Question about Hitachi Office Equipment & Supplies
Resetting the air filter timer
Hi, I cleaned the air filter on the Hitachi CP- RX60 projector and followed instructions on the resetting of the timer. Using the remote it jumps (in the menu) out of the cancel mode to sub menu and it will not let me high light the reset. There is no reset on the projector itself. How can I clear the air filter message when I start up the projector?
  • 5 more comments
  • Anonymous Jan 07, 2008
    same problem
  • Anonymous Jul 23, 2008
    Hi, I cleaned the air filter on the Hitachi CP- s225 projector and followed instructions on the resetting of the timer. Using the remote it jumps (in the menu) out of the cancel mode to sub menu and it will not let me high light the reset. There is a reset on the projector itself but won'reset the projector hour . How can I clear the air filter message when I start up the projector?
  • jennif Nov 04, 2008
    I have the same problem! Can anyone help?
  • battlebuddy Nov 25, 2008
    I do not have amanual for the projector. Can you describe the steps in resetting the bulb and filter timer? It appears to be working fine, but the temp and lamp lights remain on. I pulled up the menu and found the screen that lists the lamp and filter time. Both state 107 hours. thanks
  • Anonymous Jan 14, 2009
    Same problem....please help.
  • Anonymous Apr 23, 2009
    I cannot believe there is no help... Never buy Hitachi again.
  • faizan
    faizan May 11, 2014
    sam problem
Hiya there, just worked out how to reset the filter timer so for those that need to know here's the solution;
Bring up the menu and go right the way down to "Option" where it shows you the lamp and filter hours.
Next highlight/select the filter timer section and while its on there hold the RESET button on the remote for 5 seconds.. this then pops up with a resert option and hey, 0h again, good as new! :-)
Oh and if you dont have a remote, just hold the right arrow button instead for 5 seconds in place of the reset and follow instructions as above!
Hope this helps.
Regards,
Omar.
Posted on May 07, 2009
Highlight filter time in menu then press RESET button on remote for min 3s to bring up menu. then up arrow to reset.
Hope this helps.
Posted on Jan 22, 2008
Under Advanced go to filter time.
The filter time is the time counted after the last resetting. It is shown in the OPTION menu as the use time of the air filter. Performing this item resets the time.
Pressing the RESET button on the remote control or the button > on the projector for about 3 seconds displays a dialog to make sure. To perform reset, poing at RESET using the UP ARROW button
Posted on Apr 23, 2009
  • bryant89 Apr 23, 2009
    IT works!
Ok, don't know about the CP-s225, but the CP-RX60 (and CP-RS55). I find it easier not using the remote but the Menu button and the cursor keys. 'menu', then work your way down to the 'reset / Filter Time sub option' option in the 'easy menu' and when you get to the Filter Time option press the right cursor key and keep it held in until the reset menu appears (it needs holding in for 5 - 10 seconds before the reset menu will appear. its more or less the same procedure for the lamptime and filter time but i think the lamp time is only accessible through the 'Advanced menu' which again you select via the cursor keys at the bottom of the easy menu. Apologies if this sounds a bit naf, it what i can remember off the top of my head but the key is holding the right cursor key down for longer than one click.... Hope this helps
Posted on Mar 11, 2009
It helped. I lost the remote, but could also do it with the buttons on the projector itself. The key is to hold for more than 3 sec. thanks!
Posted on Feb 20, 2008
Depress the RESET button for at least 3 seconds while lamp time is being displayed. The reset menu will appear. After you replace the filter, select RESET on the menu.
Posted on Jan 12, 2009
I also have the same problem. Last time I just about managed to get it to reset after working on it for ages, this time I canno. Dioes anyone know the answer? martin@canalmuseum.org.uk
Posted on Jun 09, 2008
3 Suggested Answers
  • 105 Answers
SOURCE: Resetting the air filter timer
Hitachi CP- RX60:
Press the RESET button on the remote control or the right-pointing triangle button on the projector for about 3 seconds. Once you see the RESET dialog, use the upward-pointing triangle to RESET. I can't see what you are or are not doing...so please see page 39 of the user's manual (download found below)
Source:
http://www.aboutprojectors.com/Hitachi-CP-RX60-projector.html
Hitachi-CP-S335 :
"The lamp time is the time counted after the last resetting. It is shown in the OPTION menu as the use time of the lamp. Pressing the RESET button on the remote control for about 3 seconds displays a dialog. To reset the lamp time, select the RESET option using the (triangle) button."
