Question about LG LFX25960ST Stainless Steel French Door Refrigerator
Lg lfx25960 Ice Dispenser
I have the LG LFX25960. The ice dispenser is not letting the ice drops. I can hear the motor turning but the flap does not open. How do I go about fixing it? What part do I need? Is there a diagram I can look at to fix it?
Your help is greatly appreciated.
I had the exact same problem on my LG LRSC26940 and was able to fix it fairly easily. First remove the Ice Funnel by pulling down on it. Then remove the entire dispenser panel by getting your fingernails underneath and pulling out. Disconnect the electrical connecter to the front panel PCB. Remove the 4 screws attaching the bracket that the Ice Funnel connects to. This exposes the solenoid that opens the Ice Door flapper. In my case, the electrical connections to this solenoid were bad. I simply scraped the spade terminals on the solenoid off with a screwdriver and crimped the connectors with a pliers. I put it all back together and it is working fine now.
Posted on Feb 09, 2008
The door hinge on the dispenser door is probably broken -- its just a tiny plastic hook / its tricky to take it apart without breaking things -- i'd suggest calling a service man -- to diagnose the issue they'll have to take it apart. watch them do it -- then if you don't like the estimate -- decline it and then do it yourself.
Posted on Dec 13, 2007
My ice dispenser keep shooting out ice after I moved glass away. The ice comes out in handfuls.
Sounds like there is still ice in the Shute, the unit is design to clear the shute so ice want freeze in the shute. Just touch and allow the shute to clear. The shute doesn't get as cold as the rest is why this happens. There is a micro switch near the handle that might be sticking, but seldom does.
Jan 03, 2015 | LG LFX25960 Bottom Freezer French Door...
Ice wont dispense
This may be a crazy idea, but maybe the crank is getting is getting wet and freezing. You might try turning freezer control up a bit to see if it makes a differences
Jan 12, 2013 | LG LFX25960 Bottom Freezer French Door...
The trap door on my LG LFX25950SB ice maker will not open when trying to dispense ice? What can I do to solve this? The ice maker is working along with the auger.
This will usually be a main board problem. There is also a solenoid in the dispenser that may have failed but the board located behind the unit is, the most likely problem. To determine for sure, a meter will be required to make some voltage checks. To make the voltage checks at the board and solenoid can be very difficult. Making these checks can be dangerous.
Jan 16, 2011 | LG LFX25960 Titanium Bottom Freezer French...
Ice maker is not working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
iooiut
Jun 03, 2010 | LG LFX25960 Bottom Freezer French Door...
LG LSC27931st.ice dispenser flap doesnt close after ice drops
Not that this is much help, but I have the same problem with the same model.
Dec 02, 2009 | LG LSC27931S Side by Side Refrigerator
LG LFX 25950SB, the Ice Maker is not working, just hear a click
heatman101
klh
Feb 22, 2009 | LG LFX25960 Bottom Freezer French Door...
LG Refrig LFX25960SB
The service manual with the codes is available at:
LG LFX25960 Service Manual
"ER IF" show a problem with the ice maker fan motor.
Nov 06, 2008 | LG LFX25960 Bottom Freezer French Door...
LG LFX29560 Ice Dispenser
You may need a service call as the ice dispenser flap is operated by a solenoid which is controlled by a small pwb board which is located by the dispenser.
Sgt 48
Nov 30, 2007 | LG LRFC25750 Refrigerator French Door
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
435 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Mike
Mike
deecee73
Level 1 Expert
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
