Question about Xerox Phaser 6250DP Laser Printer
I keep getting a paper jam, and, when I can print, the right side of the TEXT ONLY is faded out...
...images come out fine. There is also black powder on the outside of the cartridge.....???
Thanks you!
  • 2072 Answers
SOURCE: xerox Phaser 6120 color problems
I am running this one and I perplexed by what your saying.
Although I will offer some ideas.
I am running through my mind why the label would only affect the colors.
So some of what I am saying here is thinking.
That is a carousel color printer, and the label is confusing me, mainly since you said black is fine.
I can understand one color being off with the third party toners, but not all 3.
What you are having in some way has to be a contact issue, as if a piece of the label would up on a ground contact.
I would first try removing the transfer assembly, all the toners and the imaging unit, and carefully inspect for another piece of label.
Look at all the metal contacts on the cartridges and internally to the machine, see if one is dirty or somehow bent.
Go into you menus and run a color calibration series, and also do a memory clear, and NVM/NVRAM reset. But before you do any resets print out a configuration page to confirm your addressing if your using an Ethernet cable.
USB wont make a difference.
The reason I suggest the resets and calibrations is the label could have caused some high voltage arching and therefore corruption.
But, then again, why wouldn't that affect black and white. What does black graphics look like?
This one is making my mind spin.
Calibration makes sense because you say you have wrong color substitution, yet doesn't address streaky appearance That to me suggests a bad ground contact, But why only bad in color LOL.Ahhhh you have me nutty with this one. LOL.
I keep migrating back to software corruption or mis calibration.
Let me know if this makes sense or helps. Reading your problem makes me want to see this one.
Anyhow let me know if my rambling, which is rare helps.
Posted on Mar 14, 2008
  • 40 Answers
SOURCE: Kodak Easyshare 5100 Wont Print In Color Or Black
For all of those problems, you need to replace the Printhead. This is one of the most common issues among the Kodak All in One Printers, they simply stop printing text. However, it seems that Kodak is sending out some new printheads that work so much better, so you should get in contact with their support and have them replace their printheads. Call cb_transparent_l.gifus.gifspace.gifspace.gifarrow.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gif1-800-421-6699cb_transparent_r.gif.
Posted on Nov 20, 2008
Joed911
  • 4338 Answers
SOURCE: My kodak 5100 printer is having problems printing black text
Clean the printhead, then print a demo sheet.
  1. Verify that inkjet paper is loaded in the paper trays.
  2. On your desktop, start the KODAK All-in-One Home Center, then select the Help [?] icon.
  3. From the Help menu, select Maintenance, then select Printhead Cleaning. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows a steady green, press Photo and Copy simultaneously to print a demo sheet.
If the Demo print is bad- IE: no black, blurry print etc., then you may need to replace the printhead:
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/printhead/AUR1780-9_UE_RevC.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Jan 02, 2009
deepfunktion
  • 18 Answers
SOURCE: My printer won't print black ink even though the cartridge is full
try to clean the nossles with software from the manafactures website
Posted on May 06, 2009
  • 4 Answers
SOURCE: My Samsung CLX-2160N will not print black and
See answer posted by Loki
Posted on Jul 07, 2009
Faded print on right side of page. When I copy/print in black, why is the black print faded on the right side of the paper?
Your toner cartridge may be the culprit.
Take the cartridge out and shake sideways and up/down. Reinstall it and try again.
If it's still printing faded side, replace the cartridge.
Jul 30, 2014 | Brother MFC-9840CDW Laser Printer
Printing laserjet fades from left to right on text only
Anthony try removing the cartridge and gently tilting backandforth a few times. Re-install for good news!
Mar 12, 2014 | HP LaserJet 4650 Color Printer
Ink smudge on right side of paper
Chances are high that the process of clearing the jam has resulted in ink being released from the cleaning/resting pad area based over on the right hand side (where the printhead sits when not in use).
This waste ink has probable come into contact with the rollers and other parts over on the right edge of the paper.
You'll probably see this ink slowly fade out and disappear over time. If it doesn't however there's something effectively feeding things so check the resting pad for a loose tube, overflow, puddles, etc...
If there's anything like that, report back (preferably with images).
Jul 21, 2013 | Epson Office Equipment & Supplies
Hi when printing black or grey outside edges
sounds like your black toner cartridge is getting low or not filled evenly. To fix this until it get a bit lower on toner just take the cartridge out and holding it up right give it a few shakes side to side. The will spread the toner power out inside and you should be printing normally again.
This can also happen if you moved or bumped the printer. Usually you only see this when the toner is low or after you print a lot of pages. Most text is in the mid of the paper so thats where the toner get s used the most.
Oct 23, 2009 | Samsung CLP-350N Laser Printer
I have fading on the right hand side. Printer Dell 3100CN
Dell printers are junk. But you have put a lot of money into this thing. Check the alignment of the black drum, could be that something is keeping if off track a little bit.
May 26, 2009 | Dell 3100cn Laser Printer
Samsung CLX-2160, keep getting faded toner stripe down page. changed toner numerousof times The same problem occurred for me after only 300 pages. The black color on the all prints is faded out on the...
Everyone will tell you that it's the Imaging Unit - happy to say that's not true. If it was the imaging unit the colors would not come out right either. I bet if you print a test page that all the colors come out fine across the page. It's only the black.
Also - if you replace the black toner cartridge, or reinstall your printer and drivers like some people will tell you - still no results.
The problem is in the black toner cartridge PATH inside the printer. Something has jammed it up a bit. Try taking out the black cartridge and blowing firmly into the small hole at the bottom of the spout that looks to have a sponge inside. Use a straw and make sure your air blown is dry. Then lightly tap the cartridge a few times. Then use the straw and once again blow very firmly inside the receiving path (inside the printer) for the spout on the cartridge. Make sure you are blowing into the spout path at the bottom - not the gear drive path in the middle - as that will not do any good.
Replace the cartridge, warm up and print another black and white page. You should see that the faded out section is gone or diminished in size. If it is not gone, simply repeat the above steps until it is gone. You will see that the faded out strip gets smaller and smaller each time until it's gone. I had to repeat five times, but eventually got it corrected. Now prints like brand new so don't get discouraged.
Loki
May 18, 2009 | Samsung CLX-2160N All-In-One Printer
HI, I have a clp-300 and it is printing black only on the right side, but the left is completely washed out. it works fine when I use a color other than black
If you the image is faded and your toner supply is good, the problem is the developer blades in the imaging unit. During the normal use of the printer, there is a buildup of toner that sticks on the developer blade. The developer blade meters the amount of toner that gets to the drum that ultimately makes it to the paper. As the toner buildup increases on the blade, less and less toner that gets to the drum cause the image to fade.
To fix this problem you will need to disassemble the imaging unit and clean the blades or buy a new imaging unit. I have clean my blades and I have a document to show you if you are handy.
Jan 18, 2009 | Samsung CLP 300 Laser Printer
Epson cx4800 - will print in text mode but gives me a paper jam message in photo mode pape ris not jammed
It sounds like a driver issue. Have you tried to uninstall and reinstall the software on your computer?
Nov 02, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
May 24, 2008 | Canon BubbleJet i560 InkJet Printer
Xerox Phaser 6250DP Laser Printer Logo
181 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
