Question about 2wire HomePortal® 1800HW Router (1000400212000LNR)
Connecting a netgear wireless router to a 2wire
I have talked to tech support at both sbc and netgear with conflicting instructions on how to connect a sbc 2wire dsl router to a netgear wpn824 rangemax wireless router. what is the configuration needed to have access to the internet through the 2nd router (netgear) I have been told both don't use the wan port on the second router and do use the wan port on the second router AUGHH!!! What I want to do is turn off the wireless option on the 2wire router, connect the 2wire router to the netgear router and connect one computer wired to the netgear router and one computer wireless through the netgear router. Any help with this would be greatly appreciated.
  • Anonymous Feb 07, 2008
    In have the same problem, but my router is a linksys wrt54g, I have 2-wire modem and have 2 wirelless conection, but my linksys don't have a IP adrees. thank you
  • Anonymous Jun 23, 2008
    I bought a new computer around the end of June '05 and I have been having trouble connecting the internet. What I specifically want to do is connect the internet with a router and am having so much difficulty doing so. I have tried surfing the internet on my first computer and have tried talking to computer professionals. Can anyone else help me??????????
  • 53 Answers
Before you connect the netgear router to your 2wire modem, you have to get the modem configured first. you did not include the firmware version of your modem (firmware version is found at the UI, go to, click on the system icon.) for firmware version less than 3.7, go to homeportal/management, click on configure services, uncheck enable routing, then click on submit. for version 3.7 or higher, go to homeportal/management, click on configure under broadband link, put a dot in disable pvc search, set VPI to 0 & VCI to 35, the connection type box should be direct IP, then click on submit. then go to configure services, uncheck enable routing box, then click submit. you will notice the broadband link on the 2wire modem turn orange/amber, then you have successfully set the modem to bridged mode. that way you can now connect the router according to manufacturer's instructions (or just read the manual for the netgear router....)
Posted on Apr 03, 2008
  • 556 Answers
Are the router addresses assigned on the same subnet?
many routers have a base address of and a subnet mask of meaning all addresses 192.168.0.? are part of their network.
One problem can be that both routers can be using the same subnet -- not an issue if they are connected to different connection points (such as two different houses) on the internet. However when connected to each other in your house they are confused because they have the same two different networks with the same addresses. -- for slightly different reasons --
For those that want you to connect from one router to the wan of the other you need to assure the base addresses are in different subnets -- assuming the one connected to the internet is addressed as with a subnet mask of his network as stated before is all addresses 192.168.0.?. Change the second router to a base address of say with a subnet mask of his network is everything staring 192.168.2.? they are now different and it should work. On the wan side of the router you can assign a unique 192.168.0.? address not in the DHCP range of the first router or accept a dynamic IP address from the first router. The dynamic address is probably the easier and less problematic of the solutions.
For those wanting you to connect to a lan port and ignore the wan port they should also have asked you to turn off DHCP in the second router (where you do not use the wan port) and allow the first to do all the dynamic network address assignments. In this case you could have two DHCP servers on the network competing to assign possibly the same network addresses -- if they have overlapping ranges duplicate addresses could be assigned resulting in device connection issues for those with duplicate addresses. Even in this case you may need to assure the gateway addresses are unique on the network ie of both routers are addressed as the second where the WAN is not used could become (where that address is not in the active DHCP server's assignment range) or (note the DHCP server had better be off or else the empty wan port could become the "gateway" address of attached PCs and since there is no connection there will be no access to the internet.
I hope this helps
It is quite likely either solution could work if all the proper changes were made.
Posted on Dec 15, 2007
2wire sucks balls. I suggest you throwing that **** in the garbage and getting a real modem and router.
Posted on Jun 02, 2008
Connecting Netgear USB adaptor to 2wire modem
Install the Adapter using the CD, After installing if its windows XP it will ask you to choose XP utility or Netgear utility, choose windows and scan for the network.
If its windows vista , go to start-Connect to - u will see the network name here , try connecting to it
Nov 14, 2009 | 2wire HomePortal® 1800HW Router...
Trying to connect my ps3 to the internet but need wireless route
That won't work because your old sbc wireless router 2wire gateway is also a modem. You need a plain router for Time Warner. Try Linksys router.
Sep 08, 2009 | 2wire (1000-100052-000) 802.11g/b Wireless...
