The icemaker will not make cubes. The water dispenser still works, but no cubes are dumped from the tray.
You might need to replace the icemaker or the freezer isnt getting cold enough for the icemaker to operate correctly. if freezer isnt getting cold enought for icemaker to operate correctly you should probably have it checked by a tech. if the icemaker isnt taking water you also could have a bad water valve
SOURCE: Ice cube dispenser not working
Not real familiar with that specific model but it sounds like the heating element isn't working to loosen the ice from the tray as it's dumped. A typical ice maker has a small heat element under it to melt the surface of the ice just slightly while it dumps.
SOURCE: icemaker and water dispenser
Mine did the same thing. Other web sites said it was the motherboard. I replaced it and now it works great. The part number is: Hotpoint Refrigerator Main Control Board Assembly WR55X10552best deal was at http://midwestapplianceparts.com
SOURCE: icemaker only dispenses crushed ice, not cubes
yea! I have been without cubes for 2 years. I slid out the tray, found the lever in the back where the rod went in, pulled it down, reinserted the ice tray, and IT WORKED! At first I thought I broke the lever, because I had to hold it down with a knife while I was inserting the tray, but it just must have been stuck. I am soooo happy!
SOURCE: Icemaker makes ice, but doesn't dump it.
If you have a steady blinking light when you open the door then the sensor is working. I these cases the problem is usually in a bad motor or thermostat in the icemaker. If you need I can give you instructions on how to change these parts.
SOURCE: KSRA25IL ice cube tray won't fill
The fill tube is probably frozen. Its in the roof of the freezer. turn off the freezer and heat the roof of the freezer with a hair dryer, being careful not to get it too hot,and it should thaw and work again. If you can put the food elsewhere for a day, just turning it off with the door open should work also.
