Question about Lexmark X7170 All-In-One InkJet Printer
Right Cartridge Incorrect How can I reset NVRAM on lexmark x7170. I tried everything. Unpluging, reseting to factory default on machine. nothing. Is there buton combination to solve this?
  • 3 more comments
  • Slobodan Tomic Dec 20, 2007
    I tried with that and nothing happen! Still got the same massage :
    I tried that but I still have the same massage.
  • Anonymous Jan 21, 2008
    I have the same problem with my X7170, I get the right cartridge incorrect message no matter what I try to correct it. One time I got it to print by clearing and resetting the error message but the next time I went to use it the same problem existed and then I couldn't get it to work again after that....
  • Anonymous Jan 22, 2008
    RIGHT CARTRIDGE INCORRECT AND IS NOT PRINTING
  • Anonymous Mar 29, 2008
    I'm having the same problem with my X4580 wireless printer. It reads Right Cartridge Incorrect, Left Cartridge Incorrect and it was printing with these cartridges so I know they are the right ones.
I prefer to buy a new color cartridge cause if you have right cartidge incorrect it means that your printer cant read the catridge. GOOD LUCK!
Posted on Jan 03, 2008
I found this on the following website
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:463:0:0&docid=ENUS25837
How to Reset/Clear the NVRAM and Language Selection on the Lexmark X7100, X7300, X8300 and X5400 Series All-In-Ones
Before you begin
Make sure your printer is connected to the PC via a USB cable.
Instructions
  1. Go to ftp://ftp.lexmark.com/driver/inkjet_drivers/Utilities/ClrNVRam.EXE.
  2. Download the ClrNVRam.EXE file and save it on your hard drive:
  3. Double-click on the fileto execute it.
Posted on Dec 20, 2007
Reset all-in-one factory defaults
On the printer operating panel, press the Options button twelve (12) times until Set Defaults appears on the LCD.
When you see the Use Factory option on the display, press Select. The printer should now be reset to the default settings.
Be aware that this will not clear up any issues related to problematic ink cartridges ink levels...
You can fix that issue by doing the following: just put the tape into the terminal and run cleaning process the printer will tell you that your cartridge is incorrect, just ignore it and removed the tape and try to print again and it will read the cartridge as new one.
If that does not work then try ordering a new cartridge
LEXMARK X7170 INK CARTRIDGES
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Sep 12, 2012 | Lexmark X7170 All-In-One InkJet Printer
Forgot admin password
Hi, What you need to do is to reset the NVRAM. That will also delete your network information and passwords you set for the printer. Please see steps below: Method 1 (from Standard Menu): - Network/Ports -> press LEFT ARROW button and RIGHT ARROW button simultaneously -> Select NVRAM -> Select "Reinit NVRAM" Method 2 (with Config Menu): - Press CHECK button and RIGHT ARROW button while POR -> Select "Factory Default" -> Select "Restore Network" -> Press CHECK button If you have questions about your Lexmark printer, please feel free to contact us at LxkListens@Lexmark.com
Aug 24, 2012 | Lexmark T642 Laser Printer
Right cartridge incorrect. I just purchased both new black and color cartridges 32,33 for my Lexmark X7170 printer and still get the error. Help
Make sure you are inserting genuine Lexmark cartridges. If you are, please contact Lexmark Technical Support Center for assistance.
Aug 31, 2011 | Lexmark X7170 All-In-One InkJet Printer
CM 1015mfp Colors are not aligned. when printing the characters looks like 3D.
If nothing else works, you may have to manually calibrate the dials inside the mirror box. This video link will show you how. http://youtu.be/R1DIko0a1MA
This may be necessary if the printer got bumped really hard.
Aug 17, 2011 | HP Color LaserJet CM1015 Printer
Hard resetting a lexmark T630
Press Select and Return buttons at the same time while printer is powering on. Once you have the Config menu, choose Factory Defaults, then hit Select.
Apr 02, 2010 | Lexmark T630 Laser Printer
Lexmark x4550 install new cartridge but printer read incorrect
Are you using a Lexmark factory new cartridge or a re-filled / third party cartridge. If the answer is that you are using re-filled or a third party cartridge that is your failure. Lexmark does not support the use of these products in there products. In fact, use of these type of products is considered to be -product tampering and will cause Lexmark to void the printer's warranty. Please do not shoot the messenger for the contents of the message. Truth is Truth!
Jun 15, 2009 | Lexmark X7170 All-In-One InkJet Printer
Mono color
These models use a "3 colour" printing process. In other words, these printers do not contain black ink when the BC-05 colour cartridge is installed. To produce black print, a 3 colour printer mixes an equal amount of the three primary colours. This process is known as "composite" black.
As the ink in the cartridge runs out, one of the three primary colours will run out first, depending on the material that has been printed. After one of the three colours has depleted, this colour will be missing from the mixture required to print black, and the print will change colour. This is the indication that the cartridge needs to be replaced. Usually the remaining colours in the cartridge will run out soon afterwards.
Rate the solution as appropriate !
Feb 07, 2009 | Lexmark X7170 All-In-One InkJet Printer
Incorrect right cartridge
Ive tried removing the right cartridge so I can print in black, but now , once I refilled the black one, it wont even let me print black!! this is desperate; can anyone help?
Aug 09, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
This solution (RESET the BRICK - solution 1 above) worked for me!
I had a brand new out of the box Lexmark X4580 and after one or two prints I was suddenly getting a "Left Cartridge Incorrect" error showing on the Printer Control Panel and the printer would now all me to print anything.
After about an hour of trying this and that (cartridges in, out and shalen all about!) ; no avail, I tried this and hey presto, it worked.
When I removed the "Brick" power supply I left it until the Green LED had faded right out though, I dont know if that was significant or not. Fingers crossed all is sorted now!
Mar 14, 2007 | Lexmark X7170 All-In-One InkJet Printer
Lexmark X7170 All-In-One InkJet Printer Logo
1,467 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
