It can be repaired, but usually water-damaged cameras are either worthless or VERY expensive to repair. I should expect that yours is destroyed, since Nikon's D200 is not designed to be waterproof, and has many electronic and steel parts which are very susceptible to being destroyed by the infiltration of water. A good camera shop would give you an estimate for no charge. If they tell you that it is beyond repair, you might take it to another shop for a second opinion. Is it possible for you to claim the damage on any insurance? You might check with your insurance agent just to be sure.
Comments:
Dec 20, 2007
- Imrna,
I don't know what further you might expect anyone to tell you, without actually looking inside the camera. I'm sorry to be the bearer of bad news, but a camera simply isn't designed to be immersed in water. Cameras that are will be very expensive, because multiple controls and access points have to be sealed thoroughly and that becomes expensive due to redundancy built into such seals.
Dec 21, 2007
- It may have some value to a camera repair shop (check with your local camera shop), but I doubt it. Most any repair to a camera would involve only new parts from Nikon. I've had cameras destroyed by water, one of which was a very valuable antique, which I now have on display in my home, simply because it is too beautiful to simply throw away. Again, I'm sorry that you have this bad news, and wish that I could help you more. Have you taken it to your camera store yet? It might have less damage than we think, but you won't know until a professional takes a look at it. As I said, a reputable camera repair shop would give you a free estimate.
Was this helpful?
Yes
No
Popular Solutions for Nikon D200 Body Only Digital
Can't use bracket button when both Raw and Fine setting are selected...What do I have set wrong in...
(More)
Can't use bracket button when both Raw and Fine setting are selected...What do I have set wrong in my menu. I have Reset the camera but still can't use bracketing. D200 body ?????
Hi my Nikon D200 shutters every time I turn the camera and some time before you press the shuttre...
(More)
Hi my Nikon D200 shutters every time I turn the camera and some time before you press the shuttre release button how can I stop this
The "S, CL, CH.." spindle of my Nikon D200 seems to have slipped about 90 degrees to the...
(More)
The "S, CL, CH.." spindle of my Nikon D200 seems to have slipped about 90 degrees to the left - ie when set to S, it is like it is on the open shutter mode, and it twists backwards from S not forwards to CL when activated. How can i get this back to read properly? While the camera is still functional, its not ideal. Thanks for the help!
