically a switch loop. You will actually need a total of 4 conductors (plus a ground) in order to run the high and low speed of the fan. The four conductors consist of 1) power from one switch to power up the fan, 2) neutral, 3) signal going to second switch, 4) signal going back to fan from second switch in order to run high speed. Without four conductors you can still run the high speed only by tying the two red wires in the fan together. This would be like always having the second swith in the on position. Hope this helps.
Jan 05, 2009 | Panasonic FV-08VKS1 WhisperGreen Ceiling...
I have a 1993 yellowstone camper with a coleman wall thermostat. on the bottom of it- it has a heat/cool switch on one side and the other side has a low-high-fan switch. when we run it on low or high it...
These unit are set up for continuous fan operation when turned on. It does not have an automatic position on your thermostat such as in your house. Set the fan speed to what you are comfortable with and let the thermostat control the temperature.
Jul 21, 2008 | Coleman Heating & Cooling
Coleman tsr mach 3 RV Air Conditioner
I don't think you need a new one just a good cleaning and service. The unit has a liquid high temperature line near the compressor with a fan blowing outside air across it this coil gets clogged over time with air-borne dirt and pollen and leaves and such and must be cleaned regularly or the unit will be unable to remove the heat from the coil and during the peak demand (3pm) the circuits that protect the compressor and the trailer wiring from being overloaded and burning or melting will trip. From what you have described it sounds like the RV is working as it should with a condenser coil that needs to be cleaned. GL and happy camping!
P.S. I've only serviced the occasional RV unit but in those cases I laid a piece of plywood on top of the Rv for work platform removed the retaining screws from the top cover and used a spray bottle with a good heavy foaming cleaner a shop-vac and a brush to get the job done.
Jun 11, 2008 | Heating & Cooling
the fan motor bearings need lub....the shaft has a tiny access hole to put some oil into. because the fan shaft is slowing down, it is putting more strain on the voltage current, and eventually the internal breaker shuts down the your condenser is not getting enough air accross it, compressor heats up, and it too will shut the unit down......older units have to be oiled every year, and eventually it too will fail, and a new blower motor assembly is needed or replace the ac unit.....blower motor units are around $ you install it or pay to have it done at around another $150 labor,,,,,try yourself, if it fails then call the tech........let me know
May 20, 2008 | Coleman Mach 15 Air Conditioner
Need switch for colman a/c unit
jason, if you are willing to to a little wire tracing, you can do this! We're going to create a new switch function. Chances are that two of the wires are probably for the fan motor (high and low). I'm not sure about max and normal. This uses a two position switch. Figure out which wires go where...then...get a '3 way' switch from the hardware store (they contain a common and two 'poles') along with a plastic box to contain them, a double switch cover and some 'heavy duty zip cord'. This is lamp cord but a heavier grade called number 16 or number 14 (14 preferred). Extend each of the wires and tape the connections. Now, threading the wires into the power box, hook the two fan wires that come to the switch to the new switch. Now, the common terminals and the power supply wire (probably the black) should be hooked together. It should all work...ugly but functional. If you need an on/off switch, you can make that a three gang box and include a standard on/off switch. If you can figure out the max/normal function, you can either switch it on or off or either/or...depending on the switch function. Hope this helps.
Dec 12, 2007 | Coleman 805D712T
Coleman 805D712T Logo
63 people viewed this question
Top Coleman Coffee Makers & Espresso Machines Experts
Are you a Coleman Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
