Question about Indesit 18 in. D41 Slim-Line Free-standing Dishwasher
Indesit IDL 40 Slimline flashing lights
I had a problem with my dishwasher, called and engineer, who said it was the PSB card which he has replaced - but now there are 2 out of 4 lights flashing and the engineer doesn't know what is wrong. Please help me
  • 1 more comment
  • MDavies007 Dec 26, 2007
    Indesit D41 runs constantly, circulating water, and never moves on to the rinse/drain/dry part of the cycle. The first two lights on the display flash on and off constantly.
    Anyone know a solution to this problem?
  • Doug05 Mar 01, 2008
    I have this problem as well. I've added more salt, but I still get the flashing lights.
    Does anyone have a solution?
  • Anonymous Jan 12, 2009
    Indesit IDL 40 Slimline flashing lights problem, and notify you when a new solution is offered.
The dishwasher is rinsing but not washing
Posted on Aug 31, 2009
I have the same problem as well. I have tried adding salt, but I still get the flashing lights.
Posted on Mar 01, 2008
The problem you have got with the flashing lights is that its the rinse aid or in need of more salt, hope thats sorts it for you
Posted on Feb 15, 2008
Our dishwasher idl 40 indesit has 1 and 3 flashing lights on the panel seems to be a problem
I have had this problem also and no longer take anything apart take out the filter plate pour boiling water into the well leave for 20 mins put on a 25 min fast wash and hey presto works every time. Mine seems to block up about every 4 weeks and the lights come on but this solution always works
Mar 06, 2012 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit IDL 40 slimline dishwasher does not drain completely
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Jan 05, 2011 | Indesit 18 in. D41 Slim-Line Free-standing...
My Indesit idl 530 dishwash which is fairly new has packed up with the Prewash and Drying light flashing simultaneously. I know it's under warranty but I'm trying to find out what this error code means and...
Refer the user guide for the error meaning. Switch off the machine and try.
Still the same problem contact the service engineer as this will ease your work!
May 17, 2010 | Dishwashers
Ndesit IDL 535 DW, not cycling, water coming from under unt.
The washer is fitted with an anti flood device that detects water leaks and closes water inlet valve and puts washer in pump out mode. The anti flood device is a polystireen float with micro switch at the bottom floor of the washer. Dry the water and find the leak (pipe or pipe clamp) and this should then solve the error.
Jan 22, 2010 | Indesit 24 in. IDL500 Built-In Dishwasher
Indesit idl 40 2&3 lights flash
The problem is lack of water. Check that the water is turned on at the stop **** and make sure that the hose hasn't been traped if the dishwasher has been pulled out from it resess as happened to mine.
Jan 21, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
Flashing green light on my indesit dishwasher
Put some towels dowm and tip the dishwasher over to one side about 45 degrees, if water pours out of the base it means that the dishwasher is in "flood mode" and you have a leak into the base that will need resolving.
Thanks
Dec 05, 2008 | Indesit 24 in. D61 Free-standing...
Indesit IDL 50 Dishwasher
Had a similar problem (flashing lights 1 and 2). Drained the machine by diconnecting the outlet hose and using a shallow bowl on the floor. Removed and cleaned filters. Forced clean water through by using a garden hose pipe(you can only do this one way, you cannot force water down the outlet pipe). Removed and cleaned the pump (you have to do this from under the machine but easy enough). Finally ensuring the waste trap under the sink was clear. Bingo!! No parts, no expensive engineer.
Jun 04, 2008 | Indesit 24 in. DE73 Evolution...
IDL 700
A10 2 & 4 Heating element Open circuit heater
info from idl service manuall
Feb 29, 2008 | Indesit 24 in. IDL700 Built-In Dishwasher
Indesit IDL40 Slimline Dishwasher - Won't start cycle
indesit idl 40 not pumping water out properly, ends with flashing light no 4 and plates dry but water still in machine -have to pump out using start stop button but within 2 hours base filled up with water. Can't afford massive call out prices as lady on my own.....
Nov 12, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit IDL 530 Dishwasher Prewash and Drying Light flashing
Ours was doing this and it was because there was water leaking into the base because a crocodile clip had come off
Oct 22, 2007 | Dishwashers
Indesit 18 in. D41 Slim-Line Free-standing Dishwasher Logo
1,815 people viewed this question
Top Indesit Dishwashers Experts
Eric Taylor
Marvin
Marvin
NOEL
NOEL
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
