Question about Dahle 20606 Shredder
Motor reverses paper will feed half way through, then motor reverses on its own.
Took the circuit board out, blew dust, reconnected all the wires then plugged the unit back in. it is working ok
Posted on Feb 22, 2008
Paper stuck in feed slot
The usual process is to run the shredder in reverse, and the half shredded paper comes back out of the slot. I guess you have tried this and it did not work? Next step is to dismantle the cover and clean out the shredder blades with a small screwdriver and/or tweezers.
May 18, 2014 | Epson EPS1200X Shredder
Canon ip2600 won't feed paper
I fixed mine!! I cut a letter size paper in half lengthwise (so it was skinny and long). Held the printer on my lap with both top and bottom trays open. I noticed the white pegs and skinny black roller inside were turning when I turned it on, so I waited til they were spinning and slid the paper between them along the right side. (Kind of a reverse feed). Had to do it between the crazy ink returns. Yes, the paper crumpled a little, and I did it a couple of times with a couple of papers. Something gave, because after that it started feeding properly again!
Oct 10, 2011 | Canon Pixma iP2600 Photo InkJet Printer
I have a Royal 7X Shredder which has developed a problem recently. The motor appears to try and run when paper is inserted, but the blades will only cut a 1/4 inch. The paper will not feed down into the...
I would definately say that you ahve some sort of jam in the lower half of the unit. If this is not the case, and you can see through it from bottom side up, then you have a belt slipping. There are 'toothed' belts that drive these. Most people call them timing belts, if you can get a hold of one or make sure yours hasn't come loose, I would.
Jun 27, 2010 | Office Equipment & Supplies
Xerox XD100 paper jamming every time.
The fuser is the problem. Most likely the fuser will need to be rebuilt or replaced.
Google a business called The Parts Drop. they have either the parts or the unit.
You may just have to take the fuser out and remove a badly jammed piece of paper in that module.
Shut the machine off for a half an hour. Remove the back cover. You will then see on the left side a black plastic bracket with 3 plugs on it. Disconnect those 3 plugs. Then open the right side door and toward the top is the fuser. It has yellow caution HOT labels on it. There are 2 silver phillips screws holding it in. Remove the screws and then remove the fuser unit and see if there is a paper in there. There are 2 screws that you can remove and the fuser will kind of fold open to inspect for bent fingers or one out of place.
Mar 30, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
Motor and cutter do not rotate - strip cut model
Soak the clog with dishwashing detergent and a little bit of water overnight. This should dissolve the paper.
Jan 07, 2010 | Fellowes Manufacturing C220 (Strip-Cut)...
Auto shred not working. Paper had been jammed it it, but I was able to remove it using the reverse option. Reverse works.
revers usually always works, i could be that the paper sensor is not working. there is usually a light beam or other mechanism that senses that paper is in the feed if this is not activated it will not start the motor.
Jan 01, 2010 | Office Equipment & Supplies
I have been using my shredder heavily in the last 30 minutes. I have had to stop twice for it to cool down. It was working fine, and now it won't accept paper. The cutters are turning fine. It is not...
Most shredders don't recommend use for more than 20-25 sheets in a session. Try using the reverse setting; even though you can't see paper, it's possible that there's some still in the feed channel. If after switching to reverse paper comes out, inspect the feed channel for more paper and clear any you find before trying to feed more sheets. Also in the future, constant use as you've described will burn out the motor.
Nov 16, 2009 | Tech Solution TS-4500 Shredder
Tech Solutions shredder Only powers in reverse w/ green light
Their are sensors on top and bottom of cutter asm. Good chance one or more are dirty, blocked with paper shreds or just bad. Clean with compressed air and lightly moistened cotton swab.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Jun 01, 2009 | Tech Solution TS-8000 Cross-Cut Shredder
Paper doesn't feed
It could be a few things, but the times I've had similar problems it was either caused by the feed/gripper rollers in the paper trays being worn out, thus not feeding any paper or feeding half a sheet and then jamming.
Or, it could be that the elevator in your paper tray isn't lifting, but if it's taking paper it's probably the rollers.
Jan 12, 2009 | Canon Office Equipment & Supplies
Shedder one works
This is an issue with the paper feed sensor which may be a electronic eye or a mechanical switch if it is mecanical you may just have to jiggle the switch a few times, occasionally paper may get stuck behind it not letting it activate. If it is electronic you have bad sensors or bad pc board and you'll have to contact the manufacturer for further info.
Mar 07, 2008 | Aurora Global AS501X-MS Shredder
Dahle 20606 Shredder Logo
Top Dahle Office Equipment & Supplies Experts
Marvin
Marvin
john h
Are you a Dahle Office Equipment and Supply Expert? Answer questions, earn points and help others
