Question about Dishwashers
Kenmore Elite Dishwasher 16939
I have the above dishwasher purchased in 2002. The rubber gasket on the inter panel comes loose occasionaly and then leaks water, I had it replaced twice, but the heat and suction of the door openning pulls it away unexpectingly. We are in the process of replacing a wood floor now cause by the leaking. Before we put down the new floor, I would like to solved this issue and would not prefer to purchase a new dishwasher just because I can't fix a gasket. Any suggestions?
  • 1 more comment
  • char3g Feb 26, 2008
    i have model 665 also and i have the same problem. Anybody know of any fixes?
  • Anonymous Apr 06, 2008
    I have the same problem and need my wife off my back!
  • Anonymous Sep 14, 2008
    I have the same model dish washer with the same problem. I also have a Kenmore Elite Dryer that has a problem with the elctronic dryer controls. Sears repair has been out two times to fix it. Low and dehold the problem was never fixed properly. No more Kenmore products for me. Poor products and poor service.
I have the same model dishwasher with same problem. The gasket first came loose just after my warranty expired. The stainless steel and heat don't make for a good combination with the glue that holds the gasket in. My husband works with caulk and the like. He found a clear gel of some sort to get everything to adhere. It's had to be reapplied. I just make a habit of making sure the gasket is seated in its track and watching if dishes on top rack catch the gasket when I pull rack out.
See, item #1065754, White silicone adhesive, specially formulated for use in the dishwasher to adhere tine tips & door gaskets. It's an accessory for this dishwasher. I don't know if Sears Parts Direct offers it. Sometimes their price is lower.
From above website it costs $14.55
Posted on Jan 08, 2009
I have a Kenmore elite 13102 dishwasher touchpad that has begun to crack around the start button. Does this necessitate changing out the whole electronic control pad or is there a part that is the...
You will need to replace the touch pad assembly. You can purchase the part from the link below.
Kenmore elite Dishwasher Parts Link
You can read an article that explains how to make this repair yourself at the link below.
Appliance & Refrigerator Repair
Mar 22, 2011 | Dishwashers
Lights do not come on kenmore elite dishwasher
There is a thermal fuse on this model located on the control board. Remove control panel and you will see it attached to the board with 2 wires going to it. part number is 8193762. Hope this helps.
Feb 24, 2010 | Dishwashers
The Vent Deflector is leaking on my Kenmore Elite Dishwasher. How do I remove it to check the gasket?? We took the front panel off our dishwasher and was able to discover where the water was coming from.
There are 4 screws holding it in place. But first the plastic trim must be removed. That is snapped into place.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 10, 2009 | Kenmore Elite 45986 Front Load Washer
Dishwasher seal issue
I use ge silicone clear sealant it is flexible adhesie that can handle water and heat
You can get this at Ace or big box stores you do not need a big tube
1 Open dishwasher door
2 gently pull rubber seal away from dishwasher guide You do not have to remove the entire seal unless it is loose just keep pulling until you feel the seal staying on dishwasher
3 put a small amount of clear sealant on loose seal(side facing housing) and small amount on dishwasher guide ( dip your finger into water so that it does not stick to your finger)
4 press the seal into place on dishwasher housing
5 wipe excess with a damp cloth be sure you do not get any on seal side that faces dishwasher door
6 Allow to dry over night
Good Luck
Jan 02, 2009 | Kenmore Dishwashers
Kenmore Elite Dishwasher - leaks from Overfill Protection Float
I had the same problem, but mine leaked every time. I have a kenmore ultra wash dishwasher no. 665.15762. I took the bottom rotating sprayer off and found that the plastic piece under the sprayer had a few loose screws and the rubber gasket, under that piece, had blown out at the corner facing the overfill protection float. I took out all the screws and re-mounted the gasket in place and put all the screws back and tightened them. It solved the problem. I hope that this helps others.
Nov 11, 2008 | Asko 24 in. D3250 Built-in Dishwasher
Leaking dishwasher
i had a ge that leaked in front, needed to replace rubber door gasket....
Nov 09, 2008 | GE Nautilus 24" Built-in Dishwasher
Whirlpool dishwasher quiet #1
Have you figured your dishwasher problem out yet? In my Whirlpool, that tube doesn't fit on the wash column, it just snaps on to the lower rack, right above the washer column black rubber gasket... hope this helps!!!
Sep 02, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Water seeping in dishwasher
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Jul 29, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwasher sticking half way through cycle
Crawlmom, it sounds like your door latch assy. and switches are not making properly sometime during the wash. Therefore the two dashes. You want to make sure that the dishwasher is level and securely mounted. Another thing is, on this model, if a key pad is stuck, the dishwasher will stop and flash the stuck key. Im not sure where the red light is coming from. Without being there, I'm leaning on the door switch assy. Check this out first and post back. Catriver.
Apr 15, 2007 | Kenmore 24 in. 16939 Built-in Dishwasher
Dishwashers Logo
757 people viewed this question
Top Dishwashers Experts
