Question about Kenwood VR-405 Receiver
Subwoofer doesn't turn on
I get no output from sub (kenwood sw-303) light stays red (turns green when receiver switches on) I have replaced monster cable but no result. at receiver sub is turned on and vol is turned up. Am I missing something in the setup, is it the sub or receiver not switching? I'm stumped!
  • Anonymous Aug 20, 2008
    subwolfer want come on,think iam hooking it up wrong.
On mine...sub rumbles the whole house when i do the speaker test...but no other sound comes from it. same problem. see if it shows up in speaker test.
Posted on May 02, 2008
I felt supid this morning.
I bought a high end cable for my subwoofer.... and it did not work but a regular RCA Cable did. When I went to put the cable back in the package I saw an arrow pointing one way, I turn the cable and it works great.
Posted on Feb 18, 2008
Kenwood sw-35ht Replace with a kicker sub
I suppose you could, but you are talking about a driver (speaker) that was not designed for that cabinet size and amplifier used in the Kenwood, There are differences in speaker design besides power rating and impedance.
Jun 10, 2014 | Kenwood SW-38HT Subwoofer
Kenwood SW-32HT Subwoofer Dropping sound Yamaha Reciever
Several possible answers. First - is that the Yamaha has a fault that is sending a signal with too much power on it. And the sub detects this and switches off.
Second - either the Receiver or Sub is switching off when no audio is present. A setting problem?
Third - the sub has a fault, possible overload, and goes to standby for safety.
Jul 01, 2017 | Audio Players & Recorders
Subwoofer pops when first powered on
If the cable is really old try getting a new one. I would recommend either a monoprice cable or a mediabridge cable both are as high quality and much cheaper than a monster.
Feb 07, 2013 | Denon DHT591BA 5.1 Home Theater System...
Cannot get the subwoofer to play...all other speakers work fine...my Kenwood receiver is VR-309...the subwoofer model is Kenwood SW32-HT... I have also used the setup mode to make sure the Subwoofer is...
After making sure that your subwoofer is receiving power, as most models have their own amplifier, make sure that it actually is turning on. There is a possibility of a faulty power switch. Lets rule that out first.
Once the switch is on and the proper power connection is verified, turn your attention to the setup menu on your receiver. Navigate to the LFE/Sub output level. Adjust it up all the way. Then navigate to the crossover setting. Turn it up all the way. If the subwoofer also has it's own control panel including a crossover, turn that up all the way as well. Then with an input on the receiver that has a subwoofer output set up such as for DVD, play some audio. Or likewise you can also use the receivers' test tone capability that will pan each channel individually with a wide band pink noise signal that also includes a signal sent to the subwoofer output.
If this procedure does not produce results then send me a message including your subwoofer model and your observations of your systems' operation.
Jun 10, 2011 | Kenwood VR-309
My kenwood light is red it turn green 4 a slpit second n turn bac red n want play my subs need help how to fix it
UNHOOK YOUR SPEAKER WIRES FROM AMP/IF THE GREEN LIGHT STAYS ON IT IS ONE OF
YOUR SPEAKERS.
Dec 21, 2010 | Kenwood Car Audio & Video
I have a Kenwood kdc-mp342u car cd player installed in my truck. I have subs hooked up to it and everything was working fine until i had to reset my radio and when i reset it the "sub Level...
Subwoofer output: Hold the (AM-) button down for at least two seconds. You can do this function when "SWPRE" in is set to . The SWPRE (Switching Preout) Switches the preout between rear output ("R") and subwoofer output ("SW").
Nov 10, 2010 | Kenwood KDC-MP342U Car CD Player
AR SW-30 subwoofer doesn't switch to standby mode when off
Disconnect its input cable to see if a true lack of signal lets it go to sleep. If not, it has a bug. Otherwise, you probably have some sort of signal present on the sub cable.
Jan 17, 2010 | Audio Players & Recorders
Always turns to standby
Hi, I was able to take care of this issue by talking to Onkyo tech support. They diagnosed over the phone and concluded that the receiver set the volume for the sub way too low (-12), therefore sub was not receiving the input and was doing what it was supposed to be doing. They walked me through manually increasing the volume and now everything works great.  Good luck! I hope this helps.
Apr 13, 2008 | Kenwood SW-303 Speaker
Sw 300 powered sub woofer
It sounds like your subwoofer acts as a receiver in its own right. Many low-budget home theater systems act this way, and it may in fact have a Dolby Pro Logic II encoder in it. Your best bet is to hook up either the speakers it came with, or purchase speakers from your local audio visual store. Check its power rating per speaker (in watts) in your manual, and purchase speakers that are rated for it.
The "red and white" input you mention are RCA connectors, and should allow you to connect a source to your system. If you have any more specific questions, please post them here.
Dec 31, 2007 | Kenwood SW-303 Speaker
Sub-woofer output not working
"Sub-woofer output not working" problem, and notify you when a new solution is offered.
Press the setup key on the front of the receiver
Select the subw setting
Move the multicontrol knob until the sub woofer is on
Turn off the receiver and turn back on- the subwoofer should be on
The operator manual can be downloaded on the web site--- free
http://www.retrevo.com/support/Kenwood-VR-507-Receivers-manual/id/480ag219/t/2/
Sep 22, 2007 | Kenwood VR-507 Receiver
Kenwood VR-405 Receiver Logo
228 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
