Question about HP Photosmart 2575 All-In-One InkJet Printer
Hp photosmart printer
Won't print. error code 0xb82e4cc4 on printer screed
  • 210 Answers
I had a similar problem of a senseless printer error code with similar useless help from HP for one of my client's HP Photosmart 7510. I also could not find any other relevant help online. But, while searching, I did notice a suggestion to clean the contacts. When I removed the ink cartridge carrier, I noticed a large build-up of ink around the nozzles. Cleaning out the carrier did the trick for me. It couldn't hurt to give it a try.
Follow the steps below if you need them. And, please click "Yes" below if this has helped you at all.
Remove the carrier: Open the printer to access the ink cartridges. Slide out the ink cartridge carrier if it is parked. Remove all of the cartridges. Then flip the lever to the right of the carrier. Grasp the carrier using your thumb on one side and index/middle finger on the right, both near the top, and pull straight upward. Careful, yours may be more full of ink than my client's was.
Clean the carrier: Wash the carrier in a sink with warm/hot water at various angles until all noticeable ink is cleared away. Briefly wash water directly into the carrier's induction screens which contact the sponges of the ink cartridges. This may help a little to flush any ink from the nozzles which might have dried in them while the printer was inoperable.
Remove most of the water: Shake the carrier downward (only while upright) and tip the carrier forward and side ways. But, be careful since some ink will still be contained in the carrier's ink channels. Pay close attention to the induction screens. If you tip it too far or shake while inverted, ink may splash out through the screens or drain back onto the carrier. If this does occur, repeat the cleaning procedure.
Note: Do not attempt to drain all of the ink from the channels, whether through the induction screens or through the nozzles on the underside of the carrier.
Dry the carrier contacts: Lightly wipe the tiny metallic white squares on the backside of the carrier with a dry paper towel. Spot dry the surrounding area, including the nozzle arrays on the underside of the carrier - dab, don't wipe. You should get ink spots on the towel from the nozzles. This is to be expected and is a sign that the nozzles are not clogged (at least not completely).
Inspect the carrier transport: Examine the area with the metal prongs that were exposed when the carrier was removed. Dab dry any areas with ink if you find any, especially near the metal prongs. If you discover any ink on the prongs, use a wet, but drip-dried cloth or towel to continuously dab the prongs until they are clean. Then dab with a dry cloth or towel. Re-inspect and ensure any lint or other debris is removed from the prongs.
Reassemble and test: Return the carrier to the transport, flip the locking lever to the downward position, return the ink cartridges, and then test your printer.
I hope this helped and that all goes well. Please click "Yes" if this has helped you at all.
Posted on Mar 30, 2014
  • 32 Answers
Hi -
For future refs for this type of error message, you might find this link from HP's support site helpful:
"The product displays an 0x ... error code when printing (for example Error: 0xf0af8004 ). These error codes indicate that the product has an internal condition."
It is an English document but many HP docs are translated, too.
Posted on Oct 13, 2008
  • 4,402 Answers
Go here and search
Posted on Jan 02, 2008
HP photosmart printer error code 0x61011be5
There problem with printhead you have to change it , with new one
Here how to change the print head :
Mar 22, 2013 | HP Photosmart Premium C309A All-In-One...
Won't print - d5160 photosmart. system subspooler app error
Printer Spool offline:
Disconnect the USB cable, go to RUN and type in services.msc and then find print spool and right click, then choose restart.
Start-->printers and faxes-->right click on the printer-->properties-->make sure it
May 17, 2011 | HP Photosmart D5160 InkJet Printer
Have a HP Photosmart 8050. Won't Print. In the
go on web site they will answer your question after putting in you model number of the printer you have
Jul 27, 2010 | HP Photosmart 8050 InkJet Printer
Printer stopped printing durring project "Assert Error b52b00b4"
From the HP website:
ISSUE: The printer displays an assert error code. Assert error codes indicate that the printer has an internal condition that may respond to a hard reset of the printer. Beyond that, service may be required. This document applies to the following products:
  • HP Photosmart p1000/1000, p1000xi printers
  • HP Photosmart p1100, p1100xi printers
  • HP Photosmart 1115 Printer
  • HP Photosmart 1215, 1215vm, 1218, and 1218xi printers
  • HP Photosmart 1315 Printer
SOLUTION: Hard reset of the printer A hard reset of the printer may clear the error. Here is how to perform the hard reset:
  1. Shut down the computer.
  2. Open the top cover of the printer and remove the print cartridges.
  3. Close the top cover of the printer.
  4. Press the power button on the printer to turn the printer off.
  5. Disconnect the communications, (USB or Parallel), cable from the back of the printer.
  6. Disconnect the power cord from the back of the printer for one minute.
  7. Reconnect the communications cable to the printer.
  8. Reconnect the power cable to the printer.
  9. Press the printer power button to turn the printer on.
  10. Open the top cover and reinsert the print cartridges.
  11. Close the top cover and print the calibration page.
  12. Restart the computer.
Mar 18, 2009 | HP PhotoSmart 1115 InkJet Printer
I have an HP D7360 printer. I receive the error code 0xc05d2281. can you help?
I have a HP Photosmart C6180 All-in-One printer. When I try to print I get error code Oxc05d2281 on the printer scren. I have replaced all the carriages with new one. Please tell me how to fix this problem.
Jul 31, 2008 | HP Photosmart C6180 All-In-One InkJet...
Hp photosmart 2575v all in one error code on lcd screen . Error oxb804000c.  Prints ok. Error message stays up on lcd screen most of the time. Light flashing near the card reader port ?
did a search on hp website and found over 100 hits
go here to find out what your error means
Dec 23, 2007 | HP Photosmart 2575 All-In-One InkJet...
HP Photosmart 2575 All-In-One InkJet Printer Logo
628 people viewed this question
Ben Johnson
