Question about Canon PowerShot A540 Digital Camera
What to do?
I never bothered with the warrenty and the one year is over due. But I am having the flash problem and also the very short battery life. Is it worth fixing or sending it to canon or just get new camera?
  • Babykate58 Dec 13, 2007
    Also having problems with the takes pictures fine without the flash but when I have it on it takes almost a minute to take the picture...the batteries are constantly low I seem to have to change them every week.. I have only had the camera for a year...not sure what to do to fix this..if the flash is just a setting i need to chagne or what..
  • 108 Answers
A540 is nice camera that you can still use, if you can find a friend or replace battery try replacing battery. if not A720 will be waiting for you in canon showroom :)
Posted on Dec 12, 2007
I have a lithium ion battery and it won't charge. The red lights simply keeps flashing. I warmed up the battery, but so far no luck
There could be a variety of reasons for the battery malfunction, some of which are listed below:
a) low battery voltage due to long term storage without charging (>1 year, charger will not charge if the voltage is too low. What is the voltage?),
b) cell imbalance due to shorting out the terminals (was the battery used for other purpose than running power tools?),
c) internal corrosion caused by exposing the battery to damp environments during its life (need to open the battery and look for signs of corrosion on the cells. Was the battery left out in the rain at some point in time?),
d) battery age, ie, the cells may have reached their end-of-life based on the number of charge cycles (what are the estimated number of cycles?),
e) faulty charger (does the charger charge other batteries?),
f) internal battery damage with broken connections (has the battery been dropped or mishandled at some point?).
More details should be provided before suggesting possible solutions.
Jun 15, 2014 | Ryobi Two 18V Lithium-Ion Batteries +...
Battery problem
you have some problem with batteries:
a) use the same right type from batteries
b) if you use rechargable , see if are FULLY charged, otherwise your device charger is defective, and replace batteries.
c) power supply is defective draining life for batteries go to the repair shop and fix it.
d) remember if you use too much the flash the life is short,+zoom
God bless you
Aug 02, 2012 | Cameras
Motorola RDU2080D Short Battery Life
Short battery life can be due to several factors:
1) Short initial charge(s) when the battery was new.
2) Age of battery. Check your date code embossed on the lower portion of the battery below the label. On a three digit code the first number is the year, next two are the week of the year. If a four digit code the first two are the year. Example 142 is 2011 the 42nd week. OR 1142 if a 4-digit code. If you battery is more than 18-24 months old it likely needs replaced.
3) Short charging the battery by putting the radio on the charge too often, or with the radio turned on. Always turn the radio off when charging.
4) Poor connection with the charger. Clean your battery contacts on both the radio and the charger with a pencil eraser.
5) Excessive talking. Heavy talkers radios will run down quickly. It takes more energy to Transmit than to Receive. Using the 5/5/90 rule, your battery should go an 8 hr business day.
Note: There are 3 battery styles available for your radio. The one which comes with the radio is a 1100 mAH battery. There are also two others with higher capacities available.
Best regards.
Oct 26, 2011 | Motorola RDU2080d Two Way Radio
My new samsung galaxy ace has a VERY short battery life.. it doesnt matter if i change the settings.. it only last for about 1 day at most.. not even 24 hours.. how can i fix this?
"If your battery sat on the shelf for a year, then it has deterioated enough to where it would only hold 1/ 2 to 2/ 3 the original charge."
galaxy ace is relatively new. nothing you say makes sense.
if you don't use data service, you can switch to gsm (not 3g) to preserve battery life. works with me across devices.
Feb 24, 2011 | Samsung Cell Phones
My battery light has come on. The battery is only about 5yrs any suggestions
Check battery for a early sign of wear Bad cell !! Also have your alternator tested by PEP Boys or AUTOZONE on A tester unit !! swampratt200 !!1 AAAEEE!!!!
Jul 21, 2009 | 1994 Land Rover Defender
I850 printer problem
Right, This fault is due to the waste ink pads being full, The machine will stop working until the machine has been servcied and cleared. Normally it is the end of life once the ink pads are full. By time you get a engineer out with new pads and for him to fit them it would cost more then a new machine, so i would buy a new machine with a one year canon warrenty , be so much eaiser and cheaper
hope this helps
Jul 23, 2008 | Canon i850 InkJet Photo Printer
1 to 3 year warrenty they will give you
in 1 year warrenty if your drive not responding totaly than they transfer to dealer & they will transfer to production house for replace ment
1 more thing if they had say you for life time warrenty than its also equal to 3 year warrenty.
so take care of it.
May 17, 2008 | Samsung (SP0411N) 40 GB Hard Drive
Red flashing ring when xbox is turn on.
Your xbox 360 is having what is called 3-Rings of death.. its bascially a short in the system when it heats up...are you still under the service warrenty?
call 18004myxbox it was extended to 3 years due to this problem. I would hope that you are.. but if your not there is still hope!!! depending on where you are lots of people can do a easy hardware fix for this.. check out the link
May 02, 2008 | Video Game Consoles & Games
Life-Drive will not power on.
I don't know how much technical skill you have, but I had the same problem and the warrenty had expired. I thought it might be a battery problem. To make a long story short I unpluged the internal battery and pluged it back in and the system came on.
Dec 26, 2006 | Palm LifeDrive Handheld
Canon PowerShot A540 Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
