Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
Hotpoint fdw20p dishwasher
My dishwasher prewash and wash lights start flashing during the wash cycle but i cannot find what this error code means
  • 4 more comments
  • daisy 3435 Dec 23, 2007
    my dishwasher goes on then stops then two green lights keep flashing
  • John Porter
    John Porter Feb 10, 2008
    my pre wash light keeps flashing and it will not wash
  • Rachel1R Feb 17, 2008
    Same problem - pre-wash and wash lights flash after about 5 mins of turning on
  • Anonymous Mar 13, 2014
    dishwasher stopped during cycle
  • Anonymous Mar 18, 2014
    gu2800xtvbo whirpool dishwasher is flashing code 61. What does this mean? When I press start to wash within a minute the clean light comes on but nothing happened.
  • Anonymous Mar 26, 2014
    the dishwasher drains but the dishwasher won't start washing and the display flashes
You need the control panel to reset before anything else can happen. To do this TURN OFF THE PLUG SOCKET FIRST AND UNPLUG. Then you need to drain ALL the water from the machine. Turn off the water supply feed and place the wastage pipe as low to the floor as poss ( 1-2" off floor). Water will gush out so use a large shallow tray and keep emptying the tray. Tilt the dishwasher over slightly to make sure all the water is out.
This will allow the control panel to reset itself which wouldn't normally happen if the base of the dishwasher was holding even a small amount of water.
Re connect the water, plug back in , select the RESET setting on the dial and close the door and switch on.
Leave for about 20 seconds and then turn off.
Rotate the selector switch to "A" Intensive wash and switch
I found this on another site and it really did work for me
Posted on Feb 23, 2008
Drying light flashes after pre wash cycle
check water temperture might be to low might turn the hot water temperture up, water temperture for best wash is 120 degree
Dec 21, 2017 | Hotpoint 18 in. DC27 Slim-Line Built-in...
I have a Hotpoint SDW 60 problem! The dishwasher starts and goes through pre-wash but stops with just the 'Delicate' light flashing. Does anyone know what the problem may be?
If the original light flashing that means it indicate a fault in the heating circuit. Heater, wiring, thermistor / pcb. (Main control board).
The new flashing light, PreWash (this is the only one on my list for a fault code indication). indicates a fault with the thermistor.
You would need to check by taking the door apart that the thermistor hasn't come off it's mount by the dispenser.
You would then need access to and be able to use a multimeter to test the heater and wiring to ensure they are closed circuit.
Jul 09, 2011 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint wma34 stops and prewash light flashes
I would check the water pump for a blockage a button or other debris may be lodged in there preventing it for operating properly eric
Jan 15, 2018 | Hotpoint Aquarius WMA42 Front Load Washer
Flashing lights on Hotpoint FDW20P Dishwasher
No solution! tried resetting to factory defaults but ended up that even the drain pump stopped working. after flooding the kitchen (nearly). I decided it was terminal and am loking for a new dishwasher urgently as I type. Cheers.
Feb 18, 2009 | Hotpoint 24 in. DWF32P Free-standing...
Hotpoint Aquarius DWF50 Dishwasher, cycle not starting getting flashing ECO/Fast lights, any ideas?
hotpoint dwf50 will not start, the fast wash and prewash buttons are flashing together.
Jul 05, 2008 | Dishwashers
Dishwasher error codes please help
I too had this problen today. Printed off a manual from the Hotpoint website. Very helpful troubleshoot section. Anyway, flashing eco and fast lights and beeping sound indicates 'water feed pipe blocked' You need to check the water inlet connections on your tap.However, when we pulled it out we noticed the blue water inlet pipe was slightly kinked. Straightened this out and hey presto! It works fine again. How this happens when its worked ok for 18 months will never know but still. Try it! hope this was helpful...shewoo
Apr 26, 2007 | Hotpoint 24 in. FDW60 Free-standing...
NOT WORKING FDW20p What does it mean
Hold the start key down and it should re-set . Please Rate This ! Thanx!!
Apr 08, 2007 | Hotpoint 24 in. FDW60 Free-standing...
FDW20P Error lights.
Hiya, i have the same problem. I am getting mine repaired on the 16th Next monday Booked an appointment with Hotpoint there coming to see and fix it. I will ask about the flashing lights and if you keep in contact i will let you know Ok"
Sep 20, 2006 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
700 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