Linksys wireless adapter won't auto connect to 2Wire router
Go into the wireless adapter settings and make your connection "default" and then it should connect automatically .. and if not then look for a "connect automatically setting
May 29, 2009 | 2wire HomePortal® 1800HW Router...
Connecting Netgear Wireless Router to @Wire Wireless Router
You don't need to connect your netgear, you have only to connect your computer to the 2Wire (is wireless also) - If your computer ins not wireless Only you have to do is insert a wireless PCI card in your computer or and USB wireless device and connect to the 2Wire Wireless Router
Feb 11, 2009 | 2wire HomePortal® 1800HW Router...
Can't access 2wire network using netgear adapter
I was also having trouble with my Netgear wireless n USB adapter connecting to my new at@t 2WIRE gateway. The problem was that the netgear software wouldn't allow my computer to stay connected to my 2WIRE gateway and the software wouldn't allow Windows when restarting my computer. I have Windows XP and after hours with at@t support there was no resolution and they gave me Netgear's suport number to call 1-888-638-4327. After 10 min. the problem was fixed. They had me click start icon at bottom left corner then all programs, then highlight "start up" and if you see anything like netgear adapter or netgear start up wizard right click on it and click delete. That was it! rebooted my computer and it connected automatically!!! I'm not very computer knowledgable but I hope this helped
Feb 02, 2009 | 2wire (1000-100016-002) Wireless Adapter
RE: My posted. Connecting DSL/Router to DIR-628 internet router
Installing a router to work as the second one on a home networkrequires special configuration. Do the following on the second routerto ensure it (and the devices attached) function properly:1. Connect as local device or bridge - If connecting the second router via Ethernet cable, plug it into one of the LAN ports on the first router. If connecting the second router wirelessly, ensure the second router is set for client mode.Note that some home wireless routers do not support client mode; thesemust be connected by cable. Check your router documentation for detailson its client mode configuration support.
2. Check / change IP address - Most home network routers use a default IP addresssetting. Often, these default IP addresses will not work in a tworouter environment. Check the second router's IP address value andreset it if necessary to work within the valid address range of thefirst router (and to not conflict with any other device on the network).
3. Disable DHCP- To avoid IP address conflicts between all of the devices on the homenetwork, only one of your two routers should assign addresses via DHCP. All mainstream routers provide an option to disable DHCP as part of the router's configuration screens.
(My netgear router supports client mode. The 2wire supports bridged and router mode. My 2wire is the main router. I set up my netgear using my laptop. Once you change the address on the router.. You will only be able to directly access through the main router to the 2701.)
Configure your 2701 IP address to a static address in the range and diable DHCP. Only 1 router can run the DHCP service. To disable Dhcp on the 2701.... log on to 2701> click on home network>advanced settings>uncheck enable DHCP>Next section is Public routed subinterface...Check enable and Aout Firewall Open>Input your main router address and mask>save config..
This worked with the Netgear router.. May not with your router. Good Luck! Hope this helps!
Jan 16, 2009 | 2wire 2700HG-B Router (2700HGB)
Connecting to an existing wireless LAN
Hi there you can find the instructions for connecting your netgear DG8345G wireless router to your existing wireless router by configuring first your netgear router and click to help so that you can see the instructions by configuring it into your pc or you will go to the netgear support website so that you can find that model and look for instructions for your netgear router..
Jun 25, 2008 | NetGear DG834G 802.11G Wireless ADSL...
ISP problem with 2wire 2700HG-B
When I purchased the same router on Amazon I did my best to set it up on my own, but you need the correct IP information you can only get from your customer support at AT&T. I'm using this router with an old Airport card in an 2003 iBook and a 2007 iMac (built in Airport express card). The set-up was all done wirelessly, with bellsouth (AT&T) customer service instructing me over the phone, the process took about 15 minutes.
My suggestion is to call AT&T and speak with someone who knows what their doing, and they do use the SBC global page to set up the unit, starting with for the system summary, from there you can set up your password etc...
May 14, 2008 | 2wire 2700HG-B Router (2700HGB)
Problem in reconfiguring WGR614 v5 after reset
You should configure the 2wire to a bridged modem for the autentication to work on Netgear.check with your ISP for configuring your 2wire to bridged modem
Cheers !!
Feb 24, 2008 | NetGear WGR614 Wireless Router
2wire HomePortal® 1800HW Router (1000400212000LNR) Logo
6,779 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
