Question about GE 46GW945 46" Rear Projection Television
Ge oct 1997 46gw945
Tv has short or something started turing off after about 20 mins, wont turn on with power button in front but can push volume button and will turn on? please help?
  • Anonymous Dec 19, 2007
    tv wont turn on at all i have tryed to pluge an unpluge it use remote an stil wont turn on even try it with out cable box still nothing
  • 50 Answers
I THINK YOU HAVE A BAD KEYBOARD--SOMETIMES THE KEYS STICK AND IT COULD CHANGE CHANNELS ,VOLUME GO UP AND DOWN,TURN ON ,OFF ETC.......GO TO A LOCAL SERVICER AND SEE IF HE CAN SELL YOU A USED ONE --YOU' LL KINDA SEE WHATS INVOLVED TO REPLACE--YOU MIGHT WANT TO TACKLE THIS IF TECHCANALLY SMART---ONE OF THE TRICKS IS TO "NOT TO BREAK THE OLD ONE WHEN REMOVING"" BE CARFULL...
Posted on Mar 22, 2008
Turnitoff
Generally you will turn the key counterclockwise to the lock position. This will shut off the vehicle. If you have a push button start try pushing the start button.
If you are referring to a dome light try pressing up un it or look for an on off switch. Radios can generally be turned off by Turing the volume knob counterclockwise, pushing the power button, or pressing a power button.
Hope that helps.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Nov 16, 2014 | Cars & Trucks
Push power button and it wont beep on
Sounds like the electronic control is bad but check your power supply first
Feb 01, 2014 | GE Profile Harmony DPGT750EC Electric...
TV wont turn on sometimes. push the on button, light turns from red to blue but no display or sound. If I disconnect the power cord for 15-20 min and plug it back in to the tv it will turn on and stay
My Samsung started doing that and it got worst and worst. Searched the web and find answer. It was the high voltage circuit. All TVs now are like computer and it check for 390 to 400 volts and if it is below, the TV will not turn on. Good thing the Samsung has only one capacitor showing the high voltage circuit. Measure the voltage was 381 volts. The capacitor was rated at 100 uf at 450 volts. From some old TV and power supply, got two capacitors rated 150 uf and 220 uf both at 400 volts. Had to connect them in parallel and took out the old capacitor. Now, my TV works fine.
Nov 03, 2017 | LG 42LG30 42 in. LCD HDTV
Bush lcd42f1080p100hz remote will not turn tv on
I had come home about a week ago and pushed the power button from my remote but my tv did not respond. So I just went to the front panel and pushed power but once the tv turned on, the volume was on full blast! I used the front panel volume decrease to get the volume down, but when I stopped pushing the button, the tv increased its volume to full blast again by itself! Naturally I just turned the tv off for a few moments. I tried the remote again, no response again, so I used the panel power button. The tv volume was still full blast when it turned on but after I decreased the volume it stayed this time. The picture is and has been perfectly fine and the tv was working fine. The next day the problem started all over and now once we turned it off from frustration of having to manually use the panel to change channels, it now will not turn on at all. I have changed batteries from my remote, reprogrammed my remote, pushed system reset several times, unplugged it for a while, bought a new surge charge, and even held the menu and device panel buttons for 10 sec and tried to turn the t.v. on again! What other options do I have or what may be the issue at hand and possible parts that may need to be replaced?? Thanks!!
Nov 02, 2012 | Televison & Video
I have a GE 52 inch projection screen TV. I have replaced three CP's: 150, 114, 120. I also replaced the flyback. The TV worked only a couple of times. I turned it on, then off, and right back on. I only...
You can start with resolder deflection board around Hori output, coils and Big diodes also make sure 2 ribbon connectors are pushed in correctly and in good CK Both Ribbons .
Mar 24, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
Need to reset washer it is stuck in mid cycle and wont continue nor start over
doesnt this model have the cancel button by the start button.......if so........switch on then hold cancel for 10 seconds...........
cheers
Jul 24, 2017 | GE WBVH6240F Front Load Washer
GE 32GT740 wont turn on
odds are high volt  circuit gave up. 100 150 repair 5yrs not worth repair.
Nov 22, 2008 | GE 32GT740 32" TV
Older GE television sound trouble
The first thing to check is the push button assembly maybe the volume down button has been pushed in too hard/far and is always making contact,sometimes when we clean the face of the tube water drips down in thru the edge of the frame in the buttonts,corrosion sets in and creates a short,if you are familiar with tv service you can chech the buttons thru the inside to make sure they are not pushed in but if you are not famliar be safe and call for assistance froma servicer.
Oct 11, 2006 | GE 32GT740 32" TV
Volume keeps going up by itself
help the volume on my tv keeps going up and no one is touching it! please help. my parents cannot afford a new tv
Mar 29, 2006 | Apex Digital PF2025 20" TV
Televison & Video Logo
79 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
