Question about Motorola Mobility TracFone C139-4 Cellular Phone
Voicemail passcode my sister gave me her tracfone and then i lost it, i have a avery important message on there but i cannot access because i forgot password and cannot reset number because i dont have phone but need new passcode so i can access from my land line, can you help me?
  • need2know21 Mar 24, 2008
    Does ANYONE out there know a master code or reset code for this phones voice mail??? Can the pass code be change online without losing the recorded voice mails? I really need some help here.
    Thanks!!!
    Problem Solver:
  • 12 Answers
Both of these problems can be cured by calling a tracfone operator. You will not loose the recorded vioce mails that way.
Posted on Jul 02, 2008
I forgot my voicemail password. can you help me find it?
Try calling a tracfone operator. You will not loose the recorded vioce mails that way. With most providers it will usually press *, 0, or # when you hear your voicemail message come up. Let me know if that works, if not, I'll try and get intouch with someone.
May 09, 2015 | Tracfone Wireless ZTE Valet
How do I access my voicemail from another phone?
To call your Voice Mail from a landline phone:
1. Call your TracFone from a landline phone.
2. When your voicemail begins, press the star key on your landline phone immediately.
3. Enter the PIN you use to check your Voice Mail from your TracFone. When you have finished entering your PIN, press the pound key.
4. Listen to the instructions. They will tell you how many voicemail messages you have and give you options for checking them, deleting them, saving them or storing them as new messages. Phones may vary, so listen carefully to the options.
if you havent created a pass code try 9999, if that doesnt work give tracfone a call.
1-800-867-7183
Sep 19, 2012 | tracfone.com
How to check voicemail messages
I assume you mean voicemail messages taken by voicemail service on your telephone line, the ones indicated by a flashing "voicemail" indicator on the phone. You may need to contact your service provider as not all systems are the same, but here's how it usually works. From your home phone, dial your own number so that the voicemail answers. Press the "*" button and you'll be prompted to enter your passcode. (The default passcode is usually the last 4 digits of your phone number, and you enter a new one when you go through mailbox setup.) Once you've entered the passcode and are in the voicemail system, voice prompts guide you through how to access messages and make setup changes. To process is usually the same to check your messages when you're away, although some service providers may give you a different access number to call. Again, check with your service provider for all the details if your system is different.
Sep 14, 2011 | Vtech 5.8GHz Analog Cordless Phone
Employee forgot his password and need to change the voicemail for new employee. Is there a way to reset the phone. Phone model is a Superset 4025. My phone number to the phone is (563) 690-3230 or email...
Each mailbox password is held in the system programming of the voicemail system. You need the system admin password for voicemail. Dial the access code for voicemail, if from a phone with voicemail then press * to get to the main greeting. At the main greeting dial * then the system admin mailbox number which is 99 for 2 digit ext numbers or 999 for 3 digit ext numbers or 9999 for 4 digit ext numbers then you will be prompted for the system admin passcode(default 1234). Press 2 for add/edit/delete (Never press 1 for new installation or you could delete all current voicemail programming and messages). Press 2 to edit mailbox, you will be prompted for the mailbox to edit, enter the mailbox number. Press # to skip to the passcode reset, enter the new passcode or press * to reset to default(999) then press # for each of the remaining parameters until you are returned to the mailbox menu which prompts for press 1 to add mailbox, 2 to edit mailbox, and 3 to delete mailbox, then hangup.
Dec 07, 2010 | Mitel Superset 4025 Corded Phone...
I don'ty have any minutes on my phone and i have a voice mail and I wanted to know how do i check my voice mail
You can't check your voicemails from your phone. Without minutes and/or remaining service time, your TracFone won't let you make any calls. But if you turn off the phone and call it from another one, you should be able to access your voicemail that way. Press the * key when you hear your outgoing message, enter your passcode and you can listen to any messages. Buy some time for your phone before your service time expires. If you wait too long after the due date, you'll lose your phone number.
Nov 17, 2010 | Motorola Mobility TracFone w175 PayAsYouGo...
Change voice mail message from one person to another person
Step 1 Lift the handset for your telephone and listen for the dial tone. Dial the access code you were given by Verizon when you signed up for residential telephone service. Dialing the access code will call the voicemail system. If you do not have an access code, you will need to call Verizon Customer Servicemag-glass_10x10.gif (see link in Resources).
  • Step 2 Identify the telephone number you are setting up voicemail services for. If you are calling from that telephone number, enter the temporary passcode and then press "#." The temporary passcode is the last 4 digits of your residential telephone number. If you are calling from a different phone, press "*" when the system greeting starts to play, then enter the 10-digit telephone number when prompted. After this, you will be asked to input the temporary passcode.
  • Step 3 Choose a new passcode. The passcode must be from 4 to 8 digits in length. It should be easy for you to remember, but difficult for others to guess. Do not use easy to guess numbers, such as 1234 or 1111. Also do not re-enter the same temporary passcode, since it will be easy for anyone to guess.
