posted by stevocuafter on Dec 12, 2007
will not heat up water
2 Other Users Have The Same Problem
Comment by LSH777, posted on May 06, 2008
My Ladybug 2200s vapor steam cleaner does not put out any steam. It turns on, after about five minutes the green light goes on indicating it is ready, the pressure indicator does not show any pressure, and nothing comes out the steam wand. What is wrong and how do I fix it? Am I doing something wrong or is it the machine?
Comment by Guest, posted on Jan 05, 2008
will not heat water?
Clarification Request
by reddevil6, posted on Feb 05, 2008
What brand is this, also would help to have model number.
Solution #1
posted on Feb 22, 2008
Most upright steam cleaners like Hoover and Bissell, you put in the hot water, bissell does have a heater, but it only helps get the hot water a alittle hotter. But a model number would help.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To:
Black & Decker CHV9600 Handheld Vacuum
Bosch BSG81313UC Premium Bagged Canister Vacuum
Bosch BSG71310UC Bagged Canister Vacuum
Kenmore 22812 Bagged Canister Vacuum
Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum
Kenmore 22085 Bagged Canister Vacuum
Kenmore 31912 Progressive Direct Drive Bagged Upright Vacuum
Can you Help with these Vacuums problems?
Hoover F7425-900 SteamVac V2 Widepath Upright...
leaking problem
leaking problem
I have a leak in my water tank.... Answer This...
Repair Service
Find Vacuum Repairman Near You:
