Computers & Internet Logo
Posted on Sep 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can't see some light colors using this moniter. For example, in Facebook, there are blue boxes around comments. I can't see those at all. I've tried messing my settings, but haven't really been able to sort it.
Anonymous
Level 2:
  • Expert 53 Answers
  • Posted on Sep 17, 2009
Anonymous
Expert
Level 2:
Answers
53
Questions
0
Helped
14706
Points
183
Try uninstalling and reinstalling the video driver
My Acer moniter (P244w) has recently begun to show different colors (red,blue, etc) print. Is it the moniter or something that I can correct on my PC?
This could be a result of multiple different variables. If its a CRT monitor, it could be magnetic interference that is causing it. On an LCD screen, it could be your video signal. Check the cables and make sure they are plugged in tight. Check to make sure there are no power lines or magnets around the monitor as well. Turn off any lighting in the area and see if that affects the monitor. Also you can test the monitor on a different computer to see if you get similar issues. If so, then you may need to replace the monitor or it's cable.
1helpful
Beamerproblem! I've got a red-color problem with
Take it to GameStop. They can find the problem lickety-split!
My moniter is showing no signal with 3 colored stripes g on green r on red b on blue. I have a wireless logitech mouse and keyboard and the reciever is not showing the 2 green lights meaning its on. Do I...
ok your monitor is a separate issue and start by checking the blue signal lead from the back of the monitor because for some reason the monitor isn't getting any images to show
What kind of house does smurfette need in smurfville?
I think you are SMURFFED. Bad! Get a color sample and go change the shade of blue.
1helpful
What color plug where i ve got three colors blue,red,black
If I understand correctly, you are replacing a switch with the EJ500 timer.
You mention a 'plug'
The EJ500 has 3 wires: Black Red Blue.
If you are replacing a single-pole switch:
The switch has 2 wires, one of these wires is the Hot-from-breaker and the other wire goes to Load:
Timer-black connects to Hot-from-breaker.
Timer-blue connects to wire-going-to-Load.
Timer-red wire is capped off. Red is not used for single pole switch.
If you connect wires and your lights blink, then you put the red wire where the blues wire should go.
If you connect wires and lights do not operate, try reversing the blue and black wires.
I posted images of EJ500 wiring (the Intermatic EJ500 and ST01C have identical wiring
http://waterheatertimer.org/ST01C-program.html#ST01C
If you are replacing a 3-way switch, the wiring is more complicated.
The EJ500 can not replace a 3-way switch wire-for-wire.
Diagrams on link above show wiring for 3-way.
Add a comment if you need more help.
Moniter very lightly flashing
Problem was not solved. I am returning to Samsung. Thanks.
Screen color problem
Some circutes are not working properley so please go to your nearest service center otherwise call to the moniter service center
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
