Kenmore 24 in. 16352 / 16354 / 16359 Built-in Dishwasher
Problem for Kenmore 24 in. 16352 / 16354 / 16359 Built-in Dishwasher
Only thing the dishwasher will do is the cancel drain for 2 min.
By qthinkest on Sep 17, 2009
The dishwasher will not run, it will only run through the 2 minute cancel drain cycle. The clean light blinks 7 times and then repeats the cycle. I have replaced the start button and checked the float.
Solution #1
posted on Sep 17, 2009
Not Rated)
jsrock516
Rank: Guru  Kenmore Dishwashers  Expert
Rating: 96%, 7537 votes
This may help in your situation. The following link explains how you may be able to clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now...keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up as I have referenced, the tech sheet for your dishwasher will explain. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this helps you solve your problem.
Was this helpful?
Yes
No
Popular Solutions for Kenmore 24 in. 16352 / 16354 /
Questions and Unsolved Problems for Kenmore 24 in. 16352 / 16354 /
Do you recommend Kenmore 24 in. 16352 / 16354 / 16359 Built-in Dishwasher?
Answer
Answer
Some nights the dish detergent does not dissolve....I have tried, gel pacs, liquid detergent, and... (More)
Answer
The soap dispenser doesn't alway open during operation, and when it does happen to open, leaves... (More)
Answer
kenmore elite timer stopped at 42 continued to (run ) make noise like it was working for 3 hours... (More)
Answer
dishes do not appear to be rinsed with residual soap on them
Describe your Dishwashers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwasher Experts
Top Dishwasher Repairmen
in Dallas, TX
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Your name:
Your email:
Your friends email addresses: (e.g. Julie@email.com)
(Separate email adresses with commas)
Message:
Cancel