  • Step 4 Record your name. Simply say your name, without a long complicated message. This recording is used by the voicemail system to identify you whenever you forward a message to another user. It is not used as the standard greeting when a caller is directed to your voicemail to leave a message.
  • Step 5 Record or change your personal greeting. This greeting is played any time someone reaches your voicemail box. Record a friendly greeting to announce that you are unavailable and will return all calls upon your return.
    Decide if you want to set up a different mailbox for each family member. Verizon residential telephone service allows you to set up multiple mailboxes so that everyone can have his own private message center. Callers who reach voicemail will be prompted to press "1" to leave a message for one person, press "2" for the next person, and so on.
  • Step 6 Hang up the telephone. When you have finished setting up the voicemail system on your Verizon residential phone line, hang up the phone to end the call and exit the voicemail system.
  • Nov 08, 2009 | Uniden Cordless Phone
    LG600G tracfone voicemail problems
    My recently purchased LG600G (Target $30) immediately started receiving unwanted calls that forced me to figure out voicemail. Well, when I say "immediate", I mean once I struggled through the activation process! Turns out I wasn't pressing, and holding, one of the keys. The first of many firmware issues, read on.
    Ironically, the phone is not by default setup to use the keypad for entering responses and I needed to enable DTMF tones. 9 Settings, 5 Call, 7 Send DTMF Tones. (btw, p.62 of the manual lists menu options 9.5.8 which is wrong). Select 1 then set.
    I was then able to check my voicemail but my phone still doesn't actually let me hear the DTMF tones. I also have to hold the keys down longer than other phones; it doesn't like flying fingers.
    Usually I check voicemail using a land line (or my wife's free work cell!). My local number is not my area code. For AT&T the requested mailbox is the cell number, followed by the 4-digit passcode.
    Hope this helps somebody,
    N
    Jul 01, 2009 | Cell Phones
    Retrieving tracfone by using my lan line phone.
    Oct 16, 2008 | Motorola Mobility TracFone C139-4 Cellular...
    How to set up voicemail on i phone
    <<This is straight from TracFone support for setting up voicemail on the Motorola C139....enjoy>>
    Thank you for your interest in TracFone Wireless. We are responding to
    your recent inquiry.
    TracFone Wireless would like to take this opportunity to apologize for
    any inconvenience this issue may have caused you.
    Your voicemail box has been reset. To set up and retrieve voicemail from
    your TracFone:
    Press the MENU key,
    Scroll to MESSAGE and press SELECT,
    Then scroll to VOICEMAIL and press the MENU key,
    Next scroll to VOICEMAIL SETUP and press SELECT,
    The VOICEMAIL Access Number should be: +17044089979 and press the OK
    key (if there is no + sign, please press and hold the 0 key until it
    comes up).
    If the numbers there are different, press and hold the key below the
    word CLEAR or DELETE until all the numbers disappear from the screen.
    Then enter the number 17044089979 and press OK.
    After programming the Voicemail Access Number on handset, please turn
    the phone off and back on.
    Then, press and hold the 1 key to auto-dial the VOICEMAIL box to record
    greeting and complete setup.
    Your temporary password can be 0000, 1111, 9999, the last 4 digits of
    your wireless number, or another 4-digit number easy to remember.
    All calls made to your voicemail from your TracFone will deduct airtime
    units. To avoid being deducted airtime, it is recommended that you
    contact your voicemail from a land line phone, by dialing your ten-digit
    mobile number. To retrieve voicemail messages from a landline phone,
    please follow the instructions below:
    1. From your landline phone, dial your TracFone Number.
    2. When you hear the greeting, press the star (*) key. If the star key
    does not interrupt the greeting, press the (#) key.
    3. Enter your password and follow the retrieval instructions.
    Please note, if this procedure does not resolve this issue, we would
    need to talk with you directly for further assistance.
    Should you have any further questions or concerns, please contact one of
    our customer care representatives at 1-800-867-7183. For your
    convenience, our representatives are available Monday-Saturday from 8:00
    AM to 9:45 PM EST, and on Sunday from 8:00 AM to 6:45 PM EST.
    Thank you for being a TracFone Wireless customer. We appreciate your
    business.
    Sincerely,
    TracFone Wireless
    Sep 16, 2008 | Cell Phones
    Setting up my voicemail on my Motorola C139 TracFone
    Elementary, just as you would in any other phone, just dial your number, and the phone will talk you through on setting up your voicemail.
    Jun 08, 2008 | Motorola Mobility TracFone C139-4 Cellular...
    Motorola Mobility TracFone C139-4 Cellular Phone Logo
    352 people viewed this question
    Top Motorola Mobility Cell Phones Experts
    Virgil Wolter
    Level 1 Expert
    vince
    Rami Obeid
    Level 1 Expert
    Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