Taken from pg 36 of the users manual (download link below)
Source:
http://www.aboutprojectors.com/Hitachi-CP-S335-projector.html
Posted on Apr 24, 2008
If you do not have a remote here is how to reset the filter time. Use the "Menu" bottun to get the "easy menu" to display. Push the down arrow until you get to "Filter Time," then push and hold the RIGHT arrow to reset the filter time. DO NOT try to reset using the "Reset" option on the easy menu, it will not work.
Posted on Oct 02, 2008
Hi there, I can not reset the filter timer on a Hitachi CP-x4445 projector
Sometimes the reset on that timer can be picky. Here is the snippet from the manual that suggests you hold the reset for 3 seconds:
If it were me I would skip using the remote and follow these steps using the panel on top of the projector (using the arrows, etc) . Hold the right arrow to get the reset until it shows, rather than trying to count the seconds...
Mar 10, 2011 | Hitachi CP-X445 Multimedia Projector
After turning on the projector, I get a message that says clean the filter and reset the timer. How do I do that? I have cleaned the filter.
Procedure for resetting filter time.
Pressing the RESET button for about 3 seconds displays the FILTER TIME menu. Select the RESET using button to reset the timer. : RESET <- CANCEL Selecting the RESET resets the count of the lamp timer to 0. memo Perform this function only when you have cleaned or replaced the air filter. The filter timer counts the used time of the air filter after cleaning or replacement, to display the messages about the air filter. Incorrect performing causes incorrect operation of the messages. memo About caring for the air filter, please refer to the section "Air Filter".
Users manual located here. http://www.aboutprojectors.com/pdf/hitachi-cp-x1250-manual.pdf
Good info deserves a good thumbs up! Thank you!
Mar 01, 2011 | Hitachi CP-X1250 Multimedia Projector
Hitachi projectors cp rx60 cp r555 same remote control?
Specifically i don't know. What i do know is mfg's use the same codes, whether they map them to the same functions across a series of remotes can't say for sure. Experiance tells me it will be just fine...
Jun 10, 2009 | Hitachi CP-S335 Multimedia Projector
Cleaning the filter/blinking LAMP and TEMP
Goto Advanced menu and select option then lamp Time hold down the reset button on the unit for 3 seconds until a new screen comes up then hit reset. Do the same for resetting the filter time
Feb 01, 2009 | Hitachi CP-X445 Multimedia Projector
Lcd projector beeps every minute
Hi Jenrowe
Try resetting the lamp and filter timer , if this still occurs reset the whole mashine.
Apr 24, 2008 | Hitachi CP-X275 Multimedia Projector
Apr 22, 2008 | Hitachi CP-S335 Multimedia Projector
Hello Wardens wife
What you want to do is go to the advanced menu, find the filter time and using the remote hold down reset button for 3 seconds or so while the filter time is selected. This will bring up a reset menu and reset the timer.
Mar 23, 2008 | Office Equipment & Supplies
Resetting Air Filter Timer once cleaned.
Menu, options, filter time. When the filter time is displayed, press the reset button for at least 3 seconds. The reset menu will appear and you can select RESET.
Feb 01, 2008 | Hitachi CP-X385 Multimedia Projector
Hitachi CP-X250 LCD Projector
clean filter and reset the filter timer by advanced options filter timer and hold reset till menu shows then arrow up and it will zero out.
Oct 19, 2007 | Hitachi CP-X250 Multimedia Projector
Projector Reset
Hi Here is the info for you :: Caring For The Air Filter The air filter should be cleaned about every 100 hours. If the indicators or a message prompts you to clean the air filter, clean the air filter as soon as possible. If the soiling will not come off the air filter, or it becomes damaged, then it needs to be replaced. Please replace the air filter as soon as possible. memoWhen you replace the lamp, please replace also the air filter. Turn off the projector, and unplug the power cord. Allow the lamp bulb to cool for at least 45 minutes. Apply a vacuum cleaner to the top of the filter cover and the air filter to clean. If the soiling will not come off the air filter, or it becomes damaged, it needs to be replaced. If the air filter needs to be replaced, contact your dealer to prepare a new air filter. Tell the dealer your air filter type. Turn on the projector power, and reset the filter timer. (1) While the projector running, press the MENU button to open the menu. (2) Choose the ?OPTION? on the menu using the / button, then press the button or ENTER button. (3) Choose the ?FILTER TIME? using the / button, then press and hold theRESET button for 3 seconds. (4) Choose the ?RESET? using the button. memo Incorrectly resetting of the filter timer (resetting without replacement, or neglect of resetting after replacement) will result in incorrect message functions. Here is the link to the users manual :: http://www.aboutprojectors.com/Hitachi-CP-X1250-projector.html Further Questions ?? Email Me hartmansp@inbox.com Have a great evening.
May 03, 2007 | Hitachi CP-X1250 Multimedia Projector
5,923 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
